Question about Amana ALG331RAW Gas Dryer
Glow rod goes on does not ignite burner
Glow rod turns on burner does not ignite then glow rod shuts off drum keeps spinning
  • lavonallen Feb 06, 2009
    Have this same problem and changed the coil set.It still has a problem . Where to check next?
    Problem Solver:
  • 14 Answers
You need a coil kit for the valve.
Posted on Jul 25, 2008
Why does it start, then shut down followed by 3 clicks?
  • Thermostat calls for heat
  • Venter motor starts
  • Air switch verifies vacuum
  • Igniter sparks, or glows - depending on furnace
  • Flame starts in burner
  • Flame rod senses flame
  • Burner continues to burn until thermostat stops calling for heat
By your description, I would polish your flame rod, it will be a metal rod that is insulated from the bracket that is screwed to the furnace case and it will have a single wire attached to flame rod,
Sep 29, 2015 | Intertherm 56000 Btu Gas Furnace
LG DLG7188WM gas dryer is not igniting
There are 3 things that will make a gas dryer not ignite. 1. the main controller 2. high limit thermostat, which disconnects power to the igniter if the dryer overheats 3. the electronic or electric igniter. There are 2 types of igniters static that sounds like a ticking noise before it lights and a thermal that glows red hot to ignite the burner. Most dryers will attempt to ignite 3 times and will shut down if the burner does Not ignite to keep unburned gasses from being expelled.
With the front cover off also called the kick pan, look at the burner assembly and you will either see the spark igniter (like a giant spark plug) or the thermal igniter glow red hot. If the igniter does not activate, and the drum is turning, it is either the igniter, or the high limit thermostat stuck in the open position and needs to be replaced.
Both can be purchased from EBAY and will save you lots of money.
May 06, 2014 | LG Dryers
Our Gibson KG7TC060D24B "tries" to start, but the shuts off before ignition. Technicians have replaced the control panel and other components but the problem persists, with the furnace working for a few...
This is possible, however it is possible they are missing something simple. I hope you can follow along.
1) Is this a Sealed Combustion Furnace, meaning you cannot get to the burners even after you remove the Door Panels?
2) If yes, is this furnace vented with pvc/plastic piping?
3) If yes, do both pipes go outside?
4) If yes then try this.
1) Turn the main power off to the furnace
2) Remove the Door Panel to the burner section.
3) Turn Furnace back and turn the thermostat all the way up.
4)Look into the burner compartment and tell me if the igniter glows red. If it does and the goes out with the burners not coming on.
5) If you feel comfortable or know of someone that is.
6) Turn the furnace off, remove the panel that conceals the burner compartment.
7) Turn the furnace on, if the igniter glows red and the burners ignite. Your problem is in the venting system. Most likely the intake pipe if it goes outside. It could be plugged or something is blocking it. If the burners do not ignite the next thing to make sure that is happening is that the Exhaust blower is operating and you can feel air outside where the pipe terminates. If you it is but no very strong, then your problem could be the inducer motor or to small of vent pipe.
If you could, send me some information about how it starts up
1) Main blower may come on and shut off, make sure the blower runs in on position 1st then back to Auto position. If it does not, you have another problem.
2) The Exhaust blower should come on next
3) About 17secs. later the igniter should glow red.
4) You will here the gas valve make a click
5) The Burners will ignite
6) The flame sensor rod on the far left hand side of the burner will keep the burner lit. If it is dirty the burners will shutdown.
7)About 90secs. later the main blower will come on.
Oct 26, 2013 | Gibson KG7TC060D24B 60,000 BTU 95.1% Gas...
Dryer won't heat up and light bulb turns on then off when door is opened.
Does the drum spin when you shut the door and start the dryer if so it wouldn't be a bad door switch. 1st. thing I would check would be the igniter with front kick panel off dryer it's located at the bottom right hand outer side of drum in the burner duct. here's how you check it with door shut start dryer and look for a orange glow from the igniter if no glow it's a bad igniter if it's not the igniter it could be a thermostat or a flame switch check these things if need more help I'll be glad to help.
Feb 25, 2013 | Dryers
Goodman furnace gmh95090cxac wont stay lit keeps clicking will lite then clicks back off what would be the problem
Hello, if the burners light but do not stay on for more than 10 seconds, I would clean the flame sensor. The flame sensor is a metal rod that is on the opposite side of the Igniter, sometimes it gets coated by oxidation and does not sense the burner flame and shuts the Furnace down. To clean to kill power to tje furnace, remove flame sensor and clean with a steel wool, then reinstall and start Furnce back up. If this does not work then most likely the Igniter is too weak to ignite the gas and will have ro be replaced.
Oct 29, 2012 | Heating & Cooling
My Amana GUI090B30B furnace will not ignite. The ignitor glows then the valve releases gas but the gas does not ignite. The ignitor goes out and the valve shuts after a second or two of trying to ignite...
Hello, it is possible that even tnough the ignitor is glowing it might be too weak to ignite the burners. I would cneck the resistance of the ignitor with a multmeter, should be between 40-90 ohms typically
Nov 28, 2011 | Heating & Cooling
MAIN BURNER SHUTS DOWN JUST AFTER IGNITION FLAME RODS TESTED VENT CHECKED
The Thermocouple or Thermopile has failed and needs to be replaced. The Thermocouple is a safety feature that keeps the pilot burning if all operations of the gas valve are safe. If the pilot burns, the burners will light. The Thermocouple shuts off the gas control valve if the pilot goes out.
Mar 08, 2011 | Heating & Cooling
Hi I have a Coleman furnace that has the electronic ignition model # G9to601oupb13c that will come on for about 3 seconds then shuts down if i turn off the power and restart it willl come back on and then...
If you mean hot surface ignition and not spark then look in front of the far burner from the glow plug and clean the rod in front of the burner with a piece of steel wool, the rod is probably dirty and can not sense the flame, so the gas shuts off.
Oct 11, 2009 | Coleman Propane Forced Air Heater...
After starting my GE gas dryer , the burner fires and everything seems fine . The burner stays on for a few minutes and shuts off like it's supposed to . After a few minutes , the glow element turns on to...
Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Aug 01, 2009 | Dryers
Furnace pilot light turns on furnace lights then shuts off
If you have a hot surface igniter (glow coil) it has a secondary purpose after ignition and that is to sense that there is actually flame present. If the HSI is located on one end of the burners look to the other and see if there is a small rod that protrudes in to the flame as well. If so it is part of this flame proving cycle. Take some sand cloth and clean it. This may buy some time but the rod should soon bee replaced.
Jan 17, 2009 | Heating & Cooling
Amana ALG331RAW Gas Dryer Logo
90 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
