Question about Mitsubishi WS-55859 55" Rear Projection Television
Green timer light turn on tv turns off
Hello i push the power button to turn on the tv the green timer light goes on then it just shuts off
  • acutler6 Aug 02, 2008
    same problem. green light turns on and then goes off.
  • Anonymous Aug 12, 2008
    same green light problem
  • 2,326 Answers
Read the info from this link to see if that applies to your TV.
Posted on Aug 12, 2008
How do I fix my Jvc the screen won't power on. When I reset it the lights on the buttons light up...but shut off right away. It has power because the red light on the bottom left corner stays lit.
JVC LT-46AM73 LCD TV Won't Turn On - YouTube
? 3:28
https://www.youtube.com/watch?v=y5j3RGUe4gM
Feb 25, 2015 - Uploaded by Awesome Things
JVC LT-46AM73 LCD TV won't turn on after power outage. ...LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to ...
JVC wont turn on - JVC - Streaming Video & TVs
www.tomsguide.com/answers/id-1677424/jvc-wont-turn.html
May 15, 2013 - JVC lcd tv will act like its turning on then the green light after 2 seconds ... wont turn on Forum; SolvedAcer Laptop V4DA2, screen won't turn on.
My Jvc Av-32F476 Tv Won't Power On, The Green On Timer Light Stays ...
www.diyforums.net/my-jvc-av-32f476-tv-wont-power-on-the-green-on-...
Dec 8, 2013 - My jvc av-32F476 tv won't power on, the green on timer light stays on and m. ... On the remote control, look for the buttons PICTURE MODE and DISPLAY, with ... My Jvc Lt24dd52j Won't Turn On The Blue Light Is Flashing But ...
Nov 1, 2014
I Have A JVC LT-42TG30J, Randomly The Tv Has Decided It ...
Aug 29, 2012
I Have No Picture On My 47 Inch On My Jvc Big Screen Just A ...
May 23, 2012
My Dynex 42" Wont Turn On Power Led Is Lit Up But It Won't C ...
May 24, 2011
More results from www.diyforums.net
Jan 18, 2016 | JVC Televison & Video
Got a Samsung dnie model code spp4251x/data tv when powering up the front light comes on but no picture or anything anyone got some good info??
tv seems to turn on but no picture? - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - ... Samsung Dlp TV (HLR-5067W) it seems like the TV turns on butthere is no picture. ... the lamp is, light is visible from where the lamp is located but no picture. DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
The timer, lamp, and standby/temp. light are flashing?!
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...I Have A Sanyo TV I Can Hear But Black Screen Im 14 And Dont Know What To Do ! .... power button the power light goes from red to green, the screen flashes on then goes black ....Troubleshooting LCD Backlight Failure Samsung LNT-4066 ...
Samsung plasma tv repair blinking light no picture ...
Jan 09, 2016 | Samsung Televison & Video
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
Sony trinitron kv-es29m80 tv has no led light
The blinks are fault indication. If the standby light blinks 10 times and the set shuts down after that;
Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board
Apr 12, 2012 | Televison & Video
Panasonic pt-43lc14 won't turn on
Try checking your lamp door. I have seen a few of these that you need to really wrench that screw down. Let us know.
Mar 22, 2010 | Panasonic PT-43LC14 43" Rear Projection...
Don't have remote. T.V won't turn on, but power light is on
well try to push buttons on the tv , i belive that might help. for example i had the similar problem and i just pushed the AV/TV button and it turned on. good luck
Jan 05, 2010 | RCA TruFlat 27F520T 27" TV
My flatscreen emerson tv will not turn back on.
I found a way around this problem. When this happens, don't use the remote.
Walk up to the TV, then HOLD DOWN the power button and while the lights are flashing, start pushing the menu button on the TV at the SAME TIME.
Then your screen will turn on. No idea why this works. Just stumbled on it while getting ********** that this TV, I had less than a month, suddely would not come on anymore. I was about to unplug the whole thing to take back to WalMart and just started pushing button combinations and found this worked.
Mar 30, 2009 | Emerson LC320EM8 32 in. LCD TV
Timer light is flashing but tv wont turn on!
When the timer light stoped flashing the remote control would not turn on the TV. The next time the light quit flashing I held the power button in on the TV for about 5 seconds and it came on and has had no problems since then with the remote or the local TV power button.
Greg Allen
Aug 29, 2008 | Mitsubishi Televison & Video
Mitsubishi WS-55859 55" Rear Projection Television Logo
160 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
