Question about Microsoft Xbox 360 Console
Disc won't read
New disc will begin to play then stops read unable to read disc, please remove and clean.
  • Anonymous Jul 23, 2008
    I'm writing this on behave of my cousin because he has the same problem. What I think will sove the problem is if you get a disk cleaner which is a simple disk with a soft lens safe brush on it, and use that to clean the inside of your xbox 360 out. That might make the lens able to continue to read disk.
    Scholar:
  • 26 Answers
Microsoft Xbox have some common problem like red lights, E74 and Disc Read Error. Microsoft is providing extended warranty for red lights problem, Means you will have to spend some money in order to get this problem repaired from Microsoft also you will have to wait for 3-4 weeks to get your Xbox back. There are many reasons disc read error can occur in your Xbox like your disc might not be clean, laser might also be dirty and many more common problem. I would suggest you to first clean out the disc, you are using. If that don't solve the problem you can also take the help of DIY guide available at Internet. I think you have got good no. of options to get your Xbox repaired, Choice is yours.
Posted on Mar 13, 2009
  • 4 Answers
The prob is that your lazer is knackered you will have to replace the lazer on the DVD.
Thanks
Posted on Jul 23, 2008
Why doesn't CD player read discs?
If it's the CR-Rom of a computer, please restart your computer.
If the failure persist, means that the optical reader of your CD player is fauling.
No sure it should help but clean your optical reased.
Hardware 101 Cleaning The Lens Of Optical Disc Drive
Actually the same goes for a standalon player.
With costs as low as they are currentl, you sinply should remove the CD player of your computer and intall a new one
If this is not the answer you expect is because your question was not well specified.
Oct 26, 2015 | Audio Players & Recorders
Ferguson TV DVD fault - won't play discs
Check its loading mechanism for proper disc loading. Replace the loading belt first and check. If it does not help you, insert a cleaning disc into it. If the fault is with accumulated dust or dirt on the laser pick up lens, it will be cleared out. If not, replace the laser pickup unit.
Nov 27, 2012 | Televison & Video
Getting a C 13 70 disc is dirty message only for DVDs that I'e burned recently. I bought a new pack of blank DVDs, the same kind I've always used, but every movie I burn on these new ones, they...
Hello, welcome to Fixya!
Was this player playing previously? And how long have you been using this player? I suspect the lens of the player. Once the lens of the player becomes weak, it won't play discs any longer.
The first thing my mind goes to, is the lens. The lens id responsible for reading/loading data on discs. So if the lens is unable to read the disc, there is no way the player is going to play the disc.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or probably, a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Good luck.
Nov 03, 2011 | Sony DVP-SR200P DVD Player
My playstation 1 won't play any games. It will start up with the disc spinning but then the disc stops spinning and i end up on the memory card screen.
DEAR FRIEND CHECK YOUR PS LANCE EYE AND CLEAN I HOPE READ PLY STATION LOGO THAN NOT PLAY , CHECK YOUR PCB BORD RBI CHANGE THAN REMOVE YOUR PROBLEM I HOPE SOLVE YOUR PROBLEM TACK CARE
Aug 21, 2011 | Video Game Consoles & Games
Hello! I own the Panasonic SA-HT692, lately I have been unable to listen to cd's due to a "clicking" sound the player makes while attempting to read the disc(s). I have cleaned out the disc...
The clicking noise is the optical unit trying to read the disc. When its working normally the CD spin's and the system reads the table of content ( info: on the CD ) and the disc stops till you give the next command , e.g PLAY etc. Now when the laser beam is weak due to dust on the lens or age, the unit starts to hunt for the CD by popping the len up and down trying to focus the laser beam to get a strong reflection. This constant up and down movement is the clicking sound you are hearing.
Either unit has dust on the lens or is due for replacement ( if it has done more than 500 / 750 hours ).
Apr 22, 2011 | Panasonic Home Theater System System
WON'T PLAY CD'S READS "NO DISC"
  • Check the disc you're using for scratches and dirt. If the disc is damaged it won't play properly, regardless of the CD player's ability to function. You can use a CD repair device like the "Disc Doctor" to repair the CD or purchase a new CD.
  • Clean the laser lens with a CD laser lens cleaning disc. CD laser lens cleaning discs can be purchased at most electronics retailers or online. Insert the laser lens cleaning disc and follow the instructions.
  • Insert a correctly-formatted, undamaged disc into your player. Listen to see if it begins to read the disc. If it continues to make no sound and gives you the same message, then the problem is probably that your disc is not spinning in the device.
  • Clean the lens while the DVD player is open. A dirty lens is most likely the cause of your no-disc error. The lens should be cleaned with isopropyl alcohol and a cotton swab.
  • Dec 11, 2010 | Sony CMT-EP505 CD Shelf System
    Wii "unable to read disc"
    If Wii gives Unreadable disc, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
    Dec 04, 2008 | Nintendo Wii Console
    To install wii fit
      "Unable to read the disc" / "Disc could not be read" / "Eject the Game Disc" Error Message.
      If you are getting one of the above error messages:
      • If your console is placed vertically, the disc label will face to the right.
      • If your console is placed horizontally, the disc label will face upwards
    • If you know you are inserting the Game Disc correctly, but are still have the same problem with only one game (or if you only have one game), try cleaning the Game Disc by following the disc cleaning procedures
    • If after reading the above information you are still unable to play a game disc, please call 1-800-255-3700 to discuss available options.
    Aug 13, 2008 | Nintendo Wii Console
    My nintendo wii wont load discs??
    Here's a page on the official Nintendo site that might help.
    "Unable to read the disc" / "Disc could not be read" If you are getting one of the above error messages:
    • If you know you are inserting the Game Disc correctly, but are still have the same problem with only one game (or if you only have one game), try cleaning the Game Disc by following the disc cleaning procedures (click here).
    Oct 23, 2007 | Nintendo Wii Console
    Wont read discs
    If it only does this for this one game, you may have a defective game disc, it happens. Often, if you have just recently purchased it, you can return it to the store and tell them that it was defective and get a new one. If not, you can always try cleaning it though I doubt that's the problem.
    nintendo.com says "If after reading the above information you are still unable to play a game disc, please call 1-800-255-3700 to discuss available options."
    Oct 01, 2007 | Nintendo Wii Console
    Microsoft Xbox 360 Console Logo
    89 people viewed this question
    Top Microsoft Video Game Consoles & Games Experts
    marley mcelhinney
    Tre Elkins
    Mike Neath
    Mike Neath
    Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
