I have the NS-PDP42 42" PLASMA 720-P and I would like to know how to change the screen resolution for hdmi devices. In the user guide it says to change it to 1280 x 720p but it does not tell how to change it. Or, should I be able to use 1080i. I use Comcast and have just gotten an HD box and it tells me to choose either 720p or 1080i and to refer to the TV'S manual to find the best picture resolution it will support.
    Problem Solver:
  • 5 Answers
There's no way to tell the HDMI input whether it should take 720p or 1080i input on this set. The best thing to do is experiment. Set your Comcast box to 720p and watch it that way for a while, then set it to 1080i and watch it for a while. The PDP42 has to do a little picture manipulation in either mode, but I think you'll find that the 720p mode will work best for you. I have this set with Verizon FiOS and I have the FiOS output set to 720p. Looks great, no complaints.
Posted on Nov 13, 2008
I cannot change my Visio resolution from 720 to 1080
If it is a 1080p TV, then the TV always displays at 1080p. The source device and/or the TV will scale and frame convert the image to match the TV resolution and frame rate. When you power an HDMI device, it reads the TV's supported resolutions and audio formats over the HDMI cable, then it chooses whether or not to scale the image for the TV. The television then receives the signal and performs whatever image processing is needed to match the display needs. With many Source devices, you can use a setup menu to configure whether video should always be scaled up to 1080p. Some people prefer the image scaling of the television. However, if the Source does not upscale, it will limit the resolution of on-screen graphics, such as the program guide. So you'll probably prefer to scale your source devices to 1080p through their menus.
Mar 21, 2017 | Visio Computers & Internet
How do I change the resolution on my Phillips 4k tv from 720 to a higher resolution tools
The TV will select the correct/appropriate resolution based on the source. To achieve the highest resolution you will have to connect a unit (video source) capable of providing 4K using HDMI 2.0 compliant cables. To achieve any HD resolution, the video source will have to be connected to a HDMI port. The ATSC terrestrial digital broadcast signal (over the air TV) is generally 720p, but many stations transmit in 1080i/1080p.
Jun 23, 2016 | Televison & Video
How do I change the HDMI from 720 to 1080.
How do I get 1080 instead of 720. - Comcast Help and Support Forums
forums.xfinity.com/t5/XfinityTV-and.../How...1080...720/.../1152741
Jan 3, 2012 - I can switch one of them from one HDMI input to the other HDMI ... The YPbPr option might be set at 720p, and you can change that to 1080i.
How do I change the resolution on my LG tv to 1080p ? - Nvidia ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Apr 20, 2012 - 7 posts - ‎4 authors
Hello, I have recently bout a new LG tv, and I use a HDMI cable with my sky HD box, but ... only shows 1080i resolution, and i cannot find where to change it to 1080p. ...Forum; Optimizing blu-ray settings for 720p Plasma tv? 1080p TV outputs 1080i from desktop - Radeon ...
May 24, 2012
Bravia Full HD won't show pc via HDMI on 1080p but ...
Oct 30, 2011
More results from www.tomshardware.com
Change it: Your Comcast/Motorola HD Cable Box may be ...
www.darrowart.com/.../change-it-your-comcastmotorola-hd-cable-box-...
Oct 20, 2012 - Change it: Your Comcast/Motorola HD Cable Box may be outputting ...they set it to output a 720p signal via the HDMI out to my 1080p-capable ...
How To Change your PS3 from 720 to 1080p - YouTube
Jan 03, 2016 | Televison & Video
HDMI port not sending signal to TV from laptop
check with different hdmi monitor or check the tv with another hdmi device
Jul 16, 2017 | Acer Computers & Internet
How to adjust TV for best picture
first reset your tv if you made some changes ,select dynamique mode bring down the backlighting 8 or 7 bring down colore a bit put hdmi black level to low , also your tv needs to be well connected are you using hdmi cables ? you must also to have good quality image configure your hd decoder (bell shaw ext ) in general the only configuration necessary in a decoder is to select the proper resolution for your tv .exp your tv is a 720 p or 1080 i you must select the same resolution in your decoder
Oct 13, 2011 | Samsung PN42A450 Plasma TV
I can't get a signal between my Sony Blu-Ray Disc/DVD Player and Samsung HDTV monitor. They are connected via a HDMI cable. A brief message on the HDTV reads "Not supported".
First, try to reset resolution of HDMI Sony BD output.
Unplug HDMI cable from TV and change to Component connection to reset BD output resolution.
Than after you entered to resolution menu, choose to standart resolution 720 or 480 i.
If above methode working, try to reconect HDMI cable again to HD TV.
If any problem with picture or still "Not Supported" messege appear, i suggest to change HDMI cable first.
i hope its work.
Mar 14, 2011 | Televison & Video
Cant get the tv to go from 720 to 1080
Changing the resolution of 720 to 1080 is dependent of the input television. Make sure the HDMI cable connection or a PC cable connected properly.
If you uses a PC input, you should set the resolution with 720 to 1024 first. then set to higher resolution. If there is a problem when doing settings dark picture or not support, it means that the TV does not support the resolution.
Perform way above the HDMI connection too.
Hope this helped solve your problem.
Mar 12, 2011 | Samsung Televison & Video
How can I switch my screen resolution on the Pioneer PDP-4270 from 480i to 720i or 1080i? HDMI cable is connected appropriately. I have tried new HDMI cables, and pressing reset to factory settings along...
Change the resolution on the cable box or satellite box, witch ever you have. A set by itself cannot change the resolution, if the cable is giving you 720p, that's what you'll see for that station. All stations do not transmit in HD. The best picture is only as good as they're giving you.
Dec 19, 2010 | Pioneer PDP-4270HD 42 in. Plasma...
I do not know how to work the display resolution
The tv display resolution will automatically change depends on your source/device output resolution and TV inputs used as well. Television component and HDMI inputs accept 480i up to 1080p signal while composite and s-video accepts 480i(lowest resolution) signals only. You will get high resolution signals from cablebox, game consoles, bluray etc through their component or HDMI output jacks.
Dec 25, 2009 | Sanyo DP50747 50 in. Plasma TV
Can not get HDMI to work on PLAYSTION 3 on my Philips 42' Plasma
I had the same thing with my PS3 on a samsung 40". Try pressing the power button down on the PS3 for 5 secs or more, until it beeps (Not sure if it's one beep or a series of). I think this is how you reset the system and it should automatically recognise and reset the resolution size to HD on you're screen. Hope this helps,
Andy.
Jan 21, 2009 | Sony Playstation 3 (PS3) Console
Televison & Video Logo
91 people viewed this question
Top Televison & Video Experts
