Question about Lexmark X85 All-In-One InkJet Printer
Lexmark X85 Printer
Printer want print. Paper feeds to its first stop but fails to feed any farther. The printer goes thru the complete cycle but fails to pull the paper thru.
  • Anonymous Jan 02, 2009
    same as above
  • Anonymous Apr 13, 2009
    Paper stops at 1st stop and doesn't move. Printer sounds like printing, but nothing on paper.
I tried cleaning the rollers off with lens-cloth & paint thinner & got TONS of ink off the rollers, still same problem thoough, but very slight improvement.
Posted on Oct 26, 2008
I have a lexmark x85 printer that is misbehaving. Weather I try to copy or print from the computer,t will not feed properly. The unit feeds about half way and then the printer heads start to move as if it...
You simply need to find a way to clean the inside of the printer, especially the rollers of dust. I will explain.
This is sort of scenario is usually caused by dust inside the printer. Dust has a way of preventing the sensors from detecting paper. Also it prevents the rollers from having a firm grip on the paper while picking paper. Sometime one side grips well and tries to pick the paper while the other doesn't resulting in a jammed. I will suggest you get a long handle brush and try to reach as far inside the printer as possible and brush (from the back and front). If you have a blower you may also use it to blow well into the interior of the printer (If you do not have a blower the brushing will still do if you do it well.) This, if properly done should do it. Brush especially the rollers etc.
Jul 30, 2011 | Lexmark X85 All-In-One InkJet Printer
Lexmark X85 won't feed paper. When trying to
There could be something in the paper feeder that's blocking the paper path. Please follow steps below to identify and fix the problem:
1. Remove the sheets of paper from the feeder.
2. Grab a flashlight and look inside for any debris.
3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
4. If feeder is clear, place the printer back on the table, open the printer cover and remove the cartridges.
5. Check the cartridge area for any obstructions/debris that could cause this error or problem.
6. If cartridge area is clear, close the cover.
7. Unplug and re-plug the printer into the power outlet to reset it.
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again.
ns Serif"'>6. When the printer turns on, reinsert one cartridge first.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge.
Jul 11, 2011 | Lexmark X85 All-In-One InkJet Printer
Lexmark printer x85 all in one
It needs a thorough cleaning inside, and a lube job as all of the lubrication has dried up. Call around but this type of a maintenance is usually about $25.00. J.
Aug 01, 2010 | Lexmark X85 All-In-One InkJet Printer
Paper wont feed thru the printer
hi!! in that kind case my troubleshoot of that is the feed mechanism was defective and try to bring that in your nearest lexmark service center.
May 15, 2009 | Lexmark Z42 InkJet Printer
Lexmark x85 paper jams
I have owned several X73, X83, and X85 printers. Most of them end their life in the way that you are describing your problem. They will start by feeding the paper thru the primary load but will not feed the paper thru to be printed on and out the paper exit.
First and foremost, I advise you to unplug the printer, remove the flip top cover and turn the printer upside down and shake. I have seen items in the paper path such as a penny cause issues like this. Also make sure the paper path is clean and no small tears of paper in the way that could be blocking. If you find something check again, hopefully this is the good solution.
If that does not work, it is most likely that you need the print engine for the unit. Unfortunately this costs about $109 if you can find them (unless they got cheaper since I last checked).
If it makes you feel any better I have one that matches your's on the shelf here :) You can get a new AIO printer for $109 or just a little more.
Mar 22, 2009 | Lexmark X85 All-In-One InkJet Printer
Print Output
Try cleaning the feed rollers. these are the rubber wheels that actually contact the paper and pull it through. If they get dirty, their grip on the paper will be less than adequate. Just use some clean water, or perhaps some rubbing alcohol, and a clean rag to wipe them thoroughly.
Feb 11, 2008 | Lexmark X85 All-In-One InkJet Printer
Lexmark X73 print/paper problem
Same problem here. Went thru a few tests with Lexmark but didnt help. They next said it would be best to get new one since repair cost would be higher. Thru front door I do see a spring that moves freely. That must be broke. After their help they sent email for 20% off.
Sep 12, 2007 | Lexmark X73 All-In-One InkJet Printer
Lexmark Z11 Printer will not work
i am having the same problem and after looking it over, something is not feeding it thru the beginning of the paper starting in. if i pust 1 sheet down far enough to grab the paper it will print one page at a time. I have been unable to determine what is not feeding at the beginning yet.
Oct 03, 2006 | Lexmark JetPrinter Z11 InkJet Color...
Lexmark X85 All-In-One InkJet Printer Logo
352 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
