Rca lyra mc2501 when I connect the usb cable it just flashes usb connected but will not connect what can I do?
  • Anonymous Jan 03, 2009
    same thing shows as USB connected.
    thinking that possibly the time not being used has been too long, and battery is not keeping it's charge.
    this am, the mentioned display showed, but this afternoon it let me press the button to permit charging of battery ? after the unit was re-connected to USB.
    Took unit apart to look inside, lithium battery AE402535P 3.7v 280mAh.
  • Anonymous Feb 02, 2009
    sono in vendita le batterie AE402535P?
I have tried this but still have the same problem. Also78 the only way I can charge the player is by restarting the computer wile shutting down I hold down the play button till it says battery charging I do this about 4 or 5 times and the player is charged Once computer is up player starts to flash again. I still cannot add or remove songs but I can play them.
Posted on Aug 29, 2008
Try holding down the play button
I would like to know where I could get a usb cable to connect to the computer and a manual for my RCA Lycra rd1090A?
The cable is a standard USB cable, it's just that there are some peculiar variations on the end that goes into the device. Just take your Lyra to Radio Shack or what have you and make sure to get the right one.
Nov 26, 2010 | RCA Lyra RD1090 MP3 Player
MY RCA LYRA MC5102A IS NOT WORKING RIGHT!
go to the thompson.com website and download the new software for your player..
Mar 26, 2009 | RCA Lyra RD2765 MP3 Player
Wont connect to pc
Try a new/different USB cable. My Lyra was a painful thing with cables. Also, make sure the plug and receptacle are clean. Improper connection can do this.
Also, you should have gotten a driver CD for the player. It contains the correct drivers for the lyra, and will help Windows XP use the correct USB drivers.
Try those and see what happens. It may just be corrupted USB drivers.
Hope it helps bud!
Sep 21, 2008 | RCA Lyra M2030 MP3 Player
RCA Lyra MC5102A
connect lyra to computer
go to my computer on your start menu
lyra will show up on other devices or portable devices
double click on the lyra icon
this will bring up another lyra icon right click on that
go down to the option format and select that
you will lose all of your music
solved my problem two hours after it started
Aug 31, 2007 | RCA Lyra RD2765 MP3 Player
Downloading
connect it to PC and then open Windows Explorer and search for the drive letter that Windows automatically assigned to be your Lyra player. Click on that and look for any folders. Open the song folder (if exists) and then mouse drag your pc song files into this folder. Disconnect USB cable and your songs should be on the LYRA.
Aug 05, 2007 | RCA Lyra RD1021 MP3 Player
How does this work?
When the unit is connected to the computer, ?USB Connected? will be displayed on the screen. During transfer, ?USB Transfer ...? flashes on the display. When the transfer is complete, the display will change to "USB Connected". Do not unplug the USB cable when the display is flashing. Also, check to see if the mp3 file(s) you're transferring is between 32 to 320 kbps. You may need to reinstall the USB driver for this device. Good luck.
Jun 23, 2007 | RCA Lyra RD1072 MP3 Player
My rca lyra rd1080b
this is the best solution you have update your lyra rd 1080/rd 1090 for download the updating click her http://download.rca.com/download/RD1080_90FWUpgrade_v4.26.exe and after instaling this update follwo instructions provided below ? To update your Lyra RD1080/RD1090, make sure you have it connected to the computer via the included USB cable. You will need to make sure that no external memory has been inserted and the Lyra RD1080/RD1090 display reads: "USB Connected Int. Mem". (If it does not, please refer to the users guide for the section on how to switch between internal and external memory.) ? Once connected, locate and run the Lyra Systems File Update Utility if it didn't open automatically. Installshield Wizard will have automatically created this icon on your desktop as well as under "Programs", "Lyra Personal Audio Player", "RD1080/RD1090" in your START menu. ? Click the "Refresh" button until the RD1080/RD1090 player shows up under device. ? Once displayed, highlight the drive letter by clicking on it, and click the "Update SYstem Files" button. ? When successfully completed, you will see the message, "The Lyra Personal Audio Player Device system files were successfully updated." ? Click the "OK" button, and then "Done". This will close the Lyra Systems File Update Utility. ? Disconnect the Lyra RD1080/RD1090 from the USB cable, turn the unit off and back on.
Apr 22, 2007 | RCA Lyra RD1080 MP3 Player
My mp3 does not connect to my computer
Try this link - they have udated drivers for your player, which hopefully will solve the problem; http://www.rcaaudiovideo.com/en-US/Downloads.html?ProductID=RD1070 Try a different cable also, and check by plugging it into a usb port on another computer that the problem is not with your usb ports. Hope this helps :)
Mar 22, 2007 | RCA Lyra RD1072 MP3 Player
222 people viewed this question
 Grubhead
Grubhead
