Question about Harman Kardon HK19.5 Computer Speakers
Constant poping sound
When you turn the speakers on there is this continuous popping noise. you can here audio from whatever your doing but that popping noise is always there. I'd also like to know the parts list for these speakers. I need new power/volume and treble adjusters
  • 2,794 Answers
Here is the support section for Harmon Kardon
I don't know if there supported anymore but you might be able to find what youre looking for on EBay. You could try plugging the speakers into a seperate outlet and see if the noise is caused by electrical interferance. Make sure your microphone is muted if your not using it. It might be time for a new pair of speakers too.
Posted on Jul 23, 2008
I have two jl audio 12 w6v2 running with a jl audio 1000/1 and at high volume they make a poping noise does any one know y
That popping noise is your speaker telling you to turn it down, and that your amp is too powerful for your setup. The speaker cone is moving beyond its limits of excursion and on it's way to malfunction/blown. Basically the voice coil will fry.
Mar 16, 2010 | Jl Audio 12W7 Car Subwoofer
Cracking and poping with Yamaha surround sound system
Try put a ground line from any metal of your stuff to the any metal direct to the ground. these eliminate noise of the speaker.
Jan 03, 2008 | Pioneer VSX-54TX Receiver
Makes a poping noise out of the speakers when i turn it on? can ya help plz thnks james
If you have no video and its making a popping noise its mostlikely shorted convergence circuits. Contact www.TvRepairKits.com and ask them to make you a kit for chirping sets.
May 16, 2009 | JVC AV-48WP30 48" Rear Projection...
Onkyo digital reciever has poping noise when in dolby sound
I have the same reciever, and had the same problem.  Contact Onkyo, this is a known issue where defective DSP chips were used and manifest problems with a popping / clicking sound when using surround settings.  These receivers also have a Dolby Digital input issue that can cause audio dropouts when watching cable or SAT broadcasts that encode DD using a 'newer' broadcast encoding methods.  Onkyo is covering the cost of that repair for me now, even though the receiver is 5 years old now....
Jan 02, 2009 | Onkyo TX-DS797 Receiver
Speakers making a constant poping noise.
this could be due to some static  please get your electrical point checked up 1st  is your tv hooked to watch television thru RF or AV please have the interlink cables if this does not help get back with more details
Oct 15, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
My tv is making a poping noise. I unpluged the set from the radio but the sound is coming from the speakers on the unit. What is it, and how can it be fixed. Thank you Bryce,
Turn down bass in audio menu or if tv has subwoofer turn down sub level or like i stated earlier turn down bass other than that popping noise is a common complaint with vizio, if under warranty call service provider
c
Sep 29, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Popping & cracking noises
Is the popping noise coming from the speakers? If it is, lowering the volume to zero does not stop the popping from the speakers, then you have an audio output failure. If the sound is not from the speakers, you probably have a high voltage leak. If this is the case, are you in a moist environment or using the set near a window??
Mar 01, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
YAMAHA HTR 5660 MAKES POPING SOUND WITH LOUD NOISE AND BRIGHT LIGHT
Looks like you've got the best connection available - initially I thought it might have something to do with decoding the prologic signal from the analog input, but obviously not! And since you've got the audio separate from the video it is unlikely there is any interference from the video signal in the cable. Have you tried a different DVD player (I reckon that is most likely)? Also try connecting the video signal DIRECTLY from DVD to the TV if you aren't already doing so (you are anyway aren't you - the HTR 5660 doesn't have HDMI out does it?) Finally, if you have some spare cables around, try changing them - see if you get the same response when using component video cable instead of HDMI.
Jan 26, 2008 | Yamaha HTR-5660 Receiver
Das TV make cracking and poping noise when you unhook it from receiver?
Sep 30, 2007 | Sony STR-DE197 Receiver
Popping noise
If the popping sound is NOT coming through the speakers, you probably have high voltage arcing. Probably close to the high voltage (flyback) transformer. If this is the case then other parts could be damaged if allowed to continue. If the popping is coming through the speakers then you could have a problem any where in the signal circuits. Like a loose connection. You'd need to have it checked out to find the problem.
Feb 27, 2007 | Sanyo AVM-3680G 36" TV
Harman Kardon HK19.5 Computer Speakers Logo
397 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
