Question about Samsung ML 2010 Laser Printer
Unable to print
I've succesfully reinstalled this printer and drivers and the LPT1 port is functioning properly (per Device Manager) however it will not print.
I tried printing a "Test Page" and that does not work, however, if I physically depress the Cancel button, the test page will print.
Also, I tried printing from the Command Prompt per the Troubleshooting Guide, also, with no luck~~~
Any ideas?
Thanks
CW
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Hmmm..well..sounds like drivers went in badly. if it's still an issue try this link.
http://tinyurl.com/6qcpgy
Posted on Aug 18, 2008
Dead LPT1 port
You have checked everything. At from between 3 to 20 dollars though, I would just get another LPT card. You dont have to install anything in form of programs.
Mar 17, 2014 | IBM Computers & Internet
Tip
General Printer Troubleshooting: Make sure the printer has power and is ...
<b>General Printer Troubleshooting:</b> <ul> <li>Make sure the printer has power and is on-line. If you are using a manual printer sharing device, make sure the switch is set to activate the correct printer.</li> <li>Turn it off and on again to reinitialize any internal settings that may have gone astray.</li> <li>Ensure that the tape that seals the cartridge ink port is removed prior to installing the cartridge.</li> <li>Use the printer's own self-test, according to the manufacturer's recommendation. If it fails, you have verified that the problem is within the printer. If the print head is not moving at all, the transport motor may have failed.</li> <li>If the printer that you are using is not set as the default printer in Windows or the printer driver is not installed, the printer may print garbled characters. You may also receive errors when you attempt to print from applications.</li> <li>If the printer passes the self-test, try a test print using the Print Screen capability within DOS. If the Print Screen fails, you know the problem is in the relationship between the printer and the computer. Inspect the cable and the cable connections. Replacing the cable with a known good cable is worth trying since cables are so frequently the source of printer problems. Cables can fail with broken wires, loose or broken pins, or incorrect pin-outs.</li> <li>If the printer is connected to the computer through an add-in device, remove the add-in device and connect the parallel cable to the printer and then directly to the port on the back of the computer. Some examples of add-in devices are: switchboxes, parallel port scanners, external disk drives, external tape drives, security lock keys, or external CD-ROM drives. Some add-in devices may interfere with proper communications with the printer. Try printing again. If the printer prints successfully, the cable may not have been connected properly, or the add-in device may have been interrupting communication with the printer.</li> <li>If the combined length of the cables connecting the add-in device and the printer exceeds 10 feet, communication can also be disrupted. In addition, the software that controls some add-in devices may take control of the printer port interfering with any other device attempting to use the same port. In some cases, the software for the add-in device should be disabled or uninstalled. Remove any add-in devices and uninstall the software for those devices, then try printing again.</li> <li>The message "out of paper" is sometimes erroneously reported when there is plenty of paper, and can indicate a physical problem with the printer.</li> <li>If the printer port is not properly identified in CMOS, the printer may not function properly and you may receive errors when trying to print. Check your User's Guide on how to enter CMOS. Once in the Setup utility, locate the LPT1 settings. The address setting for the LPT1 port should be 3BCh or 378h depending on what kind of video card you have. The IRQ setting for the port should be 7 and LPT1 should be enabled in order for the printer to print correctly.</li></ul>
on Mar 31, 2011 | Office Equipment & Supplies
Dear SIR\r\nRECENTLY RECOVERED MY COMPUTOR unable to connect to printer cn you advise Thank you
Check and make sure you can see the Parallel Port Card you have installed. Go to Start - Control Panel - Administrative Tools - Computer Management and on the left hand side click on Device Manager. Check under Ports (COM & LPT) and see if you have more than your Printer Port (LPT1) installed. If you do not, reinstall the device drive for your SYBA SDPEXNM2P PCIe 2x Parallel Port Card. If you do have more than one listed, check the printer in Control Panel - Printers and Faxes and make sure the printer is enabled. Let me know what you find.
Jul 07, 2011 | SYBA SDPEXNM2P PCIe 2x Port...
I have a citizen prolaser 6000 laser printer, it emulates HP Laserjet 3, I want to connect it to my laptop via a usb interface cable, currently it is connected to the printer port of a desktop (lpt1 for...
There is three things that you will need:
Proper port set up on laptop device manager (Check settings) LPT1 is for a parallel port - Need USB Correct Driver for the Citizen 6000 Pro Laser (Windows should auto install) Hub that will communicate via USB to the IEEE 1284 Printer via cable.
Driver Site: http://www.driverfiles.net/Printers/Citizen/Prolaser-6000-Printer-Driver/download/page,sh,38839,389,12,.html
I hate to suggest, but you may have to call Microsoft Citizen Tech Support for suggestions on the Hub that will communicate via USB properly. Check your manual for setup options.
TF
Jun 02, 2011 | Office Equipment & Supplies
HP3600 USB printer works but won't print on my HP7058 Laptop
Try removing all ports from your laptop, then reboot, and then create just one USB port. Also, go to your hardware devices and make sure your usb ports don't have any question marks or yellow warning symbols. Be sure first that the drivers for your USB ports are installed and working first. This sounds either a faulty USB cord, which does happen, or USB drivers issues in your laptop. The printer is probably not the problem here.
Feb 17, 2010 | HP LaserJet 3600n Printer
XP Cannot able to print on Epson LX 300+
This is XP's parallel port problem
try changing the settings:
find: Start Button, Control panel, System
Device Manager, then Ports !
Change the settings for LPT1 to enable
Detection of Legacy Plug and Play devices
o and Here is the service manual for this printer:
http://ca.geocities.com/artiedc/LX300SvcMan.pdf
Ed
May 25, 2009 | Epson LX-300 Matrix Printer
Epson Stylus CX9400 driver settings
Not sure how you're removing the driver, but if you go to control panel device manager remove the printer totally as an option; reboot and then reload the printer. You also need to identify the remote printer in the print sequence or as your default printer in set-up (device manager). Hope this helps.
Jan 14, 2009 | Epson Stylus CX9400 Photo Printer
Samsung ML-4500 with IEEE 1284 to usb cable not working
Windows XP/VISTA (do not install the CD)
1) Plug the cable into the USB port on your computer.
2) A prompt that says "Found New Hardware" will appear. Windows will then install the USB printing support driver automatically. You do not need to install the driver from the CD.
3) Plug the cable into the printer.
4) If your printer is already installed, click on Start, then Printers & Faxes. Right click on the printer you are connecting to and click on Properties. Click on the Ports tab and check the ‘Virtual printer port for USB’ port. Click OK.
5) You should now be able to print.
With XP, the biggest clue is to FIRST plug the cable into the usb slot, THEN the other end of the cable into the printer.
May 14, 2008 | Computers & Internet
Lexmark 1200
Also, check your port settings in Windows' Device Manager. Right-click My Computer on your Desktop (or click System from the Windows Control Panel), click Properties, and select the Device Manager tab. Click the plus sign (+) to expand the Ports menu item and view Properties for your Printer Port (LPT1). Verify that the port is working properly and it is enabled, and that you have the appropriate drivers installed. USB (Universal Serial Bus) printer cables can also come loose, and they often conflict with other devices. Remove any USB peripherals and try again. Next, check your printer status by right-clicking its name in the Printer window. Is it online? Is it your default printer? If another printer (or even a printing program, such as a virtual fax printer or Adobe Acrobat distiller) has taken over the default role, you may be printing to the wrong place without realizing it.
Mar 01, 2008 | Lexmark X1240 All-In-One InkJet Printer
Printer not printing from computer
Hello:
To resolve this situation try the following:
1) re-install a driver. Goto HP.com and download a anew driver. COmpletly uninstall the old one.
2) Force your deskjet to run a self test...disconnect the cable from the PC...power off the unit...hold down the print button...turn unit back on.
3) try a new cable
4) Download a manual here
I hope you are up and printing soon.
Good luck to you my friend,
Seek PC Repair
Feb 10, 2008 | Compaq Presario 5000 PC Desktop
Samsung ML 2010 Laser Printer Logo
62 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
