Microsoft Excel for PC Logo
Posted on Jul 23, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cycle Problems I want to add a cycle in my excel custom userforms to let me add Data to a datasheet, how can I achieve this?
  • Kcas11 Jul 28, 2008
    I'm sorry. I mean a Loop, any kind of loop that will help me save, modify or delete data.
  • Tim Babcock
    Tim Babcock May 11, 2010
    Can you elaborate on what you mean by cycle?
Tim Babcock
Level 3:
  • Microsoft Master 2,794 Answers
  • Posted on Jul 28, 2008
Tim Babcock
Microsoft Master
Level 3:
Answers
2794
Questions
13
Helped
1127717
Points
7249
You can specifiy a range of cells to put whatever you want to in them simply by highlighting the range of cells and formating the area as to what is supposed to be done with them.
2answers
Need gas and oil mixture for 25 cc ut 08083 blower
Two-cycle engines use a mixture of oil and fuel to power and lubricate the engine. Homelite blower engines use a ratio of 50 parts gasoline to 1 part two-cycle engine oil. Two-cycle engine oil is commonly sold in 2.6-ounce containers; add it to 1 gallon of gas to achieve the 50:1 ratio. Two-cycle engine oil for outboard motors is not compatible with Homelite blowers.Use premium fuel,the blower,weedeater,etc. will last much longer!
Oct 31, 2015 • Garden
Drive cycle for 2000 toyota tundra
Drive Cycles are only in factory service manuals,
few people buy & in the repair shops data bases
No vehicle owner needs to be involved with that.
It is a function of the repair shop to know if a drive
cycle is even needed, before any repairs are performed
Apparently shops do not road test & confirm there work &
blow off the customer with telling them to drive in a certain manner,where it appears from what I see on this site that the shops fail to even make the correct repairs if any as I seldom
see the questions where work was done & even need a drive
cycle
You going to have to use Google & the codes or problems
to find out if drive cycles or scanner relearns are nec
2answers
I have a Black and Dekker all-in-one Breadmaker B2200. The manual has very few recipes so I often use the recipes from my previous Breadmaker B1650. It had an Add Ingredients alert (to let you add nuts...
NO, it;s better to wait until kneading has started. If it has a second kneading add then. If not, add in a few minutes after ingredients have started mixing. Just lift the lid and drop them in as it mixes.
2answers
Minimize Data Entry
I will suggest you to create small application in .net for ths which will add some value and process your data;If you want to use Excel only make a master sheet with details and use it in other excel sheets
Maytag Neptune MAH4000
Are you getting cold water to fill ?How is the water pressure?Timer maybe at fault here.
180helpful
15answers
Export tally data to excel format
Select ASCII. Give output file name Eg:d:/exp Open the file using EXcel.Select Delimite  nexxt comma finish.Export is completed
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
