Question about Hobart A200 Stand Mixer
Hobart 20 quart mixer
Hey bigg t,
I just had my mom's hobart shipped cross country, and when I opened the crate the motor was packed up-side-down..(I know-don't ask).... There is a little grease dripping from the transmission stick(1 drip). How worried should I be. I don't have an account on fixya yet as I just did a quick search and found this post. My e-mail is thomas.bonacci@yahoo.com.
Thanks for your help.
Tom
  • Tom Jul 25, 2008
    I figured as much, but pro advice never hurts. Do these machines use the same mineral oil lube as the smaller kitchen aid mixers? Thanks again. T
  • 640 Answers
Hey tom dont worry about it.These mixers hold a decent amount of grease.If you need any other info let me know.
Posted on Jul 24, 2008
  • anthony james
    anthony james Jul 28, 2008
    No,they use a grease if the unit is newer if an older unit they use oil but it doesnt matter.If you call your local hobart branch they can give you the part number.
How to change oil in 20 quart hobart mixer and the type of oil
on a a200 there is no oil. this mixer requiers grease. if mixer is leaking oil it is because the grease is broken down .you have to pull tpo cover off mixer remove trans. parts clean out old grease clean all trans. parts reassemble put top cover back on .then make sure mixer runs in all 3-speeds before putting 1.5 cans of -47grease back in grease can be bought @any hobart office
Dec 20, 2009 | Hobart H600 Stand Mixer
How can i tell the which size my mixer is?
A 200 means 20 quart. I assume you have no bowl or else you can just measure the volume of the bowl.
Nov 29, 2009 | Hobart A200 Stand Mixer
Small screw and nut?
By turning the screw cw or ccw it adjusts the clearance on the worm shaft assembely,in other words if the mixer is noisy by adjusting this screw you can quiet it down.
Mar 30, 2009 | Hobart A200 Stand Mixer
Hobart A120 mixer bogging down
Hi. If the motor does not turn, the problem is electrical. Trace and test the electrical circuitry with the mixer unplugged. Start with the electrical plug and work your way through to the motor and switch connections. An electric motor technician should be called in if you are not familiar with electrical troubleshooting techniques. Good luck!.
If this solution has assisted you, please rate it. ricardok45
Mar 23, 2009 | Hobart Food Mixers
I need the manual for the Hobart 20 Quart Mixer A200T
Hobart doesn't release their service manuals to the general public,however i'm a hobart tech and repair these mixer's often.If you need any help let me know.
Mar 05, 2009 | Hobart A200 Stand Mixer
New bowl & hook hobart d300
There is a website called onesharpstore.com, It carries parts for the hobart 30 quart mixer. I specifically saw the bowl and hook attachments as well as others like beaters and a cheese and vegetable grater. Hope this helps. And if you sign up I think you can even request a full catalog for your machine.
Feb 25, 2009 | Hobart D300 Stand Mixer
Hobart mixer 30 quart
this is an extremly difficult mixer to take apart if you are not tech minded do not attempt this
Nov 29, 2008 | Hobart A200 Stand Mixer
Hi im a service tech for hobart.I cant give service manuals out because i could lose my job but i can step you thru your problem with the mixer,let me know.
Aug 21, 2008 | Hobart A200 Stand Mixer
Hobart 60 quart mixer
the motor protection board is doing its job.you should only use 1st speed to mix pizza dough.im a hobart technician and service these mixers all the time.let me know
Jan 27, 2008 | Hobart D340-6007 Mixer
Hobart A200 Stand Mixer Logo
203 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
