My hvac duct work on one of my central air units has a lot of condensation and causing puddles of water throughout my basement. Do you know what the problem is? The drain lines don't seem to have any leaks. There is condensation at the main supply unit of the HVAC system (gas forced air system). Can anyone help understand what the problem is and how to fix it?
  • 41 Answers
Could be just not insulated enough is this a new instalation? the humidity is too high around the ducts is their a return air vant close by that you can open? you need to lower the humidity or seal the ducts so it cant get to them dan
Posted on Jul 23, 2008
Condensation dripping from ceiling in all electric home with no basement
The wall of the daughter's bedroom is NOT insulated. Moisture from normal activities (showering and cooking) within the house are causing the realtive humidity to be above 50%. When that moisture enters the wall or ceiling, the temperature drops below the dewpoint and condenses out. The moisture that condenses makes a nice environment for the growth of black mold which is highly toxic. The mold will spread by airborne spores. If you have return air ducts for your HVAC system in the room, the spores might be dispersed throughout the entire house, depending on how good you HVAC filter is. Note that if you have a swamp cooler on the roof, it could be leaking water through the ceiling and causing the problem.
You need to immediately move you daughter to another room and remediate the situation -- tear out all the drywall and anything that is damp or has signs of visible mold. Get the humidity in ther house below 50% with a dehumidifier. I would recommend the Winix 50-pint model (refer to link below). This will condition 1500 square feet, which is a lot, but you will need one on each floor.
Amazon com Home Kitchen
Jan 29, 2014 | Kirby Shampooer Shampoo Hose G3 Ultimate...
Our central AC has severe leaking ( condensation)...what to do ?
Every airconditioner will create condensation that needs to drain. Your condensation is not going where it is supposed to, probably because the drain is plugged. Find the cooling coils (they might be in the basement, but are probably in the attic) they will be right next to the fan. There will be a pan or tray under the coils and there will be some kind of small diameter pipe or hose that should go to a sewer inlet, or might possibly go outside. You might possibly have a small collecting tank with a pump that will be operated by a float switch. Lots of possiblities, but it is likely going to be obvious once you find the drain hose.
Good luck.
Jun 06, 2012 | Heating & Cooling
I have a Ruud Model UBHC-17J11NFD in my basement. Water is coming from the bottom of unit and pooling onto the basement floor. What should I check first?
Hello, most likely you have a clogged condensate line, in order to clean it you will need a wet/ dry vac and attach it to the outlet of the line and the suction pressure should dislodge the clog. Also, if the unit uses a condensate pump make sure it is working, if its not it can cause water to pour out onto the floor.
Aug 09, 2011 | Ruud UBHC Air Conditioner
Eddfx24fa2 model # on furnace of central air unit in my basement I am trying to calculate wattage of this central air unit On compressor outside: 220 volts, 60 amps??? Does amps sound correct? amps x...
It is a two ton system. and without doing a heat load Calculation and not knowing the heat load It would not be anything but a guess. But if everything is working properly and the system is clean and with good duct work, than it should be big enough for the size of your house.
Jun 06, 2011 | Airtemp B6Y12F2A Air Conditioner
I have a 4 ton Ruud HVAC system that is two years old. It is a 13 SEER unit. It is tilted slightly to the front of the evaporator to aid in draining the condensate. Two days ago, my daughter came home...
If the condensate drain is clogged, water will stay in the condensate pan located below the evaporator.
As the water builds it most certinly will be picked up by the blower and travel through the duct work.
Jul 03, 2010 | Ruud UBHC Air Conditioner
Puddle of water in the dryer
The water comes from condensation inside the dryer ducting and drum. Heavy condensation can occur when the dryer exhaust ducting becomes clogged.
As your dryer runs, it exhausts warm moist air from your clothing. If lint becomes trapped inside the ducting, or if the ducting is kinked, this moisture has no where to go, but condensate inside the walls of the ducting and/or drum. If lint becomes accumulated it can act as a sponge and absorb this moisture.
The following link explains some common causes and potential problems you may encounter:
Read through the link provided and let me know if you have additional questions. I hope this can help you.
Jun 11, 2010 | Maytag PYE2300AY Electric Dryer
Unit in basement leaking around bottom
The drain line coming from the internal drain pan to the pump is clogged, causing overflow of the internal pan. That means the water never reaches the pump, and is simply overflowing into the bottom of the unit/duct.
The drain line and pan need to be cleaned and cleared.
A shop vac is a wonderful tool for such a job.
Sep 23, 2009 | Whirlwind FH-778 Air Conditioner
Leaking central a/c unit
All central A/C units have a condensate drain line that comes from just under the evaporator in the Main air supply plenum.
You may have a blockage in that drain line and will have to remove the pipe to clear the obstruction. Try flushing the drain pipe with warm water until it flows easily from the top to the end.
You might have a gravity drain that goes into a floor drain or a french drain along the basement walls. The other typical drain installation is a condensate pump that the water drains into and when the float in the tank is lifted, a small pump turns on and pumps the water (condensate) out of the house either thru a drain hose thru the wall, or into a drain in the basement, etc.
Check the entire drain line and anything connected to it for any possible obstructions and/or blockage.
If you have any other questions once you take a look at your installation, just add a comment and I'll check back within a day to provide more info, based on your input.
I hope you found this very helpful and best regards!
Aug 06, 2009 | Whirlwind FH-778 Air Conditioner
Heating & Cooling Logo
122 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
