Question about Meade DS-2114 ATS (325 x 114mm) Telescope
Azmouth axle (lower mounting) broken off base
I would like to repair the base of my DS-2114 mount! The verticle shaft of the AZ mount has fractured. I am proposing the use of a metal filled epoxy and a long 3/8-24 bolt to hold the casting together. I then propose drilling and threading four holes through the bottom of the casting and into the verticle shaft as a perminent fix.
Has anyone had this same problem with a 2114 base?
Thanks,
Fred
    Problem Solver:
  • 5 Answers
I have done this on another DS mounting as a deliberate modification. In your case I would see if I could get a replacment as it might cost less assuming your time is worth anything. In my case I made a modification and I cut the casting web which I suspect is what broke on yours. Either you had it knocked over or you trie to mount too much weight??? Anyway since yours is a break the precision of the repaire would be in question so geting a repair part would be my first inquiry. Otherwise your fix will be similiar to my modification which was successful!
Best,
Rick
Posted on Aug 22, 2008
How do you replace the alternator
The generator is located above the oil filter and axle shaft.
1. Disconnect the negative battery cable.
2. Remove the 2 bolts from the top of the heat shield on the generator.
3. Remove nut from the upper T-bolt adjustment bracket.
4. Raise vehicle and support.
5. Remove the right front wheel.
6. Remove the accessory drive splash shield.
7. Remove the lower heat shield bolt.
8. Remove the generator heat shield.
9. Unplug the field circuit from the generator.
10. Remove the B+ terminal nut and wire.
11. Loosen the accessory drive belt t-bolt.
12. Remove the pencil strut.
13. Loosen the lower generator pivot bolt.
14. Remove the generator belt, refer to the Cooling section for more information.
15. Remove the axle retaining nut.
16. Remove the lower control arm from the steering knuckle.
17. Remove the 2 bolts for the axle shaft bearing support.
18. Remove the axle shaft assembly. Put a container under the transmission to catch the transmission fluid from the transmission.
19. Remove the generator from the lower mounting bracket and set generator to the side.
20 . Remove the lower mounting bracket for the generator.
21. Remove generator through the axle shaft hole.
Jul 29, 2013 | 2006 Chrysler PT Cruiser
How do you the replace alternator
Jul 28, 2013 | 2006 Chrysler PT Cruiser
When your take off fast,it makes a loud clanking noise. At easy take off it doesn't make the noise.
You did not mention the year and model which would help to choose a prime suspect, but all I can tell you for sure that is that something is broken that secures part of the drive train. Could be motor mount, transmission mount, guibo in drive shaft, rear axle mount. Could possibly be a shock mount or the sheet metal where the shock mounts attach to the body on an early e46.
The good news is that unless it is the sheet metal around a shock mount, it is most likely an inexpensive repair.
Sep 01, 2011 | BMW X5 Series Cars & Trucks
The 360 rotation motor runs (Motor can be heard rinning) But the scope wont rotate. As the product is out of waranty, is it a problem that I could fix my self, as i'm pretty handy with a screw driver...
You can send this into Meade for repairs.
http://www.meade.com/support/index.html
Or you can disassemble the base and look inside. I suspect you have either a loose or broken worm gear inside the base. There are manuals available on the Meade web site but they do not give any disassembly instructions. Call Meade at the phone number above or try taking apart the base and look inside. Only Meade will have replacement parts.
Apr 29, 2011 | Meade DS-2114 ATS (325 x 114mm) Telescope
Replace left front axle seal
First you'll have to remove the axle shaft, and here's detailed directions so use whatever info you need. First you'll need to jack up your vehicle place your jack just behind the front lower control arm mount. Take off your tire/wheel, remove the cotter pin and the axle nut retainer, remove the 2 caliper mounting bolts, move the caliper out of the way and support it so it doesn't just hang by the brake hose. Now, slide your rotor off, next you'll need to remove the axle nut and at 180ft lbs of torque you'll need a breaker bar or a heavy duty impact. The nut should be a 36mm if I remember correctly. Remove the bolts holding hub to steering knuckle, remove hub now you can tap it with a hammer to help loosen it from splines on axle shaft. take off the dust cover, pull the axle shaft out now, take out your bad oil seal, grease splines, then install new seal, carefully reinstall axle shaft to avoid damaging the seal, reverse steps and you're good to go. Good luck with your repair
Jan 29, 2011 | 1995 Jeep Grand Cherokee
Replace 1997 civic ex alternator
The alternator is removed from the bottom of the vehicle. place the vehicle on jackstands positioned on the body, so the suspension hangs (you'll need this extra clearance to get the alternator past the axle shaft). 1). Disconnect the battery 2.) remove the upper mounting bolt (12mm) 3.) remove the terminal nut from the white wire. (10mm) 4.) Disconnect the 4pin connector 5.) From under the vehicle remove the lower mounting through bolt nut and through bolt (14mm) 6.) Remove the alternator from the lower mount and position the alternator to the side of the lower mount. 7.) remove the two lower mount bolts (14mm) and remove the lower mount asy. 8.) remove the alternator down the axle and out below the wheelwell. its going to be a tight fit so you'll have to turn the alternator at just the right position to get it out.
Jan 09, 2010 | 1997 Honda Civic
Front axle how to remove half shaft
Hi.. The step to remove the front Axles of you Vitara.
Raise and support Vehicle . Remove front wheel,
Drain Diff,fluid,
Remove Locking Hub if is equipaded,
Remove Circle clip from axle shaft
On right side of Vehicle, Remove the Stabilizer Little ball joint nut. Remove castle nut Front Tie rod end,
Remove mounting bolts from brake calipper,
Remove Calipper from steering knuckle and wire a side.
Remove Stud Nut from steering knuckle,
Support Lower suspension arm with a jack,
Remove lower strut bracket bolt ,
Lower jack and disconnect Knuckle from lower suspension crontrol arm,
Pull Outler joint from Hub.
Use Large screwdriver or Prybar To pry Right inner joint from differential, The axle will go out making a little froce with the prybar,
To remove the left side,
Remove mounting bolt from inner joint flange,
Pull out axle from hub.
To reinstall just reverse the prosses.
I hope this help on your job...
Thank you for use fixya....
Aug 18, 2008 | 1999 Suzuki Vitara
Can a shade tree mechanic change the clutch in '97 mitsubishi 3000?
Removal (3000GT AWD)
1. Remove air cleaner cover, air hoses and vacuum pipe. Remove air cleaner, intake hose, battery, battery
tray and washer tank.
2. Disconnect transaxle control cables and speedometer cable. Raise and support vehicle.
3. Remove both inner fender splash shields. Remove clutch tube bracket and disconnect clutch release
cylinder (including clutch damper assembly on FWD models) and wire aside. Support transaxle assembly
with jack and disconnect upper transaxle mount. Remove mount, bracket, plug and stoppers.
4. Remove transaxle assembly upper coupling bolts. Disconnect tie rod ends and lower arm ball joints.
Remove right support member, starter cover (if equipped) and starter.
5. Remove left side bearing bracket mounting bolts and pry left axle shaft from transaxle. Wire left axle
shaft and inner shaft assembly aside. Pry right axle shaft from transaxle and wire aside.
6. Remove front bank side and rear bank side transaxle stays. Support transaxle assembly with a
transmission jack. Remove transaxle assembly lower coupling bolts and lower transaxle from vehicle.
7. Insert a clutch alining tool to prevent pressure plate and clutch disc from falling. Loosen pressure plate
bolts gradually in a crisscross pattern to avoid warping pressure plate flange. Remove pressure plate and
clutch disc.
May 14, 2008 | 1999 Mitsubishi 3000GT
Meade DS-2114 ATS (325 x 114mm) Telescope Logo
93 people viewed this question
Top Meade Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Experi
Level 1 Expert
Greg Cann
Greg Cann
Are you a Meade Optic Expert? Answer questions, earn points and help others
