Question about DFI LANParty UT RDX200 CF-DR Motherboard
Vcore power adapter for the cpu
When I disconnect the 4 pins adapter the computer turns on and the fans,but not video;now when I connect the 4 pins adapter nothing works; I wonder if theres a short circuit.And how can I resolve this problem,the power supply is new I just bought it.Thats the new 4 pins adapter for the Vcore supply,thats what I read. The Mother Board is also new I just bought it with a CPU.The Mother Board is a Chipps M863G
  • 2,794 Answers
Being that it's new it's probably still covered under warranty. Sounds like the motherboard is the suspect.
Posted on Jul 23, 2008
Motherboard Power Problem
Hello Alienware,
Could be a few things.... such as the micro-fuses that have gone on the MB....
But what I dont understand is this:...."Then I disconnect the 4-pin cable that goes from the Power Supply to the motherboard near the CPU and the pc turns on fine"
How????
You have just disconnected the cable from the PSU to the motherboard....it CANT turn on! LOL.
Do you mean that the lights turn on?
Or you hear the HD spin up (if you left it connected to the MB that is)?
Please advise so I can help you more.
Nov 11, 2013 | Biostar P4M80-M4 Motherboard
Error poweredge system R510
Reset bios, test with a different power supply, ensure all cables connected securely to the CPU FAN header, and then conatact DELL support.
Oct 10, 2013 | Dell PE2800 Server
My computer stopped working. I replaced motherboard and power supply. Now the solid amber light is on . The computer sounds like its starting up and the fan turns on. After about 10 seconds the fan gets...
Make sure that you connected all of the required power connectors on to the motherboard. Depending on you motherboard, there might be a 4 pin connector next to the CPU that supplies extra power to the CPU. Also if you have a dedicated video card (not integrated to the motherboard), it may need more power as higher end video cards need direct power from the power supply. Also make sure you have your monitor connected correctly.
With that said, I have a feeling that it is the 4 pin CPU connector since it is easy to miss.
Oct 22, 2012 | Dell Precision 370 (370TREC) PC Desktop
Computer shuts off after 2 mins when case side panel is on
Might be faulty PSU power supply unit
it sounds like a loose connection of some type check the power button connections make sure the soldered wire connections are good and dust free
check cmos battery seating some motherboards cmos batteries are soldered in
it could be a loose or faulty power or data lead check these from motherboard to hard drive also make sure the CPU cental processing unit has a secure dust free seating an has thermal paste
it does sound odd
hope this helps
Jul 04, 2012 | Computers & Internet
I have an Acer AX1700-U3700A and I was working online and stepped away came back and the computer was turned off. I Pressed the power button but nothing turn on .... I have not idea what happened .... Is...
  1. Check your computer is getting power, (reconnect power from outlet)
  2. if power is ok, then open your computer cabinet, disconnect motherboard power (24 pin), then make short Green and Black wires and check power supply fan is working or not, (Switch off computer when disconnecting)
  3. if fan is not working replace power supply (SMPS) and check (working fan means SMPS is ok, but in some occasions Fan may work in defective SMPS )
  4. if the power section is ok you need check you mother board
Thank you...
Please rate me if it is valuable
Aug 28, 2011 | Acer Aspire AX1700-U3793A PC Desktop
I can't get it to turn on ; when I pess the on switch, the blue light does not come on
try pull out the ac adapter and battery. Hold down the power button for 30sec-1min. Reconnect ac adapter and see if you can power back on.
Test your ac adapter to make sure it's not dead. You can get instructions on how to do this on http://www.bootmylaptop.com
Dec 15, 2010 | HP Pavilion a1010n (PS563AA) PC Desktop
We have a desktop computer((Model: GATEWAY 838GM) misplace the ADAPTER for the CPU which one to get please thanks
sallyduby we may have some confusion here.
CPU = Central Processing Unit. Another term used is Microprocessor, or simply Processor for short.
CPU does not refer to a Personal Computer. At least not since the 1960's, and not unless you wish to confuse someone with the wrong reference. ;)
This is Gateway Support > Gateway 838GM Desktop PC > Main Support page,
http://support.gateway.com/s/PC/R/5389/5389nv.shtml
In the list click on Components.
A) There is no adapter device for the CD drive, or DVD drive, unless this is a mistaken reference to the flat ribbon data cable
B) There is no adapter device for the Harddrive, unless this is a mistaken reference to the SATA data cable that connects the SATA harddrive to the motherboard.
C) There IS possibly an adapter for the Keyboard, if you are using a Keyboard with a USB connector on the end of the cable, and are not using the original Keyboard that has a PS/2 connector.
Example;
http://www.directron.com/freeusbps2.html
D) There is no adapter for the Media Card Reader, unless this is a mistaken reference to the data cable that connects the Media Card Reader to the motherboard.
E) There are no adapters for the Ram Memory module/s.
F) There are no adapters for the Modem. The Modem plugs straight into the motherboard.
G) There are no adapters for the Motherboard, unless a USB mouse, or again a USB keyboard, is being used.
The same style of adapter for the USB Keyboard will also work for a USB mouse.
H) There is no adapter for the Power Supply, unless this is a reference to a power cable adapter that could go to a computer case fan, from a 4-pin standard Peripheral power cable.
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
(The 4-pin standard Peripheral power cable, and it's connector, are shown in the middle photo.
The Harddrive example/s shown is an IDE {PATA} harddrive. This style of Harddrive uses a 4-pin standard Peripheral power cable)
I) There is no adapter for the Intel Pentium 4 CPU {Processor} (3.0GHz, 800MHz FSB)
The motherboard has an LGA 775 processor socket.
The Processor has the socket holes, while the processor socket has the pins.
775 socket holes, 775 pins.
http://en.wikipedia.org/wiki/LGA_775
Unless this is a mistaken reference to the Fan/Heatsink combo that sits on top of the CPU.
Typical Fan/Heatsink combo example of Processors (CPU's) using an LGA 775 processor socket,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2943299&CatId=493
(Except the Gateway version is square)
J) No adapter for the Speakers unless I am mistaken.
Post back in a Comment, and give at least a general description of the adapter you are referencing to.
Regards,
joecoolvette
Dec 12, 2010 | Gateway 838GM (RB838GM) PC Desktop
Cpu fan stop few second after starting pc
Hello,have you installed new motherboard or CPU?
Follow these steps again
1) Disconnect the power cord from the back of the computer & open up the case.
2) Wear an anti-static glove or at very least discharge your static by touching a metal surface or power supply
3) Disconnect the main 20pin ATX power connector from the motherboard & the square 4pin ATX2 power connector
4) Remove any PCI cards you have & disconnect ALL drive cabling from the MOTHERBOARD. Also disconnect any internal USB fly leads from the motherboard.
5) You should now have ONLY the cpu+heatsink/fan, memory & video card installed. Locate the round silver battery in the bottom right corner of the board. Just below it, you'll see a plastic jumper cap. This cap should be covering 2 pins (pins 1 + 2) with pin 3 bare. It will be marked JP1. Move the jumper to cover pins 2-3 instead. Leave in this position for about 30 seconds, then return the jumper to its original position (pins 1-2).
6) Reconnect the square 4pin ATX2 power connector & the main 20 pin ATX power connector. Make sure that the case speaker or buzzer is connected also.
7) Make sure the only external devices connected are the keyboard/mouse & monitor. Reconnect the power lead & power on the system
Let me know what happens
Feb 06, 2010 | ASUS M2N68-AM SE2 Motherboard
CPU fan turns for a few seconds and stops, pc will not turn on. Have tried a good PSU, same issue. Removed all connection to motherboard apart from 20 pin, 4 pin power + cpu fan and PW switch: same issue.
1. First of all Remove dust from your CPU fan and try again if issue has been not resolve
2. Second test your SMPS by the help of Green & Red wire. In case fan is turning properly it mines your SMPS is ok
3. Third & last kindly replace your SMPS For the same.
Nov 19, 2009 | HP Pavilion a1120n (PX759AA) PC Desktop
DFI LANParty UT RDX200 CF-DR Motherboard Logo
105 people viewed this question
Top DFI Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Steve Frost
Steve Frost
Are you a DFI Computer and Internet Expert? Answer questions, earn points and help others
