EMACHINE LAPTOP SPEAKER
DO YOU FIX MY KIND OF SPEAKER PROBLEM? I ALSO NEED TO FIND OUT IF THE TOUCHPAD CAN BE REPLACED ? I HAVE AN N-10 E-MACHINE LAPTOP
  • 39 Answers
The touchpad can be replaced on any laptop. As for your first question, we do not fix anything here on fixya. We can only give suggestions and possible solutions for you to try yourself.
Posted on Jul 23, 2008
In my acer emachine e725, the touchpad scrolling is not working, anybody help please.
haave you recently opened the front portion of the computer up to replace a part ? there is a connection inside , perhaps it has dislodged itself from power.
do you have the service manual ? in it it esxplains (in brief) about the touchpad portion
apparentkly there is aon/off swicth
Touchpad toggle Turns the internal touchpad on and off.
go to this link to obtain manual
ftp://ftp.emachines.com/notebook/E725/Manual/eM_HM50_MV_Eng_QG_0223.pdf
Oct 16, 2010 | Acer Aspire 5600 Series 5630-6951 Laptop
My touch-pad mouse is not working in A135-S4527 Can you help? Thanks.
Try to power drain the laptop first.Turn off the machine, unplug ac adapter and remove battery.press and hold power button for 10 secs then put the battery back and plug ac adapter if needed. turn on the computer and check if touchpad is working if not then check touchpad settings in taskbar, check if touchpad is disabled if not or if there is no icon there go to device manager(right click on mycomputer->properties->device manager)and look for driver for touchpad under mice and other pointing devices.If driver is not there then you have to reinstall the driver. If you have the disc from the manufacturer of the system then run the disc and install driver or if not go the manufacturers website and then download he driver from there.Make sure you restart the machine after installing the driver for it to work properly, also check if the laptop has a button to enable/disable touchpad...some laptops has that kind of feature...Cheers!!!
May 15, 2010 | Toshiba Satellite A135-S4527 Notebook
I have a Acer E725 e-machine laptop. The Mouse pad seems to be locked, I cannot use it and am assuming I hit some key which locks it. is there a Function key to unlock it ??
next to your power button there is another button which shows a finger and a pad...if light is on in that you need to press that button and turn the light off...then also if it is not working install driver for touchpad from the resource CD you have got along with the emachine
May 12, 2010 | Acer Computers & Internet
Emachine E725 touchpad does not work
The eMachines E725 has a built in switch to toggle the touchpad on or off by the touch of a button. Look at the button to the left of the main power switch. You'll notice the icon looks like a hand touching a rectangle - or touchpad. if this button is lit up, the touchpad is turned off. simply press the button to toggle the touchpad back on. The light on the button should now be off.
It's that simple. I hope this helps.
Apr 14, 2010 | Acer Aspire 3000 Notebook
Adapter/power supply cord missing emachine model SP 30A speakers
AC/DC Adapter
Model MA-9200
Input 120 VAC 60 Hz
Output 9 VAC 200 Ma
Class 2 Transformer
Oct 17, 2009 | Audio Players & Recorders
How do I unlock my touchpad on my new Emachine laptop E625? I believe I locked it inadvertently... When I trouble shoot it, Windows says the pad is working properly. Currently, I am using a USB mouse on...
There should be a button just above the touchpad to reactivate it. If not, it will be the Fn key + one of the Function buttons at the top which look like a touchpad icon.
Aug 03, 2009 | Computers & Internet
Mouse doesn't work properly
That's it. There's nothing else.
The problem is with the motherboard and not the touchpad component.
The only thing you could try is updating the bios but it's a long shoot.
Sorry to give you bad news, but it is what it is.
Mar 10, 2009 | Dell Inspiron 6000 Notebook
Dell Inspiron 600M Keyboard Replaced, now touchpad doesn't work
need to pick up the keyboard and make sure the ribbon cable to the mother board is fully seated. if it is. then the touchpad need to come out and clean it very carefully. the sugar and any sticky substances need to be clean off the machine, around the touchpad.
I hope the drink did not damage the touchpad.(it is heat senstive)
if it still don'e work aft reinstalled it. you need to call dell to get a replacement.
Nov 13, 2008 | Dell F3534 Touchpad
Touchpad key 'sticky'
Hi Talderman, Are you referring to the ?mouse? button just below the touchpad? If yes, that is a common problem and could be the result of foreign material getting in-between the contacts or more likely mechanical wear from use. You can try cleaning the contacts but you will need to disassemble the laptop to get to the touchpad assembly which is part of the palmrest. It?s not a quick or risk free job and typically is beyond the abilities of most home users since it involves removing the LCD panel. Unless you have the skills, tools and have the ability to risk the machine I would suggest taking it to the local Dell authorized shop and having the touchpad replaced. If you decide you want to try let us know and I?ll post instructions on how to take it apart. By the way Ebay has the part for about $20?.. Good luck and please don?t forget to rate the post.
Feb 01, 2007 | Dell Inspiron 2200 Notebook
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
