Question about Gateway Computers & Internet
The ac adapter on my daughter's notebook just sparked and was very hot. Does this likely need to be replaced?
    President:
  • Gateway Master
  • 1,314 Answers
Likely, yes. However, it could also be a problem with the plug in on the motherboard or the circuitry thereof. The best thing to do is to try another adapter on it and see if that corrects the problem.
Thanks and please take a moment to rate as FixYa. Thank you.
Posted on Jul 23, 2008
I got a new battery it worked when i got it now it wont charge ac adapter works though after i made sure the battery worked i put the computer away for a present for my daughter i have my own laptop so the...
Welcome to FixYa!
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Thank you for using Fixya...
Jul 17, 2011 | Gateway T-6321 PC Notebook
I can't get my dell inspiron to power on. I will charge the battery using the wall charger but will not come on. What can I try?
Try this if will help.
Remove battery and unplug the ac adapter from laptop.
Without the power sources hold down the power button for 10 seconds.
Check the ac adapter from wall power socket if ac adapter LED is ON.
Plug back in the ac adapter to laptop then check the LED from the ac adapter if it stayed on.
If ac adapter LED turned off right after you plug in the ac adapter to laptop then you need to replace the ac adapter, motherboard and power daughter board.
Hold down the D key then Press Power Button once. Check if color display will appear in the screen.
if the ac adapter stays on you and still no power indicator from the laptop you need to replace motherboard and power daughter board.
Hope this helps.
Jun 02, 2011 | Dell Inspiron 6000 Notebook
Sometimes the Adapter Charges other times Doesnot, and now finally out, cant charge!
Possible cuase:
1 AC adapter failure
2 Power jack failure
First replace it with another working charger, see if the problem gone. If not, there may be strong possibility that the power jack was broken.
Here below are some common symptoms of a bad charger.
-The laptop only runs when you keep the power cord in a certain direction.
- The laptop only runs on battery power.
- The laptop will not charge the battery.
- The laptop switches from AC power to battery power intermittently.
- The unit suddenly shuts off
- Sparks come out of the back of the laptop.
Reference: Dell Latitude D620 Charger
Jan 20, 2011 | Dell Latitude D620...
My daughters Toshiba satellite l505d will not boot up correctly. It starts but then nothing happens. What do I need to do. Have already taken battery out and restarted. Any help would be helpful.
Try the following.
1. Remove battery and plug in the AC Adapter and check if it works
If yes - Battery is defective
If no - Motherboard Problem/AC adapter
2. Check the AC adapter LED indicator if its lighted or not(double check by a multitester)
If lighted - it works properly
if not - replace
3. Try to reinstall WINDOWS operating system by the use of the installer CD
4. Reformat your computer and install necessary drivers and applications
Thanks. Cheers!
Apr 15, 2010 | Toshiba Satellite L505-S5966 Notebook
No power to dell inspiron 1545 adapter
Ya this is a AC adapter Failure if there is no blue light then ,if you have any other known good AC adapter to try with if it works then it faulty call DELL with see whether your system is in warranty, there is 20 digit long serial no on the dell ac adapter,they will replace it if it is in warranty
Jan 09, 2010 | Dell Inspiron 1545 Notebook
What ac/dc adapter do i use with the creative
check this one, they have power adapter for cambridge soundwork dock
http://www.findpowercord.com/ac-dc-power-adapter-for-cambridge-soundworks-i-dock/
Oct 24, 2009 | Creative Technology Cambridge SoundWorks...
Acer laptop 5315. While using the laptop it just
this laptop is cleverly designed, it is most probably the daughter board. this is where you connect you ac adapter. the daughter board or power board, eliminate the need for you to replace the whole motherboard when the connector is damaged. all you need to do is replace the power board. if this does not fix the issue, then there is a likely hood that you need to replace the motherboard
but before you attempt the above, first check if the ac adapter is not the problem
Sep 26, 2009 | Acer Aspire 5315 Notebook
Battery ac adapter overheats
You need to ditch the battery on the laptop. It is causing the issue. This is a know problem with this laptop.
Mar 31, 2009 | Acer Aspire 3000 Notebook
Screen went black
plz try by resiting the ram, if the problem persist then you have problem in display adapter,send it to the vendor from whom you have bought
May 16, 2008 | Compaq Presario 700 470024-192 Notebook
My laptop battery won't charge
possible when the old AC adapter blew it took part of the power management circuit with it, This is the circuit that detects and charges the battery, I'm not sure whether this a seperate replaceable daughter card or whether it is part of the main motherboard. you will need to investigate this (or send it for a service)
Oct 09, 2007 | Dell Inspiron B130 Notebook
Computers & Internet Logo
15 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
