Home | Standard Televisions | Audiovox AVT2540 won...
Problem for Standard Televisions
Generic problem for all Standard Televisions
Audiovox AVT2540 won't turn on
By taggart526 on Jul 23, 2008
The TV in our RV turned off on it's own. Now we can't get it to turn on. Using the remote or on the TV itself, we still get nothing. The red light that usually comes on as we turn it on doesn't come on. The TV is basically built into the RV, and it would be extremely difficult to remove it, so I wanted to check what to do first before I removed it. Thank you.
Sponsored Links
Solution #1
posted on Jul 23, 2008
Not Rated)
Benimur
Rank: Guru
Rating: 88%, 3741 votes
The only possible check that could be done without removing/opening the Audiovox TV would be to check for the presence/absence of supply power/voltage depending on how the TV is powered (12VDC or 120 VAC). Normally, there would be an fuse and/or circuit breakers.for the RV's entertainment system including the TV.
The 120-volt circuit breakers and 12-volt fuses are located in the same compartment. These devices interrupt the power if the circuit is overloaded.The 120-volt circuit breakers include a 30 amp main breaker and several smaller breakers for individual circuits. If a circuit breaker is tripped, look for an overload on the circuit, then reset it by turning the breaker OFF and then turning it ON. Do not try to reset a breaker the second time without locating the overload problem. The 12-volt fuses protect individual circuits. If the circuit is overloaded, it will blow the fuse and the fuse must be replaced. Check the circuit for an overload and replace the fuse with the same type or amperage rating.
If the above checks out, then problem is internal to the unit and would require removal from its current position.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Was this helpful?
Yes
No
Popular Solutions for Standard Televisions
Questions and Unsolved Problems for Standard Televisions
Answer
Cant change tv from cable to antenna
Answer
my 27'' rca tv. keeps going on and off by itself how do i reset it like the repair shop did two... (More)
Answer
Have a Sony KV-32S40 TV picture comes on about one minute after it is turned on then flash on-off... (More)
Answer
my tv should be recording but it says ''updating your recording(s) this may take a few minutes...''... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Standard Televisions:
Top Standard Television Experts
Rank: Guru Guru
Solutions: 1444
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Standard Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
