Question about Tag Heuer Formula 1 CAC1111.BA0850 Wrist Watch
Crown I need to reattach the hands. I have removed the the back but cannot remove the action because I cannot get the crown off. The watch is a Bulova.
    Problem Solver:
  • 5 Answers
Your need the following tools to take out the crown...fix the hands and fix the hands.
1. Pointed Small Forcep
2. 7 or 8 no. small screw driver
You can these tools from a hardware store.
As this work is of high perecesion you need to be very careful and need high concentration.
As you have already opened the back cover of the watch you may find an arrow(--->) mark, when you press it and pull out the crown it may come out.
Now you can fix the hand by holding it by forcep and then setting it on the pinion(centre) of the dial or the position you want to fix.
In case of any difficulty you may take the watch to service centre.
Posted on Jul 23, 2008
My crown for my bulova precisionist watch won't screw down
It is possible a tiny gasket is inside the tread... needing to be REPLACED before proceeding.
First check to see if it is a "left-hand" or "right-hand"
threaded CROWN... Then check that there is no damage to the STEM or the CROWN... You will need at least a 10x (power) jeweler's loupe to see that.
If you have any damage... A watchmaker might be able to dress the treads and save the ORIGINAL PARTS...
Else you are probably looking at replacing both the stem & crown...
Dec 23, 2016 | Bulova Watches
Removing crown and reattaching arms
On most watches there is a very tiny screw next to the crown that you can turn to remove the crown.
Here is a tutorial on how to take apart watches with pictures to help you as well.
Hope this helps!
Jul 28, 2008 | Bulova Quartz Two Tone Steel Watch for Men
How to set up second hand and chrono minutes for bulova 98B105 back to zero setting?
If you haven't got the user instructions you can get them via the following link:-http://www.bulova.com/watches/bulova/marine-star/98b105/
You should see "download user manual" at the bottom of the page.
Mar 31, 2011 | Bulova Marine Star Calendar #98B105 Watch...
SETTING DATE&TIME
i cant get a manual for this but watches have standard mechanical function so maybe this will do.
the center crown of the watch right side of the picture, loosen the crown. Be careful, some crown have a screw function so if your bulova has this don't force to pull it to prevent damage. if you have loosen the crown, check if can be turn it, if yes pull gently the crown, first pull date adjust,second pull time adjust.
This is the proper way to adjust you day and time.
say you want to adjust your watch to (date)10th (time)10:15am
adjust your date to 9th, then move your watch hands clockwise until the date change at 12oclock this is the evening time (PM) continue moving your watch hands until you reach 10:15am.
if your crown is a screw time remember to turn it close tightly for waterproofing.
Dec 13, 2010 | Accutron BULOVA men's 26B62
Bulova 96R31 keeps time + date, but the chronograph does not work
The problem is in chronograph module or related gear train. To find what exactly the problem is, special tools and equipment is needed as well as watchmakers knowledge and skill. There may be just an underpowered battery, but according to your explanation, I tend to think that the first causes mentioned by me are the right ones. Visit your nearest watch repair shop and ask to check your watch for any faults. Rate me, please.
Feb 25, 2010 | Bulova Diamond Chronograph #96R31 Watch...
Cannot open clasp prestige replica rolex
1)Unscrew the crown until it pops out, the same way you would unscrew the crown to change the time on the watch.
2)Place the watch case opener in the notches around the outside of the back of the watch case. You have to use a watch case opener made for Rolex watches to open the watch. Once the case opener is in place, twist it and the back will pop open.
3)Use a mini screwdriver to loosen a tiny screw on the inside of the watch located near the stem. You do not need to unscrew fully--only loosen it.
4)Pull the crown straight out. The crown and stem should come out easily.
To open the back of the watch
1)Purchase a Rolex watch back opener set, if you do not already have one. This set is able to open and close any size of Rolex case.
2)Match the size of your Rolex case with the same size of grooved metal die from the tool set.
3)Put the metal die on the grooves on the back of the watch case.
4)Turn the die to remove the case.
5)Remove the rubber gasket.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Dec 31, 2009 | Bulova Watch
How do I safely remove the crown of SEIKO ladies wristwatch
it might just lightly push on but not expert at this. clocks do. and some watches do. thats a fact.
Mar 26, 2009 | Seiko SNA413 Wrist Watch
I cant adjust the minite hand backwards if the watch is gaining
Unfortunately your watch do not have reverse action, so, you have to go all the way forwards till you reach designated time again.
One more way how to set the right time is to disconnect the battery and wait till the real time reaches the hands of your watch, then put battery back and set again. If watch has a STOP function (crown pulled out), then you don't have to disconnect the battery- just pull out crown and wait.
By the way: pushing the button in accelerates minute hand constantly, but if you'll push the button rapidly, it will move mimnute hand bit by bit. Use this feature to set desired time more precisely.
Do not forget to rate, please.
Jan 14, 2009 | Bulova Watch
Remove stem on accutron 76 to replace face number
The video i want to see you,is using older kind of watch,screwing before he can pull the crown ,the new model watches now is pushing, while pushing you pull the crown .That's why ill tell in advance so you aware.I know because i'm a watch technician working in rolex before...
remove the crown
if i helped,please,click FOR RATING .It is the only way i get paid for my works also,please consider leaving feedback..
Jul 26, 2008 | Bulova Watches
How to align seconds hand for stopwatch feature?
If you pull out the crown to the 2ed postion the push the upper start button that should move the second hand up to zero then push crown in.
Jan 23, 2007 | Bulova Men's Black Leather, Black Dial...
Tag Heuer Formula 1 CAC1111.BA0850 Wrist Watch Logo
94 people viewed this question
Top Tag Heuer Watches Experts
Jimmy Accardi
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
