Datel Action Replay for Nintendo DS Logo
Anonymous Posted on Feb 09, 2011
When I connect my ds to my pc, the Action Replay automatically goes into usb mode, but then I get a bunch of "Error!"'s on the ds screen. Is this supposed to happen? How can I fix it?
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Feb 10, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
508
Points
I fixed this by:
1. When you start the ds the AR will load. Correct?
2. as soon as you see the white screen with "This product is not made or endorsed by Nintendo" hold A+B+Start+Select
NOTE
I do not suggest doing this unless you dont have codes you manually imported in because it will delete them.
  • Anonymous Feb 10, 2011
    It didn't help.... What am I supposed to do after? When I did it, the screen went white, so I just turned it off. Was I supposed to wait?
  • Anonymous Mar 26, 2011
    Weird... Usually it will... Nvm well I got a new one and my friend told me how to fix my old one because I sold it to him and then he fixed it he said that he plugged it into the comp and then deleted all the codes and games. I hope this helps, if not I'd suggest getting a new one, they sell for around 20-30 dollars at Gamestop
Action replay gone blank not loading
mmm... Try restarting it
Can you tell me more about it?
3helpful
Action replay doesn't let me add codes in custom code list!!!!!
Your Action Replay DS hardware may require resetting if you are experiencing any of the following problems:
* Code Manager PC software is reporting that Action Replay DS does not contain enough free space when it actually contains no codes.
* Code Manager PC software is reporting the console`s battery is low when it’s actually fully charged.
* Multicolored bars are shown on the screen after you confirm the entry of a game ID when trying to manually enter codes.
* You can use the Code Manager PC software without any problems until the Action Replay DS is connected via USB set to the update mode on the console, at which point Windows shows a run time error.
If you are experiencing any of these problems, please follow the steps below to reset the Action Replay DS hardware. Please beware that resetting the Action Replay DS hardware will not restore a default codelist, and any codes which are stored on the Action Replay DS will be erased.
1. With your console powered off insert the Action Replay DS
2. Hold down buttons A+B
3. Turn your console on
4. With A+B still held down, as soon as you see the Action Replay DS license screen press and hold down buttons START+SELECT so that you now have 4 buttons held down
5. Hold all 4 buttons down for around 10 seconds until the Action Replay DS loads to it`s home screen
6. If Action Replay DS doesn’t hold on the license screen for around 10 seconds when you do this, you may need to turn off and try again
9helpful
I wiped all my games! HELP ME!!!!!!!!!!!!!!
i had the same prob
* Multicoloured bars are shown on the screen after you confirm the entry of a game ID when trying to manually enter codes. * You can use the Code Manager PC software without any problems until the Action Replay DS is connected via USB set to the update mode on the console, at which point Windows shows a run time error.
from codejunkies
1helpful
My ds wont accept the ards. My other ards wont put any new games in the bottom screen it goes blue and red?My computer (windows vista)doesnt accept my ards
Your Action Replay DS hardware may require resetting if you are experiencing any of the following problems: * Code Manager PC software is reporting that Action Replay DS does not contain enough free space when it actually contains no codes. * Code Manager PC software is reporting the console`s battery is low when it?s actually fully charged. * Multicoloured bars are shown on the screen after you confirm the entry of a game ID when trying to manually enter codes. * You can use the Code Manager PC software without any problems until the Action Replay DS is connected via USB set to the update mode on the console, at which point Windows shows a run time error. If you are experiencing any of these problems, please follow the steps below to reset the Action Replay DS hardware. Please beware that resetting the Action Replay DS hardware will not restore a default codelist, and any codes which are stored on the Action Replay DS will be erased. With your console powered off insert the Action Replay DS Hold down buttons A+B Turn your console on With A+B still held down, as soon as you see the Action Replay DS license screen press and hold down buttons START+SELECT so that you now have 4 buttons held down Hold all 4 buttons down for around 10 seconds until the Action Replay DS loads to it`s home screen If Action Replay DS doesn?t hold on the license screen for around 10 seconds when you do this, you may need to turn off and try again whats an ard? from code junkies
My action replay zeroed out.
the ds cartridge need to be reset.
do it by using this method.
you can tell if it needs resetting by;
2helpful
2answers
Action Replay DS has deleted avery single cheat code it came with
source codejunkies
Action Replay does not find DS Lite even though USB is connected
theres 2 little metal strips on the AR USB connector, you have to carefully snip them off their furtheest to the end on each side. that will fix your problem
5helpful
2answers
My Ds Action Replay Went BLANK!
i have had a similar prob it wiped all the games andm then i could not put more on because it went multi coloured when i tried so i hap to reset the entire thing to do so(source codejunkies):
copyed from code junkies
24helpful
4answers
Action replay when i plug in my ds and load code manager it says waiting for ds even though it is plugged in
IF you are running Vista 64, the issue is the driver on the disk is incompatible, thus the pc will never see the ds. However, I have found a workaround. First make sure the DS is on and plugged in and the Action replay Manager is launched. On the DS click on the mouse so it should read updating software. Then, go into device Manager via the Control Panel, there you will see NDS and an exclamation mark. Right click and choose to update the driver or properties. Then choose Browse My computer for driver software... then let me pick from a list... then fo the manufacturer shoose: Standard USB Host Controller and for the Model choose Unknown. It will pick it up instantlly. Voila.. Good Luck! and what a pain!! V
I’m happy to help further over the phone at https://www.6ya.com/expert/vicki_52d4aba3abce9140
9helpful
2answers
Can't get codes
I have just found the solution to the problem (2 minutes later XD)
Quote CodeJunkies' Support site:
Try resetting the Action Replay by following these steps:
  1. Insert the Action Replay into the DS
  2. While the Action Replay software is loading, press and hold all the following buttons: A + B + Start + Select.
  3. Release all of the buttons once the Action Replay is at the main menu.
The first screen should persist for much longer than normal, and when the Action Replay DS main menu loads, your hardware should be reset.
Once the reset has been performed, try connecting the USB cable to your PC, opening up the code manager software and transferring data again.
It won't return all of your games back, but it will allow you to start on a clean slate again. (Using the update feature will bring most, if not all of your games back
Top Datel Video Game Consoles & Games Experts
Aron
john h
Are you a Datel Video Game Console and Game Expert? Answer questions, earn points and help others
