Question about Sony Walkman NWZ-B105F MP3 Player
Can't get my player connected
When I connect my player to the computer it appears to be recognized by the system, but i just can't get access to the device the display only marks "don't disconnect data access" this message apears blinking and then, the device shoots down and restarts again and again, when I try to access the device in a normal way It displays a message "format error"
I've tried with some solutions like pressing the reset button and trying to update the firmware, but nothing solve the problem
  • Anonymous Jul 26, 2008
    i`m having the exact same problem and i dont hav my own pc to wiork on
I've had the same problem. This is wat I did:
Originaly this player was only plugged into a computer with windows Vista installed. I then plugged it into a laptop with Windows XP pro. It told me that it was unformatted and asked me if I wanted to format it now. I formated it as FAT32. Once the formatting was complete I unplugged the player and the display on the player said that is was creating folders. I had a functioning mp3 player once that was done.
Posted on Sep 26, 2008
Sony walkman nwz-b135 when i connect it to my laptop it will add music etc, but will not charge thanx
I'm sorry to know that the Walkman player is not getting charged. I'll be glad to assist you with this. Please perform the following steps:
If the New Hardware Wizard appears and is prompting for a location of the driver, point to the following directory: C:/WINDOWS/INF .
To function properly, your Walkman player must be recognized by your computer as a Media Transfer Protocol (MTP) device. If the portable player was connected to the computer before the Windows Media Player version 10 or later was installed, it will be recognized as a Mass Storage Class (MSC) device and not function properly. In that case, a different procedure is available to correct this issue.
For some models, when you use the portable player for the first time, if you have not used it for a long time, or the battery is depleted, it may take up to 5 minutes for it to be recognized or start charging. On models with a display, the display will remain blank. If it the portable player is not recognized or does not begin to charge after waiting 5 minutes, reset the player by pressing the reset button.
If this is not the first time using your player and it was working properly at one time with no major changes performed (such as restoring the operating system or replacing a hard drive), follow the procedure below:
Connect the portable player to the computer using the supplied USB cable.
Disconnect the USB cable from the portable player and then reconnect.
Check the connection status again.
Disconnect the USB cable from the computer and then reconnect.
Check for available space on the player using Windows Media Player or My Computer .
Restart the computer.
Check that the USB cable is firmly connected to both the computer and the player.
If the player is connected to a USB hub, disconnect it and connect it directly to the computer with a dedicated USB cable.
If the player is still not recognized by the computer, disconnect all devices connected to the computer with a USB connection and restart the computer.
After the computer restarts, connect only the Walkman player and test the connection again.
If the player is still not recognized by the computer, try a different USB port.
Under the Common settings menu of the player, format the player using the built-in Format utility.
Verify the current Operating System. If it is an upgraded operating system, contact the computer manufacturer for updated drivers for their upgraded operating system.
If you are running the Windows XP operating system, be sure you are running Service Pack 2 (SP2) or later.
If you did not have the latest service pack, test the connection status again after it has been installed.
If you are still unable to transfer music to your player and have not yet uninstalled and reinstalled the driver follow the procedure to confirm that the player is recognized by the computer as an MTP device.
Thanks for contacting FixYa.
Aug 08, 2011 | Sony Walkman NWZ-B135 MP3 Player
When i installed the media player into my computer. i get a little screen saying usb device not recognized. one of usb devices attachedto this computer has malfunction,and windows does not recognize it....
Hi, smpk4083 mp3 player not recognized by the computer
Why is my smpk4083 mp3 player not being detected by my computer when I connect it?
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met.
- Windows XP SP2 or higher
- Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.
- Download the hotfix from http://support.microsoft.com/kb/939211.
- Run the hotfix.
For MAC users, see smpk4083 mp3 player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the smpk4083 mp3 player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: smpk4083 mp3 Players can connect to your computer in MSC or MTP mode. Exceptions are smpk4083 mp3 player Connect and smpk4083 mp3 Express which only use MTP mode. MTP mode is the recommended and default method for smpk4083 mp3 Players when used with Windows OS.
The smpk4083 mp3 player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Hope it helped.
Have a nice day,.
Feb 22, 2011 | Sylvania Audio Players & Recorders
I have just bought a new sansa clip. i have successfully uploaded music to the the player and i can hear it well. now when i try to access the player through the computer i cannot access the music and...
Hi, are you sure the computer is recognizing your player?...if not....
4. Power issue.
- Run the hotfix.
For MAC users, see Sansa player not recognized by a MAC OS
STEP 1 - Connect the Sansa player to the PC
NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are mitone mp4 player Connect and mitone mp4 player Express which only use MTP mode. MTP mode is the recommended and default method for mitone mp4 player Players when used with Windows OS.
The mitone mp4 player player will show up on Device Manager's right pane as:
Hope it helped ..
Have a nice day..
Feb 19, 2011 | SanDisk Sansa Clip MP3 Player
How do i download music? i'm not reconized by computer . sansa e250
To have your system recognize your Sansa as a disk drive do the following:
1. Turn off the player.
2. Connect the usb cable to the computer. Do not connect it to the player.
3. Slide the lock switch to the right. You will see an orange strip.
4. Connect the usb cable to the player.
5. The player should appear in your computer as an external disk. Copy your music from the player to your computer, or viceversa.
Dec 09, 2009 | SanDisk Sansa e250 MP3 Player
My battery wont recharge when i plug it into the computer
IMPORTANT: To function properly, your Walkman® player must be recognized by your computer as a Media Transfer Protocol (MTP) device. If the portable player was connected to the computer before the Windows Media® Player version 10 or later was installed, it will be recognized as a Mass Storage Class (MSC) device and not function properly. In that case, a different procedure is available to correct this issue.
NOTE: If this is not the first time using your player and it was working properly at one time with no major changes performed (such as restoring the operating system or replacing a hard drive), follow the procedure below: Check for available space on the player using Windows Media Player or My Computer . Restart the computer. Check the connection status again and try to sync the player. Check that the USB cable is firmly connected to both the computer and the player. Check the connection status again and try to sync the player. If the player is connected to a USB hub, disconnect it and connect it directly to the computer with a dedicated USB cable. Check the connection status again and try to sync the player. If the player is still not recognized by the computer, disconnect all devices connected to the computer with a USB connection and restart the computer. After the computer restarts, connect only the Walkman portable player and test the connection again. If the player is still not recognized by the computer, try a different USB port. Check the connection status again and try to sync the player. Under the Common settings menu of the player, format the player using the built-in Format utility. Check the connection status again and try to sync the player. Verify the current Operating System. If it is an upgraded operating system, contact the computer manufacturer for updated drivers for their upgraded operating system. If you are running the Windows XP operating system, be sure you are running Service Pack 2 (SP2) or later. If you did not have the latest service pack, test the connection status again after it has been installed. If you are still unable to transfer music to your player and have not yet uninstalled and reinstalled the driver follow the procedure to confirm that the player is recognized by the computer as an MTP device.
Sep 22, 2009 | Sony Walkman Video NWZA818 MP3 Player
Mp3 not recognized by the computer
try re installing the cd program of ur mp3 or if you dont have any... try this. (for windows computer only)
1- plug your mp3 in the computer using your usb.
2- go to my computer.... in the left task pane. click view systems information.
3-the system properties dialogue box will appear.
4-click the hardware tab then click the device manager.
5-the device manager tab will appear.
6- click the portable devices then you will see the name of your device.
7-click the name of your device .
8- you will see in the general tab in the dialogue box that will appear 'device usage'
9- enable it.
thats all..
Jun 07, 2009 | SanDisk Sansa E280 MP3 Player
Cannot get my computer to recognize my sansa e260 player
On your Sansa Go to "Settings" then "System Settings" then "USB Mode," change it to MSC, now try connecting it. If that doesn't work try the other modes just in case.
Hope this helps!
May 01, 2009 | SanDisk Sansa Connect MP3 Player
Usb port problem
This would indicate to me that your MP3 Player might be bad. Have you tried to connect your MP3 player to another computer to see if it works on that computer?
Good luck.
Jan 06, 2009 | Microsoft Computers & Internet
Not recognized by computers
To fix this try the following using an account with administrator privileges and internet access:
1. Open Device Manager (While holding the windows key, press the Pause / Break key. This will open up the System Properties box. Select the Hardware tab and click Device Manager)
2. Find and expand the Portable Devices folder (a problem icon should appear beside the WALKMAN NWZ-A815 device)
3. Right-click WALKMAN NWZ-A815
4. Click Update Driver...
5. Select Yes, this time only
6. Click Next
7. Select Install the software automatically
8. Click Next
9. Click Finish
Open Windows Media Player 11, connect your sony nwz-a815 and wait for it to appear then try to sync some files.
Mar 31, 2008 | Sony Walkman Video NWZ-A815 Digital Media...
Sony Walkman NWZ-B105F MP3 Player Logo
152 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
