Shaper Image wireless speaker auxillary SR 298. Speaker does not work. Appears not to receive wireless signal. Book no help and Shaper Image support non-existant. Are there any repair places or tech support available? allan caldwell vccaldwell@aol.com
5 Suggested Answers
SOURCE: Sony STR-DE845 center channel cut out, receiver clicks
balls
Posted on Dec 20, 2007
ginko
  • 19396 Answers
SOURCE: Sharper Image Wireless transmitter deal
Do not restart them with the button, that won't reset settings, unplug everything from power for 5 minutes and plug them back.
Posted on Jul 19, 2008
gpgab97
  • 77 Answers
SOURCE: Only one speaker working on my str-de675 receiver
If the speakers themselves work fine, then the problem lies within the amplifier output. The channels can go bad after hard use, they can be repaired but it may well exceed the cost of the amp if it is not just one channel. Also be sure that you are hooking up speakers that are rated for your amplifier by matching the OHM resistance of the amplifier to compatible speakers.
Posted on May 03, 2009
  • 4 Answers
SOURCE: Marantz SR-18EX; Front left channel crackles
The f-l channel of the sr18, & sr18ex & sr19 is a common failure location due to the heating and cooling over the years. The crackling an/or distortion, is most commonly due to the amplifier going into a high idle, or d.c. offset that can no longer be controlled by the adjustment potentiometers on the board. usually the two 2sc3200 transistors become unstable, and as well a 47mfd and a 470 mfd elect. caps nearby. Also distortion is caused by one or more of the zener and germanium diodes all grouped near the big dual ceramic white resistor. The amp block is held in by six screws. first remove the cross bracket, then cut the cable tie free from the hole on the board. Ten screws hold the top board on, the pull the boards apart from the connectors. before replacing it, resolder ALL of the connector pins to BOTH boards.
Posted on May 27, 2009
SOURCE: Speaker Detect error Left Rear
Hey there.
I had the same problem until i figured out that if u dont have surround speakers connected it will be a error when trying to configure the rear surround speakers.
So if u are running a 5.1 system and have hooked up ur surround speakers to the back surround speaker port u have to change them to the surround speaker port.
Hope this work for u
Posted on Sep 09, 2009
Reconnect my wireless lg w95 receiver to my blue ray after it was unplugged
Wireless speakers connection
LED indicator of wireless receiver
LED Color Operation
Blue - The Wireless Receiver is receiving the signal of the wireless transmitter.
Red - The Wireless Receiver is in standby mode.
Off (No display) - The Wireless Receiver is turned off.
Initial setting an ID of wireless receiver
1. Connect the Wireless Receiver and the rear speaker (right, left) with the speaker cables.
2. Connect the power cord of the Wireless Receiver to the outlet.
3. Turn on the main unit and Wireless Receiver: The main unit and wireless receiver will be automatically connected. "MATE OK" appears in display window. Setting an ID of wireless receiver When the unit is manufactured, the ID is already set. If an interference occurs or you use a new wireless receiver, an ID should be set
again.
1. Turn on the main unit and turn off the wireless receiver.
2. Press and hold x (STOP) on the front of unit and MUTE on the remote control. "REMATE" appears in display window.
3. Turn on the Wireless Receiver. A new ID is set.
Nov 23, 2011 | Televison & Video
HI, I have Receiver Marrantz SR- 5005, the center chanel does not work, please tell me what happened and solution to fix the problem. Thanks
Get the manual and open it up to the part where speakers are defined, then test it/them with tones. Try swapping a different speaker into the center if the current center channel speaker still doesn't work.
Web search "Marantz SR-5005 manual" (note the spelling)
Aug 07, 2011 | Audio Players & Recorders
How do i make the Sharper Image SA251 Subwoofer Speaker work what do i use as a line level?
I don't suppose they came with a manual.
http://www.spreadmyad.com/san-diego/merchandise/electronics/8242133-sharper-image-subwoofer-san-diego-25
Line level would (usually) be the LFE signal produced by a multichannel receiver. The speaker level inputs would be from the Front L and R speaker outputs.
Aug 04, 2011 | Sharper Image SA251 Subwoofer
Can't get computers Bluetooth to connect with Bluetooth speaker
Install the sofware that came with it and then try. If your computer dosen't have bluetooth it cant connect. Usually you would need an extra piece of hardware to get bluetooth on your pc.
Jan 29, 2011 | Altec Lansing iMT525
Power cuts off after 2 seconds after stereo start button is pressed
Disconnect your speaker wire's from your receiver, and then turn the receiver on.
If your receiver cuts off with the speakers disconnected, there is something wrong with your receiver, and take your Sherwood receiver to a qualified reputable technician.
If your receiver stays on with the speakers disconnected, their is a short circuit either in your speakers wires, or in your speakers. Make sure your speaker wires are pushed all the way in the speaker terminals in the back of the receiver, and do not leave no naked speaker wires exposed. If you have too long of bare speaker wires exposed at the receiver's speaker terminal, or at the speaker's terminals, they could touch each other, and cause the receiver to cut off. If the speaker wires are OK, then you may have a short circuit in your speakers.
Nov 12, 2009 | Sherwood RX-4105 Receiver
Hey there.
Jan 11, 2009 | Audio Players & Recorders
Hitachi SR-2000 receiver's right speaker connection does not work
The SR-2000 has fuses for both left and right outputs. Make sure neither are blown. Otherwise this receiver has a STK 463 integrated chip that controls the output for both channels. When replacing the STK-463 it is also acceptable to use STK-465.
Jan 10, 2009 | KLH R3100 Receiver
We have the sharper image wireless indoor outdoor speaker and when we plug everything in there is nothing coming out of the speaker. Are we able to get it to pick up satellite radio?
The wireless speakers do not pick up a wireless signal outside of the round wireless broadcaster that came with the speakers. You will need to connect that to your satellie radio to broadcast to the wireless speakers. Make sure the wireless broadcaster component is plugged into the sound source you want to make wireless. After you've connected the broadcaster to the sound source and turned everything on then push the Auto tune button to connect to the broadcaster and recieve the sound.
Nov 27, 2008 | Audio Players & Recorders
Jul 19, 2008 | Audio Players & Recorders
64 people viewed this question
 Grubhead
Grubhead
