Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA D52W20 52 Fuse problem
RCA model D52W20 the fuse keeps blowing out... Any suggestions???
  • steve humelh Apr 12, 2009
    where are the fuses located on rca model number d52w20 ? have the green light on n off problem. did the hair dryer test n it didnt work. no swollen capasitors please help
    Scholar:
  • 154 Answers
Well you could always use a bigger fuse but I would not advise to do it, it could and most likely will blow tv not fuse. Fuses ussually blow from a short or power surge. If it is new or under warranty I would return it for replacement or repair.
Posted on Jul 23, 2008
My RCA audio system shelf does not power on. I changed outlet and check for a defective fuse but to no avail. Any suggestion? It's a RCA 300WATTS 5 DISC AUDIO SYSTEM RS2767I
Could be an internal fuse in the power supply area. Follow the mains cable. However the fuse blowing could be the sign of a fault. If it blows straight away again there is a fault.
Jan 01, 2017 | RCA Audio Players & Recorders
Rca TV MODEL #F31633SB NO PWR AFER BLOWING AC LINE FUSE
Some RCA models had problems with there degauss circuits drawing to much current at turn on. You can change the fuse to see if it will work for a while. If it immediately blows the fuse at turn on or at plug in, there is a hard short somewhere. If it works for a while and blows the fuse again, take it to a repair shop and have them modify the degauss circuit. An up to date shop will know what to do. Should not be expensive.
Oct 15, 2009 | RCA 20F511T TV
RCA 52 Model # R52WH73
The solder joints are loose on the flyback transformer and that is what is most likely causing the fuse to keep blowing. Resolder the connections and replace the fuse and you should be good to go.
Jul 12, 2009 | RCA R52WH73 Projection Television
RCA R52WM24 52 in TV
the RCA service bulletin says to replace FL231, DL231 and CL230 all at the same time then reflow the solder on the flyback and the vertical output IC
Feb 07, 2009 | RCA R52WM24 52" HDTV Projection Television
Fuse keeps blowing R52 WM24 tv
you need to replace DL231, FL231 and CL230 all at the same time then resolder the flyback and vertical IC, You can get the parts under the RCA category at the following link, and they provide instructions on how to do the repair.
http://servicemanuals.vstore.ca/
The Red,Blue,Green do not line up and keeps blowing fuse
you need to replace 3 items FL231, DL231, CL230 then resolder the vertical IC and flyback conections. You can get the three components under the RCA parts category at this link.
Jan 25, 2009 | RCA Scenium D40W20 40" Rear Projection...
RCA P60920BL 60 in. Rear Projection Television Fuse
I am assuming that you preplaced the flyback and horizontal out together. Even if you did, was it blowing fuses before? Usually with this chassis, the horizontal will not blow the fuse. It will just keep the swith mode power supply from operating. Double check and make sure you didn't have a soldered blob get away from the iron and "splash" somewhere on the board
Dec 23, 2008 | Televison & Video
Blown fuse
Most likely there was a power event (surge, brownout, ect) that caused the power supply to fail in the TV causing the fuse to blow. you will need to have someone come and look at the unit and give you an estimate. If you keep putting fuses in and blowing them you could actually be causing more damage.
Mar 10, 2008 | Televison & Video
RCA MM52110 FUSE keeps blowing
should be covered under your insurance might give them a call.
other wise i would check the bridge rectifier,
Dec 05, 2007 | Televison & Video
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
231 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
