Question about Dryers
I have an Admiral Designer Series Heavy Duty 22LB Giant Capacity Plus. I removed the drum for a thorough cleaning the belt came off. Now I put the belt back on but it dosent have proper tension. I see the pulley next to the motor but I cant figure out how it goes.
  • 725 Answers
Pull the pulley toward the motor the belt goes to the outside of the pulley... let me know
Posted on Jul 23, 2008
Admiral designer series heavy duty giant capacity 20 lb dryer
two possible problems
the air blower is not running properly
too many clothes being dried restricting air flow
Nov 24, 2016 | Admiral Dryers
Admiral Heavy Duty Super Capacity Plus dryer does not start when button is pushed. The dryer buzzes when the start button is pushed, but the dryer will not start tumbling. The model number is ADE7005AYW...
Motor runs, but drum does not turn
1. Broken or slipping belt---replace
2. Loose pulley---tighten pulley on shaft
3. Drum jammed or bearing frozen---check for foreign object & clear it
Clean or replace bearing
Sep 21, 2011 | Dryers
Heavy duty super capacity plus Kenmore 80 series Electric drier the timer is running, but when I push the start button - nothing
the drum belt may be broken. you will have to check this, it goes around the drum and the pulley on the motor. you could also have a bad motor.
Oct 16, 2009 | Kenmore 73952 Gas Dryer
Admiral washing machine no cold water
HI, this is a faulty inlet valve assembly. you should replace this failing component asap if possible.This will fix the issue.
Jun 22, 2009 | Admiral Washing Machines
Sometimes does not spin enough to wring out water from clothes.
The spin cycle should be on a timer,and shouldn't be able to change how long it spins.The same timer that controls all the cycles of your washer.Your pump may be trying to go out,and isn't removing the water fast enough.This will keep water in the tub,and the normal spin cycle isn't long enough to let the pump get the job done.Another problem might be a clog in your drain hose.Another problem could be the drain hose is set to high above the pump,and the pump can't push it up that high (shouldn't be a problem if you are using the hose that came with the washer,and not extending it with another hose or something.)
Jun 05, 2009 | Admiral AW22 Top Load Washer
Dryer stumbles to get started spinning
probably need the wheels and idler inspected
Dec 31, 2008 | Amana NDE2335AY Electric Dryer
Admiral Washer not spinning
broken or slipping drive belt, ( motor) to spin pulley , losse pulley, defitive drive clutch, spin brake fails to release, or transmission is frozzen
Jul 07, 2008 | Admiral AW22 Top Load Washer
Admiral Heavy Duty 22lb. 2 speed motor going off balance
Had Same problem. Replaced The 6 retaining springs and snubber.
$15.00 worth of parts.
Dec 22, 2007 | Admiral AW22 Top Load Washer
Dryers Logo
162 people viewed this question
Top Dryers Experts
