Question about SanDisk Sansa c150 MP3 Player
Will not turn on!
It does not even show the low battery screen; it just stays black, or it flashes on and off very quickly.
  • suji_raj Oct 15, 2008
    i can't even turn it on
    wen i plug it to my computer it says there is a malfunction problem what do i do ?
  • 796 Answers
There may be some problem in the display supply...
please take it to the service center and get it replaced...
also see if the battery is in good working condition
Posted on Oct 06, 2008
Alcatel one touch sonic wont turn on....
return to seller would be my option
Dec 26, 2014 | Alcatel Cell Phones
Frozen screen
i suggest you flash it if you can,or you take it to an expert .but does the power button or standby work properly,you may check that first.
Jan 26, 2014 | GPS
Low battery showing replacing batteries does not solve problem
The flashing low battery symbol is the way Canon film cameras showed that the camera has had an error and has stopped functioning. It can have multiple causes - but for a quick check remove the lens, turn off the camera and then turn it back on - see if the symbol stops flashing. A problem with the lens can also cause this problem (usually a failure of the aperture unit)
Dec 27, 2011 | Canon EOS 5000 35mm Film Camera
Wii has flashing lines across screen then turns black, stays black, and can't do anything. If i am able to turn it back on it does this again rather quickly
This needs to be professionally repaired.
The problem is in the systems video card
There are only a few people that can do the process properly and fix the system permanently.
the wii console is probably the most complex system to take apart and put back together properly without damaging anything internally due to the small nature of the unit.
if you need help getting this unit fixed please feel free to contact me
ninja_freak318@hotmail.com
Nov 20, 2011 | Nintendo Wii Console
Display went black and now computer will not do anything
it guess there is problem with battery backup to the laptop( maybe just worn out with use and needs to be replaced ) ... it is contantly charging the battery and it not able to power the display of laptop since you said hard disk led was glowing when the computer boots up... are you getting any messages or beeps as the computer boots up ... this would help in troubleshooting . another thing would be to check up power adapter it may have developed a fault.
Aug 08, 2009 | IBM ThinkPad R51 Notebook
L1932TQ monitor flashes on, then blacks out
I would try connecting it to another computer or Laptop if you can to see if the problem is the same. You might also try disconnecting it from you computer and turning it on, it should “banner”(show a logo and or a no signal message). If it behaves the same way just a quick flash…. Sounds like its toast.
Jun 20, 2009 | LG L1932TQ LCD Monitor
Acer aspire 1640 wont boot up
TRY TAKING YOUR BATTERY OUT FOR 15 MINUTES THEN PUTTING IT BACK IN. IF IT COMES BACK ON, RECALIBRATE YOUR BATTERY BY LETTING THE BATTERY GO DOWN TO 5% THEN PLUG THE POWER CORD IN. YOUR BATTERY MAY NOT BE STRONG ENOUGH TO TURN THE SCREEN ON, EVEN THOUGH YOUR BATTERY METER SHOWS IT HAS A GOOD CHARGE. QUICK CHARGES OR FREQUENTLY UNPLUGGING IT CAUSES THE BATTERY METER TO READ DIFFERENT THAN THE AMOUNT OF CNARGE THE BATTERY IS ACTUALLY HOLDING. RECALIBRATING IT WILL GET THE METER AND THE BATTERY BACK ON THE SAME CYCLE.
Jun 08, 2009 | Acer Aspire 1642WLMi Notebook
Black screen / HD light steady and the fan keeps running
Ok, check your RAM, reseat or clean it with soft eraser, only its edge connector both side. Do this when unit is off and no other power source is connected to it even its battery.
Hope this help.
May 02, 2009 | Acer Aspire 5050-3242 Notebook
Monitor blank
try to start your pc in safemode with vga mode with thjis faulty monitor
hope you know how to do it
start pc (powerr on)
then continuously press F8 key then it will show you boot menu
select safemode with command prompt
then if it show desktop on screen this means your monitor is having problem with resolution try to downgrade your monitor's resolution
rightclik on desktopgo to properties
select settings
here you can find screen resolution make it to 800X 600 just for one time
then restart your pc it will auto select proper screen resolution
Mar 29, 2008 | Dell E173FP (Black) (Dark Gray) 17" LCD...
Philips 30PF9946 D/37
You have sound but no picture. Green power light is on and NOT flashing. You get a screen flash or flicker on power-up or even a minute of screen before going all black. It is your inverter board. Common problem on LCDs (maybe more so on Phillips?). They are easy to replace (unplug-plug) and are available on the net.
Veritas
Feb 24, 2008 | Philips 30PF9946 30 in. HD-Ready Plasma...
Open Questions:
SanDisk Sansa c150 MP3 Player Logo
164 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
SmartAviator
SmartAviator
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
