Question about Kenmore Elite HE4 Electric Dryer
How do I locate and test the fuse?
Thanks for your help. How do I locate for sure? How do I test it? Could I just by-pass it temporarily to check if dryer will run?
  • gajohns73 Jul 23, 2008
    I did check what I think is the fuse for continuity. appears ok? Any other suggestions? Thanks again.
    Genius:
  • 1,028 Answers
Fuse is usually smaller that safety thermostat and located on outer rim of element housing jumping it temp would show if bad or not but do not leave it that way ohm meter would be better
Posted on Jul 23, 2008
  • oldfixer Jul 28, 2008
    what are your symptons? no heat? fuse on element may be bad..not working ? door switch ,control bd ,front customer interface
What could be the issue with my 2010 Corolla and it will not start. I had the battery tested and that is good
This sounds like a bad starter. If you locate the starter it will sometimes work temporarily if you peck on it with a hammer
Nov 04, 2017 | 2010 Toyota Corolla
We have a 1998 coachmen catalina sport...while on our way home today we stopped and when we got back in the vehicle the gear was stuck in park..we were able to start in neutral but later realized our...
there is a gear shift selector by pass it is white in color i assume the selector is on the floor with a center console around it. remove the cover by prying up in the corners press the white by pass button and selector will move. thats just to move the vehicle temporarily. the real problem lies in the wiring harness that goes into the transmission it has a short in it that is grounding out that blows the fuse. to find the bad fuse take a test light hook the ground up to ground and probe the fuses one by one the one that dont light up replace. this is while fuses are in vehicle car on.
Apr 05, 2013 | Cars & Trucks
2003gt ford mustang driver side head light will not come on.pass.side works.check voltage at plug ,no voltage? installed new plug no voltage.checked fuse box under dash driver side all good. not sure on...
Hi, fuse 10 in the car runs the left bulb. If the fuse it good, it must be the wire or ground connection. There is no relay in the circuit.
Thanks for using FixYa.
Closeup
Jan 23, 2011 | 2001 Ford Mustang
81 toyota pick-up. No spark
Check to make sure the main fuse is good. Sometimes those blow when you short out a wire from the battery to the ground on the car *like when an alternators live wire hits ground on the car.
On a 1981 Toyota pickup, im unsure of where it is located, but sometimes they are located in the fuse box, as a big fuse usually a 100 amp or 80amp fuse.. Sometimes they are located along a ground connected to the engine and the frame of the car. This could make it just crank and not start.
Check also to make sure that the engine is grounded, by taking a test light and connecting it to the positive side of the battery, and testing the metal around the motor. Sometimes grounds can break, or when shorted out they can melt. If the motor is not grounded then it will not start. and will just crank.
Hope this helps a little - Jarett
Aug 17, 2009 | 1983 Toyota Pickup
Dryer will not start
based on your description, i would suggest two possibilities. the first....check the door switch
two....check the blower housing sensor (a fuse like component located at the lower rear of the dryer).. it is a small , slim part about an 1 1/4 inches long and about 3/8 ths inches wide. it has a wire connection at both ends.
a quick test for both components mentioned would be to pull the wires off and temporarily connect them together. (be sure to not let them touch anything else). then try to operate the unit.
hope this helps...........................jay
Apr 16, 2009 | Kenmore 63942 Dryer
Problem with steam
I'll take the machine if you are throwing it away:) You have a blown fuse. There are 2 fuses inside the mahine. Uplug the mahine, Pull the top of and locate both fuses. Connect a wire going from one end to the other of the fuse. This will temporarily short circuit the fuse. Now plug the machine in, and test it out. If it works, than that is obviously the bad fuse. If not, try the exact same procedure on the other fuse. My thermal fuse went out and it only set me back $1.98 to fix. Good Luck!
Jan 05, 2009 | Gaggia Baby Espresso Machine
My horn doesn't work
check the fuses wiring and make sure you put the right size fuse in it they might have gotten ahold of the wrong book for your car and they keep puttin the wrong fuse in it
Nov 13, 2008 | 2000 Chevrolet 2500
Reverse Sensing System doesn't sound
To test the speaker touch the wire terminal a 9 volt battery tester, make this by soldering wires to any 9 volt battery, then touch momentarly the battery leads to the speaker, the cone will move and make a slight pooping noise.
Oct 16, 2008 | 2005 Ford F-150
Maytag Neptune Gas Dryer
You have a Hi-Limit t'stat located at 12 o'clock on the flame shroud. A safety fuse is also located on the flame shroud at 1 o'clock. The flame sensor is located at 9 o'clock on the flame shroud. The Hi-Limit can be temporarily bypasses for a quick check, as well as the fuse, but do 1 at a time. Be sure to unplug the dryer before testing.
If that doesn't help, let me know if you need more assistance.
Dave E. (Illeagle)
May 30, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag neptune breakdown
Warning! Shock Hazard! Disconnect dryer from power source before servicing.
I assume you repaired a wire that attaches to a white ceramic insulator terminal? If you have a volt-ohm meter, you can check continuity of the element and hi-limit thermostat and overtemp.fuse located on the element shroud. If you ddon't have access to a meter then visually inspect the element for a break in the coil. The fuse and hi-limit can be temporarily bypassed 1 at a time to eliminate 1 or the other being faulty. Also double check your heat temperature settings on the control panel to make sure it did not become de-selected. There are also temperature control thermostats attached to the blower housing in lower left corner of the dryer that can be temporarily bypassed to test for failure. Tip: Clean lint filter after each load. Clean vent to outside,(check every 3-6 months), and refrain from overloading dryer. This will help extend the life span of the element and the dryer itself.
Hope this helps!
May 26, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
