Question about Apple iPod nano 3rd Generation
Cannot eject I plugged my ipod into my computer 8 hours ago. Got a low battery message. Syncing was completed, but I still get "Do not disconnect" message. Message in iTunes says that I cannot eject it because it contains files that are in use  by another program. Can recharging battery take more than 8 hours?
  • 44 Answers
The battery shouldn't take that long. Can you see if you have the newest firmware for your iPod? Sometimes when Apple releases a newer version of iTunes a firmware has to be applied to work with older iPods.
Click on the iPod icon in ITunes and check the settings tab in the larger window pan. Click the button Check for update.
You could always shutdown your computer and then disconnect the iPod. If the screen still says do not disconnect when the computer is off, hold down the play center buttons, untill it restarts.
Posted on Jul 23, 2008
Itunes freezing when ipod is connected
Need to reformat your ipod - don't disconnect the ipod until you hit eject - ever you should be able to use it again try a different cord and reformat then have fun cause you get to reload all the music unless you were able to save your iTunes library
Jan 16, 2013 | Apple iPod classic MP3 Player
Ipod is disabled
Plug the iPod USB cable into the bottom of your iPod.
Plug the other end of the iPod USB cable into a free USB port on your Mac or PC.
Open the iTunes application by using the dock icon on a Mac or the start menu on a PC.
Click on the name of your iPod under the "Devices" list in the main iTunes window.
Click on the "Sync" button to create a connection between the computer and the iPod.
Click on the eject symbol after the syncing process is complete, and then unplug your iPod from the computer.
The lock code has been reset; when you go to disable the iPod again, you will be prompted to choose a new four-digit code.
hope this helps
Oct 08, 2012 | Apple iPod touch Second Gen (8 GB,...
How to unlock my ipod
hope this helps
Oct 03, 2012 | Apple iPod touch Second Gen (8 GB,...
How to add new mp3 songs
Install iTunes
Before you connect your iPod shuffle to your Mac or PC computer or use it, you must install the latest iTunes software.
2. Connect and Set Up your iPod shuffle Charge your battery by connecting it to an Apple iPod Power Adapter or connect your iPod to a high-power USB port —one that's located directly on your computer—to ensure that your computer charges your iPod battery. (If your computer doesn't seem to recognize your connected iPod , wait about 30 minutes to allow the iPod battery to charge before going further.)
3. Fill your iPod shuffle and iTunes with Music Once you finish the set up, iTunes will open. It will then either:
  • Automatically start filling your iPod with music from your iTunes library (if you set iTunes to automatically update your iPod)
OR
  • Allow you to pick and choose what music, audiobooks, and podcasts to add, if you opted to manually manage music on your iPod.
To manually add content, simply drag any file from your iTunes library or playlist to your iPod icon in the iTunes Source list. If you're using iTunes for the very first time, you'll need to add some music to iTunes first, such as songs from your own CDs or music already on your hard drive.
4. Disconnect your iPod shuffle Once you've got your music, audiobooks, and other files on your iPod, you're ready to enjoy it.
  • If you see an “OK to Disconnect” message on your iPod, simply disconnect it from your computer.
  • If you see a “Do Not Disconnect” message, click the eject icon that appears next to your iPod icon in the iTunes Source list and then disconnect your iPod from your computer when you see the “OK to Disconnect” message.
  • Disconnecting my iPod shuffle
5. Play your iPod shuffle Now you’re ready to enjoy your iPod.
Sep 14, 2010 | Apple iPod shuffle MP3 Player
My ipod it showing a message that of : connected
If your ipod is frozen on the screen with this message then you might have disconnected your ipod from computer while it was either syncing or playing.
Anyways, make sure your ipod is not connected with the computer and on the ipod, press and hold the middle and menu button together until you see an apple logo on the ipod's screen.
Let go the buttons when the apple logo appears on the screen. That step reset your ipod and in most cases that fix the issue.
In case you still have the same problem even after that step, then call AppleCare at 1800-275-2273
Hope that answers your question
Apr 05, 2010 | Apple iPod nano
Do Not Disconnect is displayed
This is not a problem. The ipod is either syncing or backing its settings.
Once the activity is completed you can disconnect the device. On 1st Gen ipod, this 'do no disconnect' continues to appear even when the device is not syncing. However, it can be disconnected without problems. Click on the 'Eject' logo next to the ipod symbol in your itunes application window. Your device will now disconnect.
alternately you can also disconnect by removing the cable directly however please make sure that there is no activity taking place on your device. iTunes display window at the top of the application windows should be blank/clear.
Jul 17, 2009 | Apple iPod MA446LL/A MP3 Player
I just got a ipod shuffle and i want to add songs to it but dont know how to can you help me Please
I have an I-Pod Shuffle and I do not know how to use it. It did not come with a manual. Please help me.
May 04, 2009 | Audio Players & Recorders
IPOD Classis 80 GB not syncing completely
try holding the menu button and center button for ten to twenty seconds. make sure you are disconnected from computer 1st. this will cause the ipod to reboot.
Mar 10, 2009 | Apple iPod MA446LL/A MP3 Player
New replacement battery won't charge.
What you can try is to connect it to your Desktop computer USB port at the rear of you computer and charge it for 8 hrs atleast..
then try this step once
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step
and also try this at last
  1. Ensure that you have an active Internet connection as new versions of iTunes and iPod Software may need to be downloaded to your computer.
  2. Download and install the latest version of iTunes if you do not already have it installed.
  3. Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
  4. After a few moments, your iPod will appear in the Source panel in iTunes.
  5. Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows.
  6. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software. The 4 possible restore options are:
    • Restore Option 1: Restore - Restores with same iPod Software version already on iPod.
    • Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available.
    • Restore Option 3: Use Newest Version - Restores with the latest iPod Software available.
    • Restore Option 4: Restore and Update - Restores with the latest iPod Software available.
  7. If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password.
  8. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring.
    • Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
    • Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models).
  9. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
  10. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Nov 12, 2008 | Apple iPod MA446LL/A MP3 Player
Do not disconnect... nothing worked
In iTunes, you should be able to change the iPod to sync manually. that way, you can personally drag and drop your files into the iPod. You'll still have the DO NOT DISCONNECT on the screen, but it will sync easier.
Aug 31, 2007 | Apple iPod nano
Apple iPod nano 3rd Generation Logo
59 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
