Question about Microsoft Xbox Console
BeniS error 7 can some boby helpmy
Eny all that you tellme i was made .the firt problem was eeprom eresed from hhd whith backup y restore the eeprom and last y get erro7 is a ****.if i flash de bios or another jurasic accion what goin to hapend.xecuter is the solution?
and i from in uruguay sudamerica here is verry expensif xbox lake to sendyou.for this reson y meke the cuestion .please helpme .thanks for all for your time and ....good lake god blesing you
Posted on Jul 26, 2008
  • 62 Answers
7 - kernel - HDD timeout
Most of the times, the IDE cable is not properly connected when you see this error. Please reattach the ide cable. Not only to the harddisk drive but also to the dvd drive. ALso try to reconnect the ide cable to the motherboard.
Press pretty hard so it goes all the way in. Make sure it is seated straight and proper in the drives and the motherboard. If you still have an error 7. Try another ide cable. If still no succes, good luck and sell your xbox to me
Posted on Jul 24, 2008
Ineed to helpmy jayco slide in and out by pushing .couldthe motor be weak
make sure all the guides are well lubricated also your battery(s) must be full charged it does not matter if your plugged in to ac the slide out motor runs on 12v
Mar 15, 2015 | Cars & Trucks
Pls help,,my phone always insert sim and demo
your sim cant reach the connectors.
Take phone apart wash all connectors
with Isoprophanol to get all moisture and greese
from the connectors.
This will work. Vote!
May 12, 2010 | Nokia 1600 Cellular Phone
Locked my phone
sir my phone I.M.E.I no is 358241038785679
Jan 12, 2010 | Nokia N72 Cellular Phone
Unit power up but no or weak laser benis naro
Hate to say it and not really being that helpful I know, but this sounds like a hardware fault.
From what I remeber they use a single line laser scanner and their CodeGate technology to easily target the desired barcode, this can cause a few problems, but it can be fixed.
If you need any more help then please do not hesitate to contact us:-
helpdesk@biastechnology.com or TEL 01202 620955
http://www.biastechnology.com/
Jan 03, 2010 | Metrologic Instruments MS5145 Handheld
My Siemens WM14S791ME Frontloading washing machine had a message displaying that the pump was blocked. I drained the water out of the front, and found a bobby pin and a coin. Now I try to turn the washing...
F:23 means that there is a leak into the basepan of the machine and it should be checked by a competent repair person as sson as possible, the boby pin may have jabbed a hole in somthing or more likly there is a bad seal some were on the drum.
Apr 13, 2009 | Siemens WM14S794GB Front Load Washer
On the display is reads "check phone line" helpmy ohone set is 3 days old
replace the cord going to the wall with a known good working cord then try
Jan 21, 2009 | Panasonic KX-TG1033S Cordless Phone
Focus error
When that problem has happen to my Fuji A210 is because the slider that cover the lense has not gone all the way to the right ! I usually move the slider strongly 2 o 3 times to the left and to the right, and then turn the camera on. Fortunately, that trick has worked for me, so I hope it also works for you !!!
Nov 09, 2007 | Fuji FinePix A210 Zoom Digital Camera
My fridge is running but not cold
Is the compressor running? How about the fan motor? Chck. those items first and when there be sure coil is clean. Now coil is clean, fan and compresor are running, then you may have leak on the system. Quik test, unplug frige from wall and plug it back after a few second, if compressor runs, you have a leak.
Oct 24, 2007 | Nor-Lake Norlake Refrigeration 4' x 6'...
Hoover AAA 140
I have this problem too. Also i've had error code 5 come up as well. I think error code 3 is saying that pumping water out for so many minuites has failed. I've cleaned and run the pump out of the machine and everything works ok and there is no blockages. There still could be a problem when wired back in the machine. I have seen the pumped water coming out of the waste hose. Does anyone know if there is a sycro motor on the back of the controller or program selector that may be failing ? (ie: teeth worn off drive gear like you get on centrol heating valves).
May 17, 2007 | Hoover AAA140 Front Load Washer
Microsoft Xbox Console Logo
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
