External hard drive
If there is minimal damage to the drive do you think there is a chance I can retrieve the data?? I know it will cost $$$$ but it will be worth it to me!!!
  • 39 Answers
Try freezing the drive overnight. If your computer still does not recognize the drive after you try this, there is nothing you can do on your own. You will need to take the drive to a specialist . Basically what they'll do is take the drive apart and read the data off the discs in a highly sterilized clean room.
Posted on Jul 23, 2008
Can I retrieve data from a non-working hard drive?
There are people who can retrieve data from dead hard drives but it can be costly so get quotes first-- look in the phone book
other than that the data is long gone
Feb 10, 2016 | Power Computers & Internet
Tip
Data Recovery (possible) from faulty hard drives
DAMAGED HARD DRIVE - DATA RECOVERY
Data recovery from faulty hard drives is difficult and can be costly. There is no guarentee that you can recover data from a faulty hard drive.
If the hard drive makes a clicking noise the the hard drive is dead.
First thing to try, is to remove the damaged hard drive and connect it to an USB hard drive adapter and then plug this adapter into a working computer's USB port. If this computer sees this hard drive as an USB mass storage device (external hard drive) and you can open the various folders and files, then I would backup your data.
If the hard drive is not detected then the hard drive is dead and data cannot be retrieved with this method.
Retrieving data from damaged hard disk is possible. There are companies that can remove the disk platters from the damaged hard drive and with special equipment may be able to recover your data, but it will cost you an arm and a leg for their services. The reason for this high cost, they dismantle and remove the platters in the hard drive in a clean room environment and set up the platters up in jig/drive to retrieve/copy the data.
on Jun 11, 2010 | Computers & Internet
How can I recover my files after I drop my external hard drive?
First of all - STOP using your WD drive immediately! If you continue using the disk drive, you significantly increase the risk that the files you want to recover will be lost forever due to overwritten. Every new file or action will take up more "free space" and reduce your chances of retrieving your deleted files from WD. So really, you need to act quickly.
The next step - get a good HDD data recovery software to retrieve the data as most as possible.
Learn more from: http://www.western-digital-data-recovery.com/
Jun 22, 2012 | Western Digital My Book Essential 1TB...
Retrieving data from dead hard drive
Retrieving data fromdamaged hard disk is possible. There are companies that can remove the diskplatters from the damaged hard drive and with special equipment may beable to recover your data, but it will cost you an arm and a leg for theirservices. The reason for this high cost, they dismantle and remove the plattersin the hard drive in a clean room environment and set up the platters up injig/drive to retrieve/copy the data. First thing I would try isto remove the damaged hard drive and connect it to an USB hard drive adapterand then plug this adapter into a working computer's USB port. If thiscomputer sees this hard drive as an external hard drive and you can open thevarious folders and files, then I would backup your data. If the hard drive is notdetected then the hard drive is dead and data cannot be retrieved with thismethod.
Aug 14, 2011 | Computers & Internet
Hi, yesterday my hitachi external hard drive is fallen to the floor and after that it is doesn't work. but the lights are working. i want know can i take my old data from hard disk and can it...
Dropping hard drives is a sure way of damaging the drive. There is no way us mortals can repair a damaged hard drive that has been dropped.
Jul 04, 2011 | Hitachi Computers & Internet
Lightning storm seems to have hit earthing or power system of my house (totally knocked out the power in 2 neighbours houses) Computer died, but all other electrical components no problem - including the...
Yes, it's fixable, no , it's not worth it - it will cost you to fix it almost as a new pc. To recover your files just take the hard disk out and put it in a external enclosure  - around $25 - and plug it in in another pc.You will end up with an external disk, just wipe all Windows related stuff and use it as a backup.
Sep 10, 2010 | Acer Ferrari 5000 Notebook
Beyond Micro BMMDU2 250 GB external hard drive not working
It is highly unlikely that it will work. A circuit board from the same make and model hard drive would be a better choice, but I think a fire damaged hard drive would not work with a functioning circuit board. It depends upon how much heat the hard drive was subject to.
There are companies that can recover data from faulty hard drives, but it will cost you an arm and a leg for their services. Depending upon how valuable your data is, I suggest you get a quote first.
Apr 01, 2010 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
Lacie 500 gig external hard drive
Yikes 500 GB is a lot of data to lose, especially if you have no back-ups. In case you have never seen the inside of one, a hard drive is a series of metallic/magnetized platters on a spindle and a series of arms (resembling those of a record player) for each platter which record and retrieve data in the storage sectors formatted on the drive platters. The top 3 enemies of hard drives are: Impacts - Heat - Magnetic Objects . . . these top 3 all prove fatal to your drives operation. I am guessing the impact from when you dropped your HDD jarred the arms from their position or even may have broken the reader head. The bigger the storage of the drive, the more fragile they seem to be. Once an arm is dislodged or broken, the drive cannot function... the damage is mechanical. An arm knocked from its point of origin when not in use or jarred durring data access can no longer properly know where data is or fins its original position. Dont waste time on file recovery programs if this is the case, they require an operational drive to scan leftover data. . if the damage is to one of the platters, you might have luck with a software recovery application, but the process is very very slow and will take days. You can try taking it to data recovery experts and it will cost you usually around $1.00-5.00 per gigabyte - pretty costly. My advice, See if you can RMA the drive if it was under warranty) to get a new drive . . . or even have the data retrieved if it was that important . . . other than that, move on and be more careful with external drives in the future. Look for drives that have good impact ratings if you have a propensity for clumsiness, even then, handle with care.
Mar 27, 2010 | LaCie External USB 2.0 500GB 7200 RPM 500...
I have an external freecom 400gb hard drive
The chances are that you would have burnt the Power IC's, so there might not be any damage to the Hard Disk itself. you culd try buying a cheap External Enclosure at the closest IT store or moun the Hard drive on to a desktop computer. you should be able to retrive the data.
Mar 25, 2010 | Computers & Internet
My external hard drive quit working. The light on
Its is normally tough to make external hard drive work after they stop working. Mostly you wont be able to retrieve the data. You might need to go to a specialist for that and it would cost you some bucks.
Feb 12, 2010 | Computers & Internet
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
