Question about Toshiba 35A44 35" TV
Toshiba 35a44 screen keeps jumping from tv to video 1, video 2, video 3 the remote wont respond or the buttons on the set
  • lgtrz26 Jul 27, 2008
    I am having the same issue . . . The TV will be on TV mode for about 1 minute then it starts switching itself to Video 1-2-3 mode. The remote doesn't work at all - anybody have a resolution?
I contacted Toshiba and they said to turn unplug the TV for at least a minute, if that didn't reset it, then they gave me a service to contact. So I unplugged the TV when I was going to be gone all day, and tried it when I got home, no change at all. I had a repairman come by and he said the problem were the buttons on the TV that had to be replaced. He quoted me $240/labor and $5 for each button to replace (7), considering I only paid about $500 for the TV in December of 2004, I decided to just get a new tv with a warranty. I ended up getting the LG LCD Tv.
Posted on Aug 02, 2008
Tv won't turn on or respond
the power supply is faulty, check the following for lekages
power transistor
rectifier diodes
fusable resistors
also griver transistors
Nov 25, 2008 | Toshiba 35A44 35" TV
Toshiba 35a44 Tv keeps going to demo mode
let the card be cleaned with sprit, some contacts are still holding down.
that will solve your problem
Nov 12, 2008 | Toshiba 35A44 35" TV
this is the closed caption set to text 1 2 3 or 4 go into the settings and either turn cc on to cc1 or turn it off
Aug 08, 2008 | Toshiba 35A44 35" TV
Help!
I don't know if this will help your problem, but we were having similar problems with our Toshiba 32A33. None of the buttons on the TV or remote worked, the volume would go up and down uncontrollably, it wouldn't turn back on unless unplugged for several hours
Try either taping a penny very firmly over the TV/video button on the set to keep it depressed at all times, or wedging a piece of plastic in it to keep it down (Cardpsycho's solution).  However you do it, keeping this button depressed solved every problem we had.
Jul 22, 2008 | Toshiba 32A33 32" TV
35 in toshiba 35A44
unplug your television,then hold together the menu and the vol+.then press the power on,when its on release together the menu and the vol+ buttons
Nov 01, 2007 | Toshiba 35A44 35" TV
Freeze
it is the problem of remote setting only. call somebody for help.
Sep 20, 2007 | Toshiba 35A44 35" TV
Toshiba TV 35A44 Volume Issue
I had the same problem, you'll probably find that that particular button will push further into the set then the others, this is due to the a weakening of a cheesy metal guide which directs the projection off the back of the button into the corresponding microswitch. This metal guide will bend and will push against the switch.My solution, (and it ain't pretty) was to unplug the set, remove the button( I used a dremel cutting bit), locate the guide,a small metal plate with a hole in it. Bend the plate toward the front of the set then tape over the hole. I haven't had the problem since.You WILL have to use your remote for further functionality of the volume, However all of the buttons seem to be inherantly poorly designed and will weaken over time, AVOID USING THEM!
Aug 23, 2007 | Toshiba 35A44 35" TV
What do I do for tv switching from tv to various video modes and cycling through set up screens
the tactile switches on the control panel cause this problem . they could'be stuck or have some kind of contamination like liquid. or just bad . cost to repair aroud 60.00 dls if this helps please let me know
Jun 12, 2007 | Toshiba 35A44 35" TV
Volume Issues with Television
toshiba 35a44 I had in shop would not turn on initially,when Qa01 was replaced I was able to turn tv on, but after a couple of minutes volume went all the way down, vol display bar on screen and power and menu keys would not work, remote control function did not mater. after replacement of QA02 mpu no results. desoldered volume down and up keys and sprayed chassis with flux remover on both sides of chassis and sumerged vol keys in alcohol solutions for 10 minutes, restored them in chassis and the problem was corrected. QA01 and QA02 did not had to be replaced there was a contaminant problem on solder flux that was causing the problem. kbzon
May 11, 2007 | Toshiba 35A44 35" TV
Remote help
What is the model# for your set? Find your TV set below: MODEL: CT90157 PN: 23306517 MODEL: CT-90157 PN: 23306517 23306495 this remote has the pic size button Originally supplied with models: 32A33, 32A43, 32AF43, 32AF44, 35A44, 35AF44, 36A43, 36AF43, TOSHIBA Used with models: 13A21, 13A21C, 14AF43, 19A21, 20A42, 20A43, 20A44, 20AF43, 20AS21, 24AF43, 24AX61, 27A43, 27A61, 27A62, 27AF43, 27AF44, 27AX61, 27AX61C
Feb 27, 2007 | Toshiba CT-90157 Remote Control
Toshiba 35A44 35" TV Logo
222 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
