Question about Linksys (NR041) Router
Error i had dsl and my internet on both computers worked fine then i switched to cable internet and ran my install cd for the router. WHen it was testing for a connection it had an error that said that i need to check all cable connects and try again.. i have checked my cables several times and tried again with the same result please help
Make sure that the Internet connection type of the router is on Automatic Configuration-DHCP so that the router can obtain an IP automatically since you are using cable service. Now, if your ISP gave you static information, (IP, subnet, gateway and DNS numbers) then just set the Internet connection type to STATIC IP and then put all those information in. (Assuming that you know how to login to your router's setup screen: Default IP of NR041 192.168.1.1)
Posted on Sep 26, 2008
    Sergeant:
    Champion:
  • 330 Answers
Sometimes they fight each other
Posted on Jul 23, 2008
I cannot connect my Belkin 54g to the internet at all. I followed the wizard and got the information from my ISP - user name and password. The wireless light works, the port shows that it working but the...
ghost2233_6.jpg Did you connect the lan cable to the right port ????
1. Shut down any programs that are running on your computer at
this time.
2. Make sure you have the following items at the computer that is now
directly connected to the cable or DSL modem. DO NOT CONNECT THE
ROUTER AT THIS TIME.
• The Easy Install Wizard CD-ROM
• The Router
• The Router power supply
• Category 5 networking cable
• This Quick Installation Guide
3. Turn off any firewall or Internet connection sharing software on
your computer.
4. Insert the Easy Install Wizard software CD into your CD-ROM drive.
The Easy Install Wizard screen will automatically appear on your
screen within 15 seconds. If it does not, select your CD-ROM drive
from "My Computer" and double-click on the file named "Setup" on
the CD-ROM.
5. Turn on your cable or DSL modem by reconnecting the power supply to The Wizard will take you through the completion of the process.
the modem.
6. Before plugging the power cord into the Router, plug the cord into the
wall, then plug the cord into the Router's power jack.
7. Verify that your modem is connected to the Router by checking the
lights on the front of the Router. The green light labeled "WAN" should
be ON if your modem is connected correctly to the Router. If it is not,
recheck your connections.
8. Verify that your computer is connected properly to the Router by
checking the lights labeled "LAN 1,2,3,4". The light which corresponds
to the numbered port that you connected your computer to should
to the numbered port that you connected your computer to should be
ON if your computer is connected properly.
Good luck
Mar 12, 2011 | Gateway Belkin 54g Wireless DSL/Cable...
I recently moved from Cable ISP to DSL ISP service. For the DSL service, I was asked to configure my Router to use PPPoE with Dynamic IP addressing. I also provided the router with my username and password...
The reason you have no internet is because the router is specifically for cable. your description contains errors what i think you mean is that you have gone from cable dsl to an adsl, correct me if i am wrong. Basically your modem connected to your router via an ethernet cable and then the router fed the wireless signal to your wireless devices or via ethernet through the 4 ports in the back. With adsl you have a feed from your phone line to an adsl modem so the only way for you to get the dsl router working is to have two ethernet leads connecting to your pc, one from the modem to the pc and one from the pc to the router. You would also need to setup internet sharing on the pc thats connected to both devices.
Either do it that way or buy an adsl router
Nov 10, 2010 | D-Link DI-624M Router (DI624MRE)
Setup of d link dsl-2740b on my computer
the dsl connection is your broadband signal. check the router box. if the dsl light is off or flashing on the front, the setup will not work. this light needs to be solid. remove all devices from telephone sockets in your house, connect just one filter and your new router to it. check the dsl signal, if the light is solid green. the problem is with the physical setup in your house. If the dsl light still flashes contact your isp or broadband supplier.
Apr 15, 2010 | Computers & Internet
Won't logon to internet through the router...
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Dec 16, 2009 | NetGear Cable/DSL Router with 10/100 Mbps...
MY COMPUTER WILL NOT ACKNOWLEDGE THE LINKSYS ROUTER FOR INSTALL,
What were yo doing exactly when windows says router not found?
to access the router open internet explorer and type in
http://192.168.1.1
username admin
pass admin
unless you change the above, use the details that you created.
Jan 31, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
I cannot install the CD for my router
u can simply connect connect modem to internet port on router and connect no 4 of linksys to computer and u will be able to go online ....
Oct 22, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
I lost my belkin install cd
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
if you are still having trouble configuring your device, call supportrix and use supportcall as your promo code for 1 free technical support.
Jun 02, 2008 | Belkin (F5D7633UK4A) Wireless Router
Help
Wireless router installation
Apr 19, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Im haveing a problum hooking it in
hello!
Step 2: Unplug the router’s power cable.
Step 6: Power on the computer on and test the Internet connection.
Apr 07, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Lost internet connection
Power off the router by unplugging it. Also power off the DSL or cable router. Shut down the PC. Located on the back side of the router is a small reset button. Using a pen press and hold for ten seconds. Same for the DSL or cable. Power every thing back up starting with the DSL/cable, than the router and lastly the PC.
Dec 16, 2007 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Linksys (NR041) Router Logo
87 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
