Question about JVC Audio Players & Recorders
I have a JVC cd portable system ( mod. no.PC-x-100 ) made in 1990 I need to geta CAp stan belt & a rewind belt for my system to work properly I can't seem to find these parts
Regarding the pc-x100,did you get it fixed?
Posted on Jun 28, 2009
Tip
How to Put/Convert JVC, Panasonic, Canon Camcorder Video to Mac, MOD to MP4,...
Canon, JVC, Panasonic, most of these types of camcorders recorded videos are MOD files(some are TOD used by JVC), such as Canon FS100, FS10, FS21, JVC GZ-MC100 (SD), GZ-MG630, GZ-MG680, Panasonic SDR-SW21, SDR-SW20, SDR-S26. If we want to enjoy videos shot with these JVC, Panasonic, Canon camcorders on Mac, PCs, iPad, iPhones, or other popular portable players, we shall meet the problem that MOD files recorded in JVC, Canon, Panasonic cannot be directly recognized in Quicktime on Mac, in iMovie, and other Apple products.
MOD files, encoded by using MPEG-2 video codec with AC3 audio codec, need converting to MP4,MOV, AVI,DV, H.264 on Mac. With a MOD Video Converter for Mac , you can freely convert JVC, Canon, Panasonic MOD files to Mac MP4, MOV, DV, etc. What’ s more, Mac MOD Video Converter can edit MOD files in iMovie, FCP , FCE , etc.
The following tutorial for you to convert JVC, Panasonic, Canon MOD videos to Mac step by step.
Step1: Upload MOD files
Click "Add File" to load MOD files that you selected after you lauched Mac MOD Video Converter.
Step2: Set Output Video Format on Mac
On the "Profile", you can click to select your final video format like MPEG-4, DV, MOV, H.264, etc for Mac.
Step3: Transfer MOD Files for Mac
Click "Start" to convert MOD videos, after waiting for a few minutes, you can watch converted MOD files on Mac.
Tips: Besides converting function, you can edit MOD files on Mac OS with MOD Converter for Mac, for example, crop video, edit video effect, merge several video files, trim video, etc. More details you can refer to edit MOD files on Mac.
on Aug 06, 2010 | Computers & Internet
DVD not working
does not working means, have power but buttons don't work or no disc etc.?
May 29, 2009 | Televison & Video
Need to copy audio cassette onto my pc.
GET YOU A JACK TO PLUG RCA JACK S ,,FROM RADIO SHACK ,,,PLUG TAPE PLAYER TO CPUFOR AUDIO INTO YOUR CPU,,
May 12, 2009 | JVC Audio Players & Recorders
Play button no response fast forward and rewind work
THE capstain belts need changing to operrate the tape lifter mechanism
Dec 03, 2008 | JVC TD-W118 Single Cassette Deck
MOD file
The MOD file is just MPG format,
a simple MS-DOS command line instruction to rename your MOD files to MPG files (first copy your camcorder-harddisk files to PC-harddisk). I use to do the same!
Just execute the following command in the proper directory (or place this line in RENAME_MOD2MPG.BAT, and execute BAT file by doubleclick); the command assumes the JVC 3hexa-digit method of numbering:
ren MOV???.MOD MOV???.MPG
Oct 21, 2008 | JVC Everio G Camcorder
Problems editing files from JVC GZ-MG275AA
any alternativs? There is a very simple program that convert .mod NOT ONLY to mpg but many others like avi, mkv, flv, mp4, wmv, rm, rmvd, mov, dv, mg2 and swf. [b][url=http://www.iorgsoft.com/Mod-Converter/]MOD converter[/url][/b] is the one shoot all the trouble. This excellent mod conversion tool is not just a converter but also a video editing tool. From now on, with the MOD converter, you can enjoy your mod video on many media player, even on portable devices like blackberry, Gphone, PSP, Creative Zen,etc.
Apr 18, 2008 | JVC Everio GZ-MG20 Camcorder
CD Changer & Tape Deck
{11-30-13)
TO FIX THE CASSETTE DECK BELT PROBLEMS:
- Disassemble the player.
(you will need only one, long, phillips head screwdriver $5.00)
[It is a tedious job. (first,study how it is put together) There are 6 screws on the back - three down deep holes, three at the bottom, and two dark colored ones on the side. Once the front covering is off, then you start the process to get at the Cassette deck. You will have to unscrew a ground wire; pull the "tape" connections and one wire bundle snap fitting; and then unscrew the two screws on the back, near where the wires for the speaker connections are placed... then remove the Cassette Deck.]
{I sat in my recliner with the whole thing in my lap as i worked with a foot stool near by to put things as they came apart... and i used a metal salad bowl to through the screws into as i went along.}
- Study the drive mechanism.
- See where the drive pulleys are.
- Use small elastic bands to replace the broken belts.
(small = 1/2 inch diameter ... the size of your little finger, but will stretch out to two inches or so.)
https://www.google.com/search?q=small+elastic+bands&espv=210&es_sm=122&tbm=isch&tbo=u&source=univ&sa=X&ei=6rGaUrTlCszloASJw4KQBw&ved=0CGYQsAQ
I happened to have these on hand:
- I did this on my JVC PC-XC70BK and it worked.
- Both the player-side and record-side decks had broken belts.
[The fast forward and rewind wouldn't work on either side.]
(Per each deck: one drives play, one belt drives both Rewind & Forward)
- Now both decks work.
TO FIX THE CD PLAYER ISSUE:
- My guess is the laser pick up is dirty (because they all face upward and oily film builds up on them).
- First try a disk cleaner with a brush on the underside of it.
- If that doesn't work, then (after taking off the front plastic cover plate {see above}), you can see where the upward pointing laser lens is. If you can, use Rubbing Alcohol on the end of a Q-Tip to probe into the area and thoroughly clean its surface. Then wipe it clean with a dry Q-Tip.
- If you can't get at the laser lens, then Disassemble the Unite.
[There is another ground wire that must be unscrewed from the deck assembly. And there is the issue of the tape connections leading to the top part of the unit ... they will flop around and fall out of their place once you have pulled them from the connectors ... with a bit of observation you can get them back correctly.]
- Unscrew two screws at the back ... then pull out the tray assembly.
.... then go as far in the disassembly as you need to so you can swab the laser lens with the Rubbing Alcohol.
- Re-assemble. I had one screw left over.
... ROTFL but i know where it goes and i don't care to get it there... so to hell with it, right?
Everything works fine now. Not bad for a 17 year old piece of equipment that has a Ten CD storage tray... that you can't get anymore... right?
Oct 02, 2007 | JVC MX-J900 CD Shelf System
Cassette player will not work
common fault on the JVC tape decks is the belt stretch and then it does a clicking sound its trying to pick up the audio heads. changing the belt is quite hard if you have`nt done it before.
craig:)
Sep 09, 2007 | JVC MX-J900 CD Shelf System
203 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
