Question about Brother Office Equipment & Supplies
I get a white line on the printed pages on my Brother MFC4800. The line is about 5mm wide and runs down the left hand side of the paper, cutting through the type. Can you help please
    Novelist:
  • 158 Answers
Try cleaning the optics and the charge corona. If you do not have the operators manual which outlines the proceedure, go to www.welcome.solutions.brother.com. The proceedure is in the CLEANING documentation. Make sure the wire cleaner is pushed all the way back to its home position. Otherwise, the white line may return if the cleaner is left in the expoure path. IF THE WHITE LINE APPEARS ON PRINTED PAGES GENERATED BY YOUR COMPUTER, THE WIRE CLEANER IS THE MOST LIKELY CAUSE.. IF THE WHITE LINE APPEARS ON PRINTS THAT WERE SCANNED USING THE BROTHER SCANNER, THE OPTICS MAY BE SMUDGED. LOOK FOR CORRECTION FLUID ON THE GLASS **** (THE NARROW SCAN GLASS). THIS IS THE USUAL CAUSE.
Posted on Jul 23, 2008
Epson PX650 not printing the full A4 page of my receipts, cutting off on right hand side
COULD BE THAT THE PAPER IS BIGGER SIZE THEREFORE CUTTING.NEED TO SAY FIT TO PAGE ON YOUR PRINTER DRIVER
Nov 18, 2013 | Epson Aculaser C1100 Printer
Printer jams only when I put paper into the tray, and not when I feed the paper manually
in your paper feed tray there is a paper separation pad which is setup on a spring.just scratch it with some fine sand paper and clean with IP solution.
May 27, 2012 | Brother HL-2040 Laser Printer
Thick black vertical line appears on the right hand side of the page
PLACE A PLAIN PIECE OF WHITE PAPER IN MACHINE AND TAKE A COPY. IF NO LINES ARE ON IT THEN THE LINES ARE COMING FROM THE MACHINE THAT IS SENDING TO YOU BUT IF U DO HAVE THE LINES THEN PRINT HEAD IS PROBABLY FAULTY OR DIRTY.
Sep 13, 2010 | Brother FAX-1020e Plain Paper Thermal...
Leaving a wide black line in right hand side of transaction
Pop open the fax document feeder, and look for a glass strip about 1cm wide, that runs from left to right across the machine.
You will probably see a few spots of dirt, or more commonly, a blob of white liquid paper stuck on the glass, on the side of the machine that corresponds to the black lines on your fax.
Clean this glass strip gently, using a soft cloth dampened with a mild detergent. I often use diluted windex. You may need to scrape liquid paper gently with your fingernail. Close the cover.
Next, put a blank sheet into the feeder and make a copy of the blank page. If you have cleaned it properly, the copy will be blank as well. If you still have a line, align it with the feeder and use this as a guide to show you where the glass may still have some **** stuck on it.
Dec 04, 2009 | Brother IntelliFAX 4100 Laser Fax
Black line 1cm in from margin when printing
this is a catridge problem so pls replace your printer catridge.
Aug 22, 2009 | Brother MFC-9420CN All-In-One Laser...
My epson rx420 only prints the left hand side of any document ??? Can any one help please . many thanks
have you set the page setup in document is same with page setup at print setup. Some new epson printer use paper sensor to measure the paper width. If page setup wider than actually paper inserted, the printer will print only half page. example : Your document 10 cm wide, page setup 20 cm, and you insert 10 cm paper wide. It will print only half of 10 cm, 5 cm.
Jun 09, 2009 | Epson STYLUS R230 InkJet Photo Printer
3-INCH WIDE VERTICAL LINES RUND DOWN LEFT SIDE OF FAX MACHINE
Do your incoming faxes have the same marks?
If not you might find that the scanning part of your machine has a dirty mark on the glass or that the unit has become faulty.
Try and take a copy from the machine and print from a report or any print from memory.
If you have the black lines on both then i'd suggest getting a new drum unit, if u have it only on the copy I would have a look at your scanner glass and see if there is a dirty mark on it. if not maybe call out an engineer as the scanner unit maybe faulty.
Need anymore help msg me.
Dec 11, 2008 | Office Equipment & Supplies
Verticle line down left side of page
Printers tend to have this problem if for some reason dirt gets trapped under the print heads. A standard head cleaning is the best solution, which can be found in the menu.
Mar 18, 2008 | Lexmark X342n All-In-One Laser Printer
304 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
