Rank: Apprentice
Rating: 100%, 1 votes
I had the same problem. Turn on your laptop (dv2000) and let it do its thing with the black screen and One long and Two short beeps. Keep the laptop plugged in...Now here is where the "are you kidding me" part kicks in.
Wrap your laptop (while it's on) in a blanket and put it on a bed or a couch (where the laptop won't have room to circulate air beneath it). You must leave it wrapped in the blanket for about 30 minutes minimum, or wait an hour if possible.
Chances are, your laptop will get ver hot and shut itself down at some point before you come back in an hour. When the hour is up, try turning on your laptop again. Ideally, it should work and you now have a working laptop again.
I realize this sounds crazy, but I am typing this quick fix from my dv2000 after doing exactly what i just subscribed. I read it on some other forum when i was on my wife's pc. If this doesn't work the first time, try it one or two more times. This trick has something to do with getting a "broken" (?) connection between the video card and the motherboard soddering back together.
Hope this helps at least one of you. Good luck.
Comments:
