Question about HP Officejet Pro L7780 All-In-One InkJet Printer
White line down side of page when scanning
What could casue a white line about 2 inches in from the right border that goes down each page?
Thanks for your help.
TheaDG I have the same problem only my line is blue. I tried cleaning the glass to no avail. Any other suggestions?
I chatted with HP and they told me to clean the ADF frame which had some dust particles on it. Problem solved.
Posted on Jul 23, 2008
There is a line down right side of projected image, from top to bottom, different computers. Thanks Loren
I have a 2 inch white line down the middle of the screen from my Infocus DPL projector.
Can you help?
Paul.
Nov 29, 2010 | Optoma EP771 DLP Projector
Printer ignores white space at beginning of document
by dragging the black bar on the left with your mouse when
the cursor changes for resize
Nov 30, 2007 | Office Equipment & Supplies
1/2" white line appearing down right side of page
Try replacing the toner cartridge. This seems to be a problem with the photo-sensitive drum, which is located in the cartridge.
Jan 05, 2010 | Dell 3100cn Laser Printer
Blue line down the right side documents
your not getting the cover closed all the way use the scanning software to make the scan go to the border of the paper onlt and then do a view print to be sure it is the correct size.
Nov 13, 2009 | ScanSoft PaperPort Deluxe 9...
Lines on screen
This happened to me once too. It is something with the monitor, which needs to be cleaned inside, that is all. Just take it to a mechanical store and they will fix it
Aug 09, 2009 | Gateway 500 CS PC Desktop
When scanning or copying from either the ADF or the flatbed, my 7310 puts a black line all the way down the right side of the page exactly 1 1/2 inches from the right edge. I have cleaned the glass (and...
You can check the white guide bar that sits above the glass, any marks on there will leave a streak because it is the white reference for the scanner. after that you will probably need a new scan assembly because sometimes single elements will burn out.
Aug 07, 2009 | HP OfficeJet 7310 All-In-One InkJet...
I print borderless several times & found white border both side
This is because the image is of a different aspect ratio than the paper. That is, if your image's dimension is 8x12 inch and you are trying to print it on an 8x10-inch paper, the printer will adjust the longer side to 10 inches. Hence the shorter side will become less than 8 inches. This will lead to white border on the shorter side. If you try to adjust this, the longer side will fall out of the paper and hence in the print, this portion will be cut.
So please understand that this is normal. One option to prevent this is to crop the image to fit the paper size.
Apr 13, 2009 | Epson Stylus Photo R200 InkJet Printer
Thin black line 1.5 in from the right side of the paper going down the whole page
If it doesnt have a line on it when you scan it and open up the document then it's not going to be a scanner issue, more then likely, it's going to be an issue with the toner of the printer you are using to print with. Check the drum on the toner and you'll probably see the line in question on the drum itself. You'll just have to push back the flap that covers the drum on the toner if this is a laser printer... hope this help's if it does, please mark as a FIXYA!!
Oct 06, 2008 | Canon DR-9080C Path-Through Scanner
If this is happening only when you are scanning using the automatic document feeder, check for something blocking light above the scanner. If you open the scanner top, look along the left side of the scanner glass where the paper is scanned by the automatic document feeder. If you see anything on the glass there, clean it with a soft cloth dampened with clean water.
Jun 10, 2008 | Canon PIXMA MP830 All-In-One InkJet...
DR 2050C
This has something to do the brightness chosen. In the manual mode, if you choose a dark output, the output will have tis area also; if you choose, lighter output, it will omit. In the auto scan mode, the scanner decides what is the best output.
S. Mohan
Dec 19, 2007 | Canon DR-2050C Path-Through Scanner
HP Officejet Pro L7780 All-In-One InkJet Printer Logo
100 people viewed this question
Seeker5211
Seeker5211
