Question about Kenmore Elite HE4 Electric Dryer
GE Hotpoint Dryer NVLR333ET0WB
Patched together broken heating element and started dryer. Caught fire in heating element area and stopped working.
I have probably blown a fuse or safety switch of some kind. Any guidance?
Thanks, George
gajohns73@copper.net
  • gajohns73 Jul 23, 2008
    I have replaced the heating element and now it will not work at all. The only noise that happens is you can hear the timer working on one of the cycles.
    how do I check it?
    Genius:
  • 1,028 Answers
Ck for thermal fuse on outer edge of element housing it usually a small round disc
Posted on Jul 23, 2008
Where will I find the heat reset button on my tcm580 condenser dryer
Hello Mandy, I am not sure what you mean by a heat reset button; perhaps explaining what the problem is, I may be able to assist you. Are you referring to the dryer motor's overload reset button? As a safety feature, a dryer has a high-limit thermostat and either a thermal fuse or thermal cut-off fuse.
In the event of poor air flow where there is no proper ventilation to the heating element- the internal temperature of the dryer exceeds its high-limit, the dryer will shut-down; once it cools off, you should be able to run it again.
However, if the thermal fuse (located on the blower housing) or the thermal cut-off fuse (located on the heater housing) goes, the dryer heating element will will not heat up or the dryer will stop running altogether.
Please note, a dryer will have either a thermal fuse OR a thermal cut-off fuse, but not both.
By-the-way, there has been a recall on certain models of HotPoint Creda, and Indesit tumble dryers due to a fire hazard risk; I am sending you the link...If your dryer is manufactured by HotPoint model TCM580, then your dryer maybe affected. Read the info in the link- it'll give you instructions on how to determine if your specific dryer is affected and what to do.
http://www.which.co.uk/news/2015/12/113-hotpoint-indesit-and-creda-tumble-dryer-models-pose-fire-risk-426557
http://www.itv.com/news/2016-04-18/hotpoint-dryer-fire-risk-which-models-are-affected
Feb 15, 2017 | Dryers
My Hotpoint tvf770 starts but does not appear to heat and it stops after a few minutes. I have checked the filter and exhaust tube for blockages, both clear.
Suspect a broken/burned off wire to the heater element, or 'open circuit' of the heater element, or thermostat fault
Oct 15, 2013 | Hotpoint TVF770 Tumble Dryer
Hotpoint dryer (nvl333eyoww) not heating
The thermostat and element are mounted on the back wall of the dryer. To gain access you must remove the drum. Here is my home movie:
My home movie and repair photos for GE hotpoint dryers
Dec 02, 2012 | Hotpoint Dryers
GE dryer, no heat?
Your heating element is most likely burned out . Have you made certain all of your lint vents for the dryer are not clogged ? Also , be certain to clean the lint filter every time you use the dryer. A buildup of lint in the dryer , in the hoses & on the back of the dryer inside in between the drum & the outer covering can get so hot it will catch on fire when the heat is working , and also , without a fire will burn up your heating element.
May 18, 2012 | Dryers
Replaced heating element and it still wont fire up
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Aug 02, 2010 | GE DVL223EBWW Electric Dryer
My hotpoint ctd40 has stopped heating again, the
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Dec 22, 2009 | Washing Machines
NVLR333ETOWB HOTPOINT DRYER EATING CLOTHES
Very likely the front support bearing is worn through and cracked there are also three drum slides that are positioned on the bearing which very likely worn to nothing and will need to be replaced as well. For model # NVLR333ET0WB replacement part numbers are:
FRONT BEARING: WE3X77
BEARING SLIDES: WE3X87
Good Luck to you.
Jan 07, 2009 | GE DBSR453EBWW Electric Dryer
Not heating up
This looks like it is an older model. The normal place I check for parts doesn't stock the heating element. I found an alternative place but the part is $90.
The element is in the large round area that surrounds the drum assembly. Here's a diagram. The heating element is part number 512. The line doesn't reach all the way there but I think the element is the two dark rings inside the housing. Here the page with the parts listing. You'll note that the model number is the same but the brand is GE. GE makes hotpoint.
Sep 25, 2008 | Roper REX4634KQ Electric Dryer
My GE electric dryer's heating element will stay on when the dryer shuts itself off after running through a cycle. Even if the dryer is in the "off" position, the dryer will become hot to the...
It sounds as if your heating element may have broken in one area and fallen against the element shround and grounded itself out. This will cause the element to bypass the safety circuitry and continue to heat, but at a lower wattage. You were very diligent in unplugging the dryer.
You will have to replace the heating element. Do not attempt to repair the element as this will only cause a hot spot and will burn in two again.
May 28, 2008 | Dryers
Heating element stays on after door is opened
possibly something grounding the element to the housing. what brand of dryer do you have? GE/Hotpoint dryers are good at allowing things like underwires from a bra to get into the element area and ground out the element. or possibly the element has broken and the broken end has fallen against the housing. hope this helps
Oct 29, 2007 | Dryers
Kenmore Elite HE4 Electric Dryer Logo
286 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
