That doesn't sound good... make sure the wires have good connection to the battery terminals. If its not that then your gonna need a new starter...
The click you are hearing under the seat is the solenoid. Most likely it is bad. Luckily it is a very easy and cheap fix. You can always use the "shade tree" test to make sure. Turn the key on, lock the parking brake with the unit out of gear and use a screwdriver to jump from oe pole on the solenoid to the other. If it starts, the solenoid is bad.
