Question about Radio Shack Pro-2096 Base Scanner
Novice / 1st time
I am having problems getting the scanner to work. I have downloaded the software and really don't know where to begin. The manual that came with it, is not too useful for someone who doesn't know much about scanners.
  • 163 Answers
You are luck you even got a manual! Anymore most instructions are either on the CD or online.
First do not hook up the scanner(USB I assume) . Install the software first and follow the instructions for installing. The program should tell you when to hook up the scanner cable.
After that it is trial and error to learn the software for the scanner.
If you provide the scanner model I might be able to help more.
MM85
Posted on Jul 23, 2008
How do I use a Seiko electronic tuner?
Hi! Have you read the manual? That is a good place to begin. Maybe you did not get one (if you bought your tuner used, or found it, or stole it, or something). You did not mention your model number, but one of the really common ones is the SAT500. Here's a download site for its manual:
http://www.manualslib.com/manual/657760/Seiko-Sat500.html
Just stay cool. Concentrate on one thing at a time. And take your time. You will soon become a competent user. I think you will find it pretty easy, once you get a good start. Truly.
Jul 24, 2014 | Seiko Auto/Manual Chromatic Tuner...
HP PSC 1315 - TROUBLE WITH VERSION 4.2.0 INSTALLATION
Hi -- Hope this helps, it worked for me. Firstly, I strongly suggest you click http://www.revouninstaller.com/download-free-portable.php and save the file, then run the app. The built-in software uninstaller in Windows often leaves garbage behind in folders, files, and the registry that can make future installations fail. REVO is really good at getting rid of ALL of the crap so a clean re-install is possible. The above link is for their totally free portable version -- no crap and you don\'t have to install anything to use it. That said, uninstall all the software, then open your device manager and locate the entry for your device, right-click and select uninstall. DO check the box that says "delete the driver software for this device" so that you will be starting clean. After uninstalling, unplug the USB cable to your device and reboot.
After the reboot, Do NOT plug in the USB cable yet -- First, insert the driver CD and start the setup program. Wait until the software tells you, then plug in the USB cable and continue following the on-screen directions. Once everything installs, it may tell you to reboot, if so, don\'t try using the device until you do. After the reboot (or after the install finishes if it doesn\'t make you reboot) you should be good to go again.
I have had this problem repeatedly when trying to re-install drivers for various HP Products, and this has (so far, anyway) worked for me in XP, Windows 7 and Windows 8.
Good Luck!
Jun 07, 2013 | HP PSC 1315 All-In-One InkJet Printer
I cannot download my photos and movies from my FinePix S2900 to my computer. I have installed MyFinePix Studios. According to the owner's manual, once I plug my camera into the USB, MyFinePix Studios...
Paint Shop Pro grabbed mine using "Import from Scanner or Camera". They went to My Pictures and the first picture was on the PSP screen. See ya, FinePix software.
Jul 04, 2011 | FUJIFILM FinePix AX300 / AX305 Digital...
How do you program a radio shack to the 700mhz trunking chanels
You will probably have to use a '3rd party' SOFTWARE package. Mr. Donn Starr has written software for most of the GRE / Radio Shack scanners, and using his software will usually allow you to enter 700MHz frequencies. You will need the USB Scanner programming cable and software from Radio Shack, then search online for a link to get Don Starr's software. You might be able to try it out for free for a little while, but it is really worth the $30 for how easy it makes it to program your scanner once you get the doggone Radio Shack USB scanner programming cable configured to work with your computer. Let me know if you have more questions.
Mar 11, 2011 | Radio Shack Pro-2096 Base Scanner
Exact same problem
firstly I hope the model number is correct. if yes try once again the following steps.
disconnect the Docketport from usb. go to device manager and see there devices marked with yellow exclamation mark. remove them and restart the windows.
1. download the driver and install it
http://www.docucap.com/drivers/DocketPORT465_v1_1_4_setup.exe
2. secondly Docketscan application is needed ..download it too and intall
now try connecting the dockerport
I hope this should make things work.
Aug 07, 2009 | Syscan DocketPORT 465 Scanner
Will not cool on electricity
Hi there. There are actually a few causes of your problem but I would begin by checking the fuse. here is the Dometic troubleshooting manual for your model. It should help.
http://www.gasrefrigeration.net/dom_techdata/26121_2852SM.PDF
Jun 03, 2009 | Dometic RM2652 Refrigerator
S500 install for MAC
Check out:
http://forums.macosxhints.com/showthread.php?p=527817#post527817
The latest Fujitsu ScanSnap V2.2 L11 drivers have been patched by me to work with S300, S500, S510 and fi-5110EOX/2/3 PC-based scanners for the MAC. No need to buy a new scanner. Just apply the patch and then send me a Christmas card! ;)
Hope this helps!
Jan 16, 2009 | Fujitsu ScanSnap Manager
Scanner Problems
uninstall the device and reinstall it
you need to reinstall the drivers
Mar 09, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Radio Shack Pro-2096 Base Scanner Logo
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
