Question about U-Line 75WC Wine Cooler
U-line 75wc my unit quit working. i jumpered out the thremostat control and found it was the problem. I ordered online a new controller. They sent pt# 2767. The sensor is only 18" long which will not reach to the back of the unit where the origional goes. ? do I have the wrong part or do I have to drill and mount in the cabnet closer to the controller. It looks like they also supplied a retrofit kit
  • 286 Answers
2767-s is the correct thermostat for this. The only thing you will need to do is drillout the liner so the sensor can go in. Use permagum to seal around the hole. It should fit. You may need to bend the terminals 90 degrees.
Posted on Jun 15, 2009
My projector pt-lb10e cannot start up, the standby light is on but when try to press the on button nothing works. How can i reset the projector?
The "CONTROL KEY" may be set to "OFF".
In order to set the "CONTROL KEY" to "ON" without using the remote control unit, keep holding down the ENTER button on the projector and press the MENU button for more than 2 seconds.
Sep 16, 2010 | Panasonic PT-LB10E Multimedia Projector
Light comes on all by itself
You are probably picking up some kind of radio interference that is causing the receiver to think a remote has sent it a signal. A possible solution to this issue is to change the frequency that the remote uses to communicate to the receiver to turn the fan or light on.
I have had the same problem with the light coming on intermittently by itself. At first I also could not change the settings and have the remote work with the new settings. But I found out that when you change the dip switch of the receiver you must turn off the power using the wall switch or the circuit breaker and turn it back on before the receiver will use the new dip setting. I am still waiting to see if the light will come back on after changing the dip switches from 1-on, 2-on, 3-on, 4-off to 1-off, 2-on, 3-on, 4-on and the remote's jumpers from 1-jumpered, 2-jumpered, 3-jumpered, 4- no jumper to 1-no jumper, 2-jumpered, 3-jumpered, 4- jumpered.
These directions are for the Hunter 27157 model.
Aug 12, 2010 | Hunter 27185 Remote Control
Gets cold but does not shut off.
Check the thermostat to make sure its mounted on the evaporator plate. If its away then the sensor will never satisfy your control, Or you may need to replace the control
Oct 01, 2009 | U-Line 75WC Wine Cooler
I need to replace the metal racks in the u line 75wc refrigerator. They rusted in the back.
To order the racks you will need to order from a parts distributor. To find one in your location just visit U-line. www.u-line.com and under customer service you will see parts locator.
Sep 26, 2009 | U-Line 75WC Wine Cooler
Replaced control on u-line 75WC wine cooler now runs constantly
If the sensor of the thermostat is not on the evaporator plate then yes the thermostat will never be satisfied. Because it is not reading air temp only the evaporator plates temp. should be clamped onto the bottom of plate.
Sep 13, 2009 | U-Line 75WC Wine Cooler
I need to replace the door gasket on a U-Line 75WC wine cooler.
Most of the time they send instructions with the new gasket./
Jun 05, 2009 | U-Line 75WC Wine Cooler
U-line 75WC wine cooler - rust on inside back wall
This happens when the racks get too close to the evaporator. Or bottles. You can try to use hot water but usually you will need to buy new racks for the unit.
Sep 17, 2008 | U-Line 75WC Wine Cooler
U-Line 15WC Wine Cooler Problem
Cheak The Compressor relay is fault
May 20, 2008 | U-Line 75WC Wine Cooler
How do you open a Kenmore Elite Oasis top-loading washer?
I just finished installing my new control unit for my Kenmore Oasis and my F1 problems are GONE! I ordered it from Sears Direct Parts. With shipping and taxes it came out to about $174 for the part, but our issues are gone and now we can wash a load of clothes without having to reset it several times.
Mar 18, 2008 | Washing Machines
U-Line 75WC Wine Cooler Logo
618 people viewed this question
Top U-Line Furniture Experts
John Tripp
John Tripp
Michael Galve
Michael Galve
Sal De
Are you an U-Line Furniture Expert? Answer questions, earn points and help others
