Question about Friedrich QuietMaster RS10J10 Air Conditioner
Friedrich RS10J10-C: Only half the coils are chilled...
My Friedrich RS10J10-C room a/c does not cool the room, even after running overnight. However, the air coming out of the vents are cold.
I cleaned the filter and made sure the vent is closed, but it still does not cool the room. I noticed that only the coils in the bottom half of the unit are chilled (causing condensation on the bottom only).
Does this sound like a mechanical problem? How do you fix it?
Thanks.
  • 143 Answers
If the evaporator coil is only half coated with water, this means it is low on Freon. You need a repairman to fix the leak and add Freon, but this costs way over a hundred dollars.
Posted on Jul 25, 2008
Friedrich quiet master KS12L10 leaking water down outside wall and windowsill.
it may need coil cleaned. there is a drain hole under evaporator coil that might be stopped up.
Aug 12, 2014 | Friedrich QuietMaster RS10J10 Air...
Friedrich CP24F30 money saver mode not working
Money saver mode dose not regulate room temperature. All that mode dose cycle fan on and off with the thermostat if in the yes position then fan cuts on and off with the call for cool. if in the no position than fan runs all the time even when cool is not needed. that switch is like the auto/on on a thermostat for central air. the thermostat is what regulates temp in room.
Jul 01, 2014 | Friedrich Heating & Cooling
Unit wont get cold. motor running fine
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jun 08, 2011 | Friedrich QuietMaster RS10J10 Air...
Coil freezes up even on low cool..room does not get cool
dirty coils or low freon: clean coils off and out, they sell coil cleaner in a spray can, as far as needing charged, you will have to find a licensed a/c repairman, but honestly if it comes to calling someone, it is cheaper to buy a new one, Hope this helped Tim
May 30, 2011 | Friedrich QuietMaster SL28J30A Air...
Exhaust/Fresh Air Vent
Hello there :
ok i'll explain it like this if you have the lever on exhaust it will be just circulating the air that is all ready in the room and if you have it on fresh it will be drawing the air from the outside ok hope this helpes you understand how that works please dont forget to rate my solution.
best regards
mike
(USN) RETIRED
Aug 05, 2009 | Friedrich QuietMaster RS10J10 Air...
Friedrich air conditioner
Less efficent. Can you manually close it ?
Jun 07, 2008 | Friedrich QuietMaster RS10J10 Air...
Leaking water
water leakage from indoor unit
1.clean cooling coil
2. wash air filter
3. check drain tray.if it block then clean it
4. check drain pipe U band.
5.check indoor unit water tray.if damage change by new one or repair it
Sep 04, 2007 | Friedrich QuietMaster RS10J10 Air...
Friedrich QuietMaster RS10J10 Air Conditioner Logo
276 people viewed this question
Top Friedrich Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
