Question about Alpine Car Audio & Video
My IVA-D106E alphine screen is not turning on, after i had a flat batterey i charged the batterey but the screen is still not turning on.
Might want to check the fuses on the back of the radio or on the wires themselves , if your dome light doesnt turn on youve blown a fuse in your car
Posted on Jul 23, 2008
The laptop with the batterey,and pluged in it works,but the batterey is not charging,and without the batterey just the plug the laptop won't work.
Some laptops, by design, cannot work without the battery. It is possible that yours fall into this category.
As for the problem with the battery not charging while the laptop is plugged, please refer to the following article to diagnose & fix the problem:
http://www.fixya.com/support/r6395191-troubleshooting_laptop_power_failures_ac
Jul 13, 2011 | Computers & Internet
My triumph trophy 900 loses power and stops while riding it, but starts again straight away but its getting worse now, does my bke have a regulator rectifier or just the alternator unit, i have had my...
Do I assertain from your message that the battery is not charging? as if your battery is flat there will be no ignition. If the battery is being charged then check the fuel line filter. There is one in the tank inline with the fuel tap. It may be blocked and that moment or so with the engine at rest, may be enough to get you going again.
The battery voltage when fully charged and standing should be 12.8volts. A battery charging should be between 13.8volts and 14.5volts, no higher or else permanent damage to the battery will be done.
Hope this helps.
Nov 20, 2010 | 1992 Triumph Trophy 900
My motorola cliq just turned off and will not turn on i tried charging batterey but nothing happens the screen staays blacked out and the key board only lights up when plugged in to charger
my motorola cliq just turned off and will not turn on i tried charging batterey but nothing happens the screen staays blacked out and the key board only lights up when plugged in to charger
Jun 26, 2010 | Motorola Mobility CLIQ Cell Phone
In nokiya mobile 2626 not charging batterey
haw to ripeair not carging iwant jumper
Apr 16, 2010 | Nokia 2626 Mobile Phone
My laptop wont turn on
when you hit the on button the green light go off after a while, i suggest you bring it to technician your laptop is shutting down as it about to open, its either the sensor is not working and making it to overheat or the power switch is loose, hope this help
Sep 17, 2009 | Acer Extensa 5630-6806 Notebook
Alpine IVA-D310-navigation option?
The nav feature is purchased separatly with the deck, the previous owner did not purchase it because at the time alpine was charging an extra $1000 on top of the price of the deck to add nav. This is due to the fact that alpine decided to use there own reasearch and development team to design a nav system where as kenwood baught the rights to use garmin's technology and put there name on it which they only charge $400 on top of the price of head unit to add nav.
Mar 29, 2009 | Alpine IVA-D310 Car DVD Player
I bought a used Porsche with an Alpine IVA-W200 system already installed. The radio and CD player worked and I could hook up an MP3 player to a wire in the gloove compartment. The only problem was that the...
The expert I chatted with was both right and wrong: correct in that the problem was not the small battery in the handheld GPS unit (which feeds signal to the IVA-W200), but was incorrect in guessing the problem was due to a fuse.
I took the fuse out, it looked good, and put the same fuse back in. After that, everything works! Apparently, the IVA-W200 can freeze up (like a computer sometimes freezes) and it needed a cold start reboot. Removing the fuse completely for a few seconds (for examination) took power to the IVA unit down and back up again... voila'!
Dec 16, 2008 | GPS
Won't start...no clicking, buzzing...nothing
hello it sounds like batterey terminals need to be cleaned disconnect off batterey clean batterey terminals with a post cleaner cable terminals wire brush reinstall try to start check batterey for 12volts if not jump take it for a good ride or charge batterey goodluck
Sep 14, 2008 | 1994 Oldsmobile 88
I-scream mp3 player (AV-1)
This player uses batterey all the time. It can't be charged. Just put a batterey in the port on the back and it will work just fine.
Sep 21, 2007 | Coby MPC-848 MP3 Player
Car Audio & Video Logo
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
