Question about Microwave Ovens
GE spacemaker XL 1400 will not heat food power loevel set at 1 will not change to higher setting If THAT is the problem
Will not heat food at all ! everything else appears to be working
  • 1 more comment
  • edgington Jul 23, 2008
    does not run loader, trun table and light does work, just no heat
    Model # JVM1450WA001
  • Born4Beachin Jan 08, 2009
    Everything works properly except that it doesn't heat anything! Sure defeats the purpose of the microwave and can't find a "fix-it" solution anywhere.
  • William Miller
    William Miller May 11, 2010
    Do the inside light and turntable come on when you try to cook?
    Is it making any unusual noise or is it louder or quieter than normal?
    Do you have the model number?
  • Microwave Ovens Master
  • 8,973 Answers
If
it\'s within the magnetron portion of the warranty (usually 5-9 years)
but out of the original full warranty (usually 1 year), then your
manufacturer will cover the part cost, but not the cost to visit you or
the labor charge to do the work.
Since the turntable and light are working, the most common causes of a failure to heat are:
- loose or corroded connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron
- shorted high voltage diode
There should also be a "mini-manual" hidden inside the unit behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting & testing.
We\'re happy to help you and we\'d appreciate your
thoughtful rating of our answer.
Posted on Jul 23, 2008
Strange smell no heat
actually the two things you mentioned are a pretty reliable indicator :/
The only way to be positive is to check for power from the high voltage transformer. If you are not trained to work around electricity, i wouldn't mess with it because it can most certainly kill.
if there is no power coming from the HV trans, you then trace power back toward the cord. The component that has power going in but not coming out is the culprit.
Apr 20, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacemaker XL 1400 wont heat, controls work, no heating??
This sounds like a thermostat or magnetron tube
is shot.
Feb 27, 2010 | GE Microwave Ovens
Not hot
In all likelihood the mangnetron has failed, or perhaps even the Power Supply. or a fault that is shutting the system down for safety reasons You need to have it serviced by a reputable service centre/man. Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
Feb 20, 2010 | GE Spacemaker JVM1740 Microwave Oven
Ge spacemaker xl 1400 microwave stopped heating & there is an odor like melting plastic Can it be repaired. Is it worth it to repair. Unit is 8 years old.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fgkjf
Dec 07, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Wont heat food
It could be that the "grinding" noise was actually "arcing" taking place inside the cavity or uder the cover. The magnatron is possibly damaged or the h.v. diode. Should be repaired by qualified repairman
Sep 12, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL 1400
First, wipe out any excess crumbs. Then fill a microwave-safe bowl with about 1-2 cups of water. Add some lemon juice, or put in half a piece of fresh cut lemon (squeezing some juice out first) into the bowl... Microwave until the water is boiling. Then let it sit for a few minutes to let the steam penetrate the interior. Carefully remove the bowl and interior tray. Wipe down the interior with a damp cloth. Wash the tray in the sink with dish soap, dry, and then return to microwave. For the outside, spray with a kitchen cleaner and wipe with paper towels. The main idea is that the steam from the water will loosen food particles, and the lemon will add a fresh smell.
Jun 23, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Glass turntable won't turn - spacemaker - XL 1400
Most likely a bad turntable motor - check with www.martinmicrowave.com for a replacement .
Dec 23, 2008 | GE JVM1440 Microwave Oven
Microwave oven does not heat anything. Clock, turntable, lights work. I turned the turntable off while the oven was cooking--heard a noise, now it doesn't heat anything.
Spacemaker XL 1400 worked for 7 years.Yesterday, no more heat. Also plastic door damaged.
will try Panasonic or something commercial
Jul 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
No heat in GE XL1800 1100 Watts microwave
model # JVM1870BF001 GE Profile spacemaker XL 1800 microwave
after episode of using defrost which burned food--now stopped heating--still has power/fan--don't know how to change fuse--please help
Jun 21, 2008 | GE XL1800 1100 Watts Microwave Oven
GE Spacemaker XL 1400 Microwave
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Nov 27, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
794 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Are you a Microwave Oven Expert? Answer questions, earn points and help others
