I m using Nokia N72. i m having a problem "memory full close some applications and try again" . the error occurs wen i press message,gallery or settings. i m not able to access anything in my cell.
internal memory of cell is 20 mb n only 10 mb is used. it doen't contain any music or video files in it. i want to restore my cell without formatting it. is there any soltion to my problem? pls reply me on [email protected]
The phone needs to be formatted .... take backup and then press *#7370# ...default code 12345 ...the phone will restart ...after which try again
2.)or if not Go to application manager. Open settings. Make sure : software installation is set to "ALL". And online certification check is set to "OFF".
Everything seems issue with phone's internal memory..
first, make sure you are not keeping lots of apps open.. press and hold menu key.. try closing them..
check how much space left in phones internal memory...
move data (SMS ,contacts, pictures or videos) from phone memory to memory card..
Follow the steps : Press the Menu button (oval-shaped icon) on your keypad, and then select "Tools." Select "Manager" from the Tools menu. Scroll down and find the program you want to remove. Press "Options" and choose "Remove." At the prompt, select "Yes" to confirm. This will uninstall the program from your Nokia N72.
PRESS MENU BUTTON LONG TIME AND THERE ARE APPLICATIONS SHOW IN LINES THEN PRESS "C" BUTTON OR CLOSE IT. THEN SAME PROUBLEM SO INTER CODE *#7370# OR FORMATTE UR CELL BUT DATAS ARE DELETED OK IDRISH 911
set your messages in messaging - options- settings - other to 999 and e memory.
restore factory settings *#7780# default code is 12345 that might just might help you a bit and turn off and on your phone when you do all these things see if it helps any.
“Memory Full…Close some applications and try again” is a normal message that usually comes on Nokia N70. It showed the memory used in the phone doesn’t have space anymore. But if the message still appears although the user already closed some applications it can be theproblem. Someone who experience in this memory full problem said, an error message of memory full like above is appears each time he’s opened the Camera. It also happens for a few times when he’s trying to open messages, Gallery, or other applications. And then it will force to restart the phone. Seems like it’s a RAM problem and might there are some applications unable to close completely. If your Nokia N70 phone has gone a start menu button you can try to hold it down. This way will show you everything that you have open and they can be closed easily so that you can continue to take your photos. So if it can resolve the problem you can reset/format by pressing *#7370#
YOU NEED TO CHANGE THE MESSAGING MEMORY BY FELLOW THIS TIPS : PRESS THE MENU AND PRESS MESSAGING AND PRESS OPTIONS CHOOSE SETTINGS CHOOSE OTHER CHOSE MEMORY IN USE THERE YOU CAN CHANGE THE PLACE THAT MESSAGE STORAGE IN .
The phone needs to be formatted .... take backup and then press *#7370# ...default code 12345 ...the phone will restart ...after which try again after that you will download from www.mobile9.com because the nokia N72 will suport only sis files please down load from this web site
