Question about Microwave Ovens
GE Microwave built in 2006 has powered off...no previous problems...most recent circumstance was a 5 minute time selection that was made (to act as a timer) and after the 5 minutes was up the power disappeared...I recycled the power, but no change
  • 143 Answers
Try opening the case and checking the fuse. If blown, check the door switches.
Posted on Jul 23, 2008
Loss of power during use
You didn't mention your brand or model, but I'd bet it's a GE/Hotpoint or other Samsung-made oven.
This problem is almost always due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
Details covering some previous models are in GE's bulletin here. Even if your model is not on the list, the same problem can occur.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or maybe the wire mesh RF gasket was not installed or got pinched.
NOISY MAGNETRON TEST (c) 2009 William E. Miller prototech@usa.net (permission granted by poster-author to FixYa to keep this document on their site intact)
One way to test it is to do the following:
1. Unplug the microwave or turn off its breaker.
2. Open the door, then detach the control panel as shown in the video at http://www.microwavedisplay.com and swing it down, but without disconnecting the wires. )If you have any trouble getting the grille off once the screws are removed, slide the hood vent grille to the left about 1/4", then then pull it forward. On some models there are L-shaped clips that fit into a slot to hold bottom of the vent.)
3. Plug the microwave back in.
4. Make sure neither you nor anyone else reaches in behind the control panel. There will exposed high-voltage connections.
5. Put a few cups worth of water in a microwave-safe container and place it inside the microwave.
6. Shut the door.
7. Run the microwave for about 1 minute or so on full power. (Time Cook > 1 > 0 > 0 > Start, e.g.)
8. If it does not fail, try it several more times.
9. When the water boils, change the water and try again.
NOTE:
If your model does not have a door handle, you will need to unplug the oven and reattach the control panel to be able to open the door.
If it still does not fail, I would recommend that you put it all back together and keep using it until it fails more consistently, then repeat this test.
While a microwave should never be left running unattended under any circumstances (as your owner's manual will tell you) it's even more important when one is exhibiting a failure or any odd behavior. So play it safe and stay with it while it's running!
If you or someone you know want to replace the magnetron yourself, you will need to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions
here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find links to helpful exploded view diagrams and part ordering help
here. I'd recommend that your bookmark this link to your favorites.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
If it's under magnetron warranty, GE will send you the magnetron to do it yourself. Call them at 888-239-6832.
If it is not within the magnetron warranty, you can find links to helpful exploded view diagrams and part ordering help here.
If you prefer to arrange service by an authorized service center, GE Customer Service is here.
Dec 25, 2009 | GE Profile Spacemaker Over-the-Range...
When we use the microwave sometimes after about 5 seconds it just shuts off and resets everything as if it lost power. It does not do it everytime.
Since this is posted under GE, I'll assume it's a GE.
6. Shut the door.
NOTE:
here.
here.
Be persistent. You may have to speak with a supervisor.
Nov 23, 2009 | GE Profile Spacemaker Over-the-Range...
Starts to run then powers off and turns back on
2. Open the door, then detach the control panel as shown in the video at http://www.microwavedisplay.com and swing it down, but without disconnecting the wires. (If you have any trouble getting the grille off once the screws are removed, slide the hood vent grille to the left about 1/4", then then pull it forward. On some models there are L-shaped clips that fit into a slot to hold bottom of the vent.)
6. Shut the door.
NOTE:
here.
You can find helpful exploded view diagrams and order parts by entering your full model number
here.
If it is not within the magnetron warranty, you can find helpful exploded view diagrams and order parts by entering your full model number here.
Oct 04, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave stops running
Mostly with GE I find this to be bad connections at the fuse holder or a bad fuse due to a bad fuse holder. It will break connection and reset the unit when the connection gets hot and expands and then opens and stops power from getting to the unit.
Aug 14, 2017 | GE Microwave Ovens
Jvm1650 shuts off
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again. If that doesn't work, leave it unplugged for about 5 minutes.
Otherwise, this is almost always due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
Details covering some previous models are in their bulletin here. Even if your model is not on the list, the same problem can occur.
2. Open the door, then detach the control panel as shown in the video at http://www.microwavedisplay.com and swing it down, but without disconnecting the wires. If you have any trouble getting the grille off once the screws are removed, slide the hood vent grille to the left about 1/4", then then pull it forward. On some models there are L-shaped clips that fit into a slot to hold bottom of the vent.
6. Shut the door.
NOTE:
You can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Jul 18, 2009 | GE JVM1650 1000 Watts Microwave Oven
Ge microwave shuts down after three seconds
Let us know what you find out.
6. Shut the door.
NOTE:
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
Sometimes they will send you the magnetron to do it yourself. Call them at 888-239-6832.
Jun 15, 2009 | General Electric Microwave Oven
I have a GE Eterna Spacemaker Model Number EMO3000HSS05
Reduced power was selected, perhaps inadvertently
May 07, 2017 | GE EMO3000 Microwave Oven
Power level
The numbers DO NOT equal a certain power level Erin. They equal a percentage! This is very confusing. Even the factory reps. can't explain it adequately. I recently replaced my old 600 watt oven with a GE 1100 watt model. The 600 watt unit came with a great cookbook. (I searched the internet but couldn't find one for the GE oven and the factory was no help!) A chicken recipe in the 600 cookbook said cook on high for 30 minutes. Since 600 is approx. half of 1100, I cooked on high for 15 minutes. Result: Uncooked chicken...
The next time I cooked 30 minutes on 50% power (button 5) and It came out OK. I have since used 50% power with meats in cooking bags with good results. Remember to check for correct temp. with a meat thermometer when oven stops. Trial and error is your best test at this point I'm afraid. Also you may want to type "Microwave Conversion Chart" into your browser. You will get some additional information from this. But read carefully!
Ray
Nov 16, 2008 | GE XL1800 1100 Watts Microwave Oven
I bought a ge microwave 5/20/08. I have used it several times and it has worked well. Today I was cooking baked potatoes. I usually do them 1 by 1 and then put them in the oven for a crip skin. After...
It should default to the high power level without your having to select that.
But if you think it may have a problem, you could unplug it for a few minutes then plug it back in and try again.
After that, if it's not acting as it should according to the owner's manual, it may need service.
If so, since it's under warranty, I would let GE fix it.GE Customer Service is online here.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 25, 2008 | GE Microwave Ovens
Microwave Ovens Logo
83 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
