Question about Car Audio & Video
I have a Pioneer GM-H100 amp and I can not figure out the whole 3 prong thing is there a special wiring for it i have seen mixed comments of this same problem on different website can you please help me out
I have a gm-h100 amp. The three prong plug is for a remote turn on. Mine has two wires one of which goes to the radio where it gets a power on sigonal (12 volts when the radio is on). the other wire goes to the an accesory fuse where it gets 12 volts when the key is turned on. the amp needs both of these before it will run
Posted on Jun 27, 2009
I need wiring for pioneer gm 3000 amp?
Here is the pinout. You need to solder your own connections.
Oct 15, 2014 | Pioneer Gm-3000t Car Amplifier
Show me a picture how to hook up this pioneer gm-h100 amplifier
What do the red and black wire go to coming out of the harness?
Jan 04, 2012 | Ford F-150 Cars & Trucks
Can not find where to hook the rem wire on my pioneer gm-h100
This remote wire requires a switched 12 volt .This can be connected at fuse panel and or to radios remote out or power antenna wire.
Sep 22, 2011 | Car Audio & Video
Conect 4 wires to 3 wires box in the wall
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one to the left here is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown to the right. These are just just thumbnail pictures that you can click for a larger view. But I'll bet you already figured that out, didn't you?
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
tn_3prong_dryer_outlet.jpgtn_4prong_dryer_outlet.jpgIf you need to re-wire the outlet, these pictures will explain the anatomy of the three-prong (left) and four-prong (right) outlets. Once again, these pictures are just thumbnails--click 'em for a larger view.
Sure hope this helps you find a resolution to your delimma! Best wishes.
Comments: Jul 23, 2009- bf71290.jpgfb4d3ed.jpg
Three wire Four wire.
Aug 18, 2009 | Whirlpool LER5636P Electric Dryer
Pioneer GM-232 Amp
amp%20specs%20001.jpg444bbca.jpgcc2af91.jpgthese are from the actual owners manuel-i used to have this amp also. hope these help
Dec 29, 2008 | Pioneer GM-232 Car Audio Amplifier
My pioneer gm-h100 amp does not have a remote wire hook up on the amp
there should be a wire harness that clips into the side of the amp if you dont have the clip u can just use some end conecters and hook it up to the two pins that are on the side and hook that to the remote wire.
Aug 11, 2008 | Car Audio & Video
System Remote Control Wire.
Wal Mart generally has 4g wiring kits for ~$40. Some of the kits contain everything you'll need to install your amp (including RCA cables, fuses and fuse holders).
If you want to understand more about car audio installation, read through the following site:
Read the following pages specifically:
Installation Primer
Head Unit
Dec 28, 2007 | Pioneer GM-5100T Car Audio Amplifier
Pioneer GM-7300M 800 Watt amp will not power on
This may have a different type of triggered turn on wire. On some of the older Pioneer amps (and maybe some new ones) the trigger wire would SUPPLY B+ TO THE RADIO and when the radio was switched on the amp would sense a current draw on that wire and would then switch on. Unlike most common amps which sense the presence of B+ on the trigger wire supplied by the radio and then turn on. Look in your owners manual to see kind of turn on system you have. If you don't have an owners manual then perhaps you can download one from Pioneer support. good luck
Aug 23, 2007 | Pioneer GM-7200M Car Audio Amplifier
Car Audio & Video Logo
613 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
