Question about Sony KP-46WT500 46" Rear Projection HDTV-Ready Television
Convergence issue My Sony KP-46WT500 (5 1/2 yrs old) went from a perfect picture to moderate separation of colors. I'm seeing a slight bend in color in the upper left hand corner of the screen. The Flash Focus doesn't remedy the picture. Any suggestions?
  • Anonymous Aug 06, 2008
    The exact convergence issue. 5-6 years old. WIll take your advice and replace these parts. Thanks
  • Anonymous Aug 31, 2008
    Sony KP-46WT500 5 to 6 years old. perfect picture shifted out of color convergence. red and green are now seprated. Flash Focus does not correct.
  • Sony Master
  • 8,617 Answers
You need to replace both STK392-560 convergence ICs and some of the 4.7 ohm 1/2watt resistors. You can get replacement ICs and resistors at the following link with free instalation instructions.
http://servicemanuals.vstore.ca/
Posted on Jul 23, 2008
Convergence ?
IF THE COLORS ON SCREEN ARE SEPARATED, OR BLURRY, OR YOU SEE SEPARATE COLORS ON SCREEN. DO A GOOGLE SEARCH AND YOU SHOULD FIND CONVERGENCE PROBLEMS ON TV'S AND WHAT IT LOOKS LIKE. THERE ARE CONVERGENCE KITS AND EASY INSTRUCTIONS.
Nov 11, 2013 | Sony KP-61V90 61" Rear Projection...
My sony kp 53v75 projection tv has an issue right now. The screen has lines that run horizontally across the screen that slightly distort the image. They move up and down slowly on the screen, Is there any...
Tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alingments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK comvergence ICS and some or all it resistors are dead too.These parts on the tv convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost like $300-350 for parts and labors.
Nov 22, 2010 | Sony KP-53V75 53" Rear Projection...
Colors seperate
Yes, this problem is fixable.
Replace convergence out chips on D board of tv to fix the color separation issue.
Jun 05, 2010 | Sony KP-46WT500 46" Rear Projection...
Colors have separated. and top and bottom af pictures are bowed. i have a sony kp-46s55. its about nini years old and it was free. currently the colors are separated and the top and bottom of the pict
nbad convergence ic , this need to be done by a profecional tv tech , because need to check for the pico fuse and resistor around the area
May 08, 2009 | Televison & Video
Color issues
This is a convergence problem that can be as simple as poor solder connections at the convergence ICs to defective ICs. Can you solder? If so, let me know and I'll provide additional instructions.
Dan
Sep 05, 2008 | Sony KP-51WS510 51" Rear Projection...
Bend in picture and color seperation
try resoldering the convergence ICs if that doesnt help you will no doubt need new Convergence ICs .resolder both of them as thats sounds like a solder issue, unless the IC is getting to the end of its operational ability
Mar 26, 2008 | Sony KP-46WT500 46" Rear Projection...
Convergence problem
did you try to do convergence thru the menu system?
Feb 21, 2008 | Sony KP-51WS500 51" Rear Projection...
Convergence and picture problem.
convergence ic's
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
Jan 07, 2008 | Sony KP-57WV600 57" Rear Projection...
SONY KP-61HS30
When one or all the colors are bending severly, then the convergence circuit is not functioning correctly and must be repaired. Only one color bending means just the convergence ICs and all colors bending means convergence ICs and voltage supplies. Convergence issues are the most common problem with rear projection (w/picture tubes) televisions. The cure is replacing the convergence IC's. Sometimes the pico fuses need replaced as well. If you have the experience to use a soldering iron and a basic understanding of electronics, then, you may be able to do this job. If not then call a servicer in your area. Go to the Sony website, Sony.com, and you can locate one in your area.
Jan 07, 2007 | Sony KP-61HS30 TV
Sony KP-46WT500 46" Rear Projection HDTV-Ready Television Logo
118 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
