Question about Dryers
Accessing drum and others parts
Dryer is making loud noises but still seems to be heating up and drying. I want to take the top off and have loosened the two clips in the rear of the dryer so the rear lifts up but I can't see what is holding the front down. Can anyone tell me how to remove the top?
  • 1 more comment
  • jfisher627 Jul 24, 2008
    After scanning recent posts I found out how to open the top and have managed to pull it apart. The drum roller supports were bad, but what I found was the motor shaft also makes a squeaking sound when turned by hand. I oiled the shaft and it stopped,what I need to know is will the bearings be OK or should I replace them as long as it is opened up. Can they be replaced or does the whole motor need replacing. I also think there is room for a wider belt to drive drum, is it practible to get a wider 1/2" belt over the 3/8 belt. This is an Amana DLG330RAW gas dryer. TIA
  • lama3 Aug 14, 2008
    How did you open the dryer for access??? I have the very loud banging noises too. The dryer works fine except for that. We too thought the belt needs to be lubricated. But, can't figure out how to gain access to the drum. Any help?
  • matt27 Aug 19, 2008
    Have a Amanda Electric Dryer Model Number NDE7800AYW
    Makes loud noise, as if the belt is slipping. Do not know how to take the dryer apart to check. Need assistance
    Genius:
  • 1,122 Answers
WHAT MAKE AND MODEL??????????
Posted on Jul 23, 2008
GE 5 Cycle Automatic Heavy Duty Extra Large loud noise
All ge dryers have a center bearing on the back side of the drum and drum glides on the frontside. The glides make a scrubbing sound when bad and the drum is hard to turn. The rear bearing does a squeak thang when the plastic bearing wears thin and begins to make metal to metal contact between drum mount and rear bulkhead mount. It is an easy fix but the drum gotta come out. here is my pictorial page that shows how with videos and repair pix:
Paw Paws GE dryer repair page
http://appliancejunk.blogspot.com/2011/09/late-model-hotpoint-dryer.html
http://appliancejunk.blogspot.com/2011/08/hotpoint-dryer-eating-clothes.html
Jan 09, 2013 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Drum makes loud banging noise.
Maybe the heat in your dryer over time has melted weak glue and loose components are hitting against the drum
Jan 16, 2012 | Frigidaire Electric Dryer
Drum will not turn and there is no heat.
This dryer has a circuit board that controls virtually everything. If it makes a buzzing noise when you press the power button to turn on the control panel, it's probably not going to be an easy fix. When you hire a professional, you avoid buying expensive parts that you might not need, such as a control board. If it makes a loud buzzing noise when you press the start button, it's possible that it could be a motor or belt problem. But again, I'd recommend a service call for this one.
May 25, 2010 | Whirlpool GEW9250 Electric Dryer
When we turn on our Whirlpool Supreme electric dryer, it heats up and dries clothes, but it is making a loud squeaking noise throughout the cycle...sometimes louder than others.
The squeaking noise can be caused by any of the following.
Location High:
Belt slipping on the dryer drum
Worn Drum seals but would sound more like a dragging noise
Location Low:
Belt tensioner pulley bearing frozen and the idler pulley shaft is spinning inside the belt tensioner assy.
Belt slipping on the motor bearing
Motor bearing is dry
Thanks for using FixYa!
Kelly
Mar 04, 2010 | Whirlpool LER5636P Electric Dryer
Kenmore 110.86980800 Dryer making loud banging noise but works
Try this link: https://www.searspartsdirect.com/model-number/11086980800/0582/0151200.html?searchType=modelSearch&q=110.86980800&searchTerm=110.86980800. Under Troubleshooting, click on "Making noise or vibrating". Most likely one of the dryer drum support rollers is bad. The parts bag will have two rollers so you can replace both of them while you have your machine apart. You will find the instructions on how to replace a roller by following the link on that page. Not a very difficult job. I didn't even have to pull the dryer out of the utility closet. Most time consuming part was vacuuming and wiping off everything inside. Went thru a lot of paper towels. The triangular retainers where a bit of a challenge to remove. I recommend some small needle nose pliers and don't worry about damaging these retainers since you get four new ones in the parts bag with the two rollers. The retainers go on both sides of the rollers and fit in a groove on the shaft. When putting the new retainers back on I used a 3/8 nut driver to initially push them on. A small regular screwdriver might also come in handy in getting the triangular retainers past the first groove. Only other surprise for me was the roller on the left side required the removal of a bracket held on by a type of washer retainer which worked on the pinching concept to remain in place. I ended up getting behind it with a small regular screwdriver, then moved it a little ways down the shaft. Then I grabbed it with some pliers and pulled it off. Wonder what engineer figured that one out. A new retainer comes in the parts package. Your dryer might vary a little bit (mine is a Kenmore 110.86873100 electric model) so take pics if you want. One other thing. I supported the front of the dryer drum with my dust buster while I took pics of the motor and pulley system before removing the belt from the motor shaft and pulley tensioner. I also used the dust buster as support when reinstalling the dryer drum. Good luck with the heating element. I haven't had to deal with that problem yet.
Mar 31, 2017 | Kenmore Dryers
Dryer makes a loud thumping noise when running
A thumping sound in your dryer could be caused by a flat spot on one of the drum support rollers. It can also be caused by a problem with the drum. An idler pulley on for the belt on the drive motor can also make a thumping noise when the dryer is running. Check to see if the cabinet is properly leveled with 4 feet firmly on the floor. Push down on opposing corners to check for play. Adjust the leveling legs if necessary.
Without a model number of your Whirlpool dryer, I am not able to provide much more help. If your dryer has the lint filter that pushes down into the top panel of the dryer, then here are a few tips for accessing the inside of the cabinet:
  • Unplug the dryer to disconnect electrical power.
  • Pull the lint screen out.
  • Remove the screws that secure the top panel to the lint screen housing.
  • Use a putty knife to release the clips on the front of the top panel (about 4" in from each side) that secure it to the dryer frame.
  • Hinge the top panel up and back.
This will provide to access to the inside of the dryer cabinet. Manually spin the drum in a counterclockwise direction and see if you can determine the source of the noise.If you need more help, resubmit your question with additional details and the full model number of your Whirlpool dryer.
Aug 08, 2009 | Whirlpool Dryers
KENMORE DRYER
Hello ENRIGHT11 Welcome to Fixya
My name is Huum,
You said,
DRYER MAKES VERY LOUD NOISE WHEN RUNNING. ALTHOUGH IT HEATS UP AND BEGINS TO DRY, IT STOPS RUNNING COMPLETELY AFTER ABOUT 5 MINUTES. IF YOU WAIT AN HOUR, YOU CAN START IT AGAIN, BUT IT AGAIN SOUNDS VERY LOUD (ALMOST A RATTLING SOUND) AND THEN SHUTS OFF AFTER 5 MINUTES
Faulty Blower Wheel
If you hear a great deal of noise coming from the blower area of the dryer when it is running, then the blower wheel could be defective.
The are many different designs for blower wheels and just as many unique failure modes. Vanes (fins) can break off the wheel and bounce around in the blower breaking more pieces. The blower can break around the coupler with the shaft. This can cause the blower to spin loosely on the shaft. The blower can form cracks which cause it to vibrate, etc.
You should also not be surprised to find foreign debris in the blower. The occasional bird, rodent or squirrel has been known to bypass the out vent cover. If they crawl into the exhaust tube the first thing they come into contact with is the blower wheel.
If the blower wheel is not spinning, or if it is missing vanes, it is not moving air efficiently. As a result, heat is not removed from the heat source and it can trip the high limit switch or blow the thermal cut-off.
Worn Belt
A worn belt can stretch and/or become brittle with age. The belt can then slip on the drum or motor to cause squeaking. If this is the case, the solution is to replace the worn belt.
The belt is not the only item that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum bearings, worn drum glides or worn drum rollers depending on brand and style.
When replacing the Belt is is a good idea to also change the Drum Support Rollers, Drum Glides, Idler Pulley and Clips. All of these items are economical easily changeable when replacing the belt. The upside is that your dryer will operate like new.
Recent Customer Symptoms:
Dryer makes loud noise when turned on. Dryer works and heats up OK but makes too much noise.
Worn Drum Glides
Some dryer models are equipped with Drum Glides. The front of the dryer rests on these glides. They provide a low friction surface on which the drum spins. After time however, this glides wear down. Much like an automobile brakes, these glides make a load grinding noise when they wear thin. This griding against the drum usually leaves a bare metal stripe that is visible at the point of contact. If the glides are worn, the solution is to replace them.
The drum glides not the only items that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum bearings, a worn belt or worn drum rollers depending on brand and style.
When replacing the Drum Glides it is a good idea to also change the Drum Support Rollers, Drum Belt, Idler Pulley and Clips. All of these items are economical and easily changeable when replacing the glides. The upside is that your dryer will operate like new.
Worn Rear Drum Bearing
Some dryer models are equiped with a Rear Drum Bearing. The rear of the drum rests on this bearing. It provides a low friction surface on which the drum spins. After time however, this bearing will wear down. If the bearing is worn, the solution is to replace it.
The rear drum bearing not the only item that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum glides, a worn belt or worn drum rollers depending on brand and style.
When replacing the rear drum bearing it is a good idea to also change the drum glides, drum support rollers, drum belt, idler pulley and clips depending on make and model. All of these items are economical and easily changeable when replacing the rear drum bearing. The upside is that your dryer will operate like new.
Worn Drum Support Rollers
Some dryers such as Whirlpool/Kenmore brands are equipped with Rear Drum Support Rollers. The weight of the dryer drum rests on these rollers. They provide a low friction surface on which the drum spins when in operation. After time however, these rollers wear down. When they wear, often times they begin to elongate and form a non-round 'cam' shape. The result is that when the dryer is turned on it creates a rumble that sounds as though you are trying to dry a pair of tennis shoes. This sound is usually the drum being forced up and down on the non-round wheels. If the rollers are worn, the solution is to replace them.
When replacing the Drum Rollers it is a good idea to also change the Front Drum Glides, Drum Belt, Idler Pulley and Clips. All of these items are economical and easily changeable when replacing the glides. The upside is that your dryer will operate like new. Whirlpool
Kenmore models have a dryer maintenance kit that contains all of these items in a single kit.
Thank You For trusting us with your question
Please remember to leave a
solved rating before you leave!
Jan 21, 2009 | Kenmore 63942 Dryer
Dryer making chirping noise while drying.
If this is a GE/Hotpoint dryer then I can tell you exactly what it is. The rear drum bearing is worn down. WE3X75. To replace it you must remove the drum. This involves opening the door and removing all screws holding down the top. Then removing those holding the front on. Then removing the drum itself. This is not a hard job for a mechanically inclined indiviual.389d186.jpg
Jan 17, 2009 | Dryers
Dryer is making loud thumping noise.
Take off the back panel of the dryer and look at the motor and belt turning the drum. There may be something caught on the drum and is pinned in place causing the noise. The motor could be loose on the platform and needs to be tightened. It is probably something physical and seen causing the noise.
Jan 04, 2009 | Whirlpool LER4634J Electric Dryer
Dryers Logo
246 people viewed this question
Top Dryers Experts
