Question about Swann Communications DVR4-Alert Video Recorder
Set HDD to master
My swann communicator has a no hdd install. How can this be possible it is a new dvr4-alert? How can I now it is set to master?
  • 1 more comment
  • evillegas18 Jul 23, 2008
  • Anonymous Jan 19, 2009
    i have a swann dvr-4 alert recorder . when i try to play back it says hard drive fail. how can i fix it?
  • david_lecher Apr 11, 2009
    Do not buy swann products. I bought a new swann dvr4-alert complete system, and it did not work. Said no hard drive. I contacted the Swann 800 number and talked with their tech who said it was out of warrenty and to buy a new hard drive. So I bought a new hard drive and the same thing. I was going to buy the same main box again until I found this site and read about all of these other people having the same problem! I'm going to purchase another brand!
  • 322 Answers
The internal power supply to the HDD is often suspect in these units. Check you have power on the internal plug to the HDD from the circuit board. if you do not Try fitting an external HDD power supply (£15) this cured my unit which had a similar fault.
Hope this helps - good luck.
Posted on Oct 28, 2009
If the hard-drive (HDD) is not being detected, follow these steps to try and get it working…
Firstly, check that the power supply you are using is correct. If your DVR came in a kit with cameras; it should come with 2 or more power supplies (a/c adapters).
Sometimes customers will use the camera power supply to power the DVR, this will cause the HDD to not be detected.
Make sure the power supply connected to the DVR is correct (Try swapping the one used to power the cameras with the one used to power the DVR)
If the HDD is still not detected, you may need to open the case of the DVR to check that all the cables are correctly connected to the HDD.
Unplug the DVR from power, unscrew the necessary screws, and remove the casing of the DVR.
Unplug the 2 cables from the back of the HDD, and check that all the pins are intact and not broken or bent.
Check that the jumper settings on the hard-drive (located between the 2 cables) are set to MASTER.
Instructions for setting to MASTER are located on the top of the HDD on the information.
Now reconnect both cables firmly into the back of the HDD.
Place the case back on the DVR and plug the power cable back into the DVR.
The HDD should now be detected.
If it is still not detected, the HDD may be faulty, or may not be compatible with the DVR.
Posted on Jul 23, 2008
Swann DVR4-950 will not recognise HDD
some hard drives will not get recognized by dvr unit. but here is a possible repair link go there and sii if you can find some help. you may have to register online with this forum to get more help.
http://www.cctvforum.com/about17745.html
Oct 23, 2017 | SWANN Home Security
How do I reset password on swann DVR4-3450
You will have to call swann about this. I don't use passwords on my security system because of this.
Mar 07, 2015 | Swann Communications Televison & Video
Swann video recorder is flashing red light
My DVR box is powered up but, i get no picture and the HDD red light is flashinG
Feb 13, 2013 | Swann Communications DVR4-Alert Video...
When i press record a message comes up saying no hdd to write
hi,
i think ur its storage device hdd have some problem. the hdd is not detecting. check the connections of hdd for any loose contact. if found faulty replace it.
ok
Dec 23, 2010 | Swann Communications DVR4-Alert Video...
PASSWORD FOR SWAN DVR ??
Hi
The unit has a default password = press CH1 (channel 1) button 6 x times
good luck
Jan 02, 2009 | Swann Communications DVR4-Alert Video...
Hdd set to master
my dvr4-alert does not record no hdd
Jul 23, 2008 | Computers & Internet
Swann dvr pro-net
Go to menue ---> System ---> Clear HDD and make sure "yes" is selected and hit enter.
May 16, 2008 | Swann Communications DVR4-Pro-Net...
Motion recording for Swann dvr4
Have you switched cameras to AUTO (A) on settings line. Is the sensitivity for motion turned on and set correctly =
1= very sensitive 9 = less sensitive.
Setting areas are shaded = no recording area
unshaded = recording area
Mar 14, 2008 | Swann Communications DVR4-Alert Video...
Swann Communications DVR4-Alert  Video Recorder Logo
1,596 people viewed this question
Top Swann Communications Televison & Video Experts
Lawrence Oravetz
Jack Frost
Are you a Swann Communications Televison and Video Expert? Answer questions, earn points and help others
