Question about Krups FMF5-14 Stainless Steel 10-Cup Coffee Maker
Krups fmf 5 water leaks from the bottom of coffee maker
  • blazeburns Jul 24, 2008
    It leaks very fast all of a sudden.  I tried pouring water to replenish the resevoir as it was making coffee and the water that came out the bottom was hot.  No water is going up and through the basket up top.
  • Anonymous Mar 12, 2014
    My Krups 988 leaks water out the bottom of the machine.
  • 3 Answers
I took the bottom off mine and found that a hose that connected to to the water level tube had become disconnected.
In order to get the bottom off you need a Torx internal tamperproof pin (6 lobe) screwdriver to get the 5 screws out.
Posted on Jan 06, 2009
I have a krups 12 cup coffee maker that leaks when I pour water into the resevoir. How can I fix this?
Probably providing more info that includes the model number will help someone to help you. Have you any idea how many coffeemaker models Krups have made?
Jul 16, 2017 | Krups Coffee Makers & Espresso Machines
What does dotted line rectangle mean, appearing on screen, on Krups FMF-5?
it looks like you have a display problem try reset if not replace display
Oct 07, 2014 | Krups Coffee Makers & Espresso Machines
Krups water leak
It could be the seal where the tank engages. I would remove the bottom and prop it up so I could see underneath it and then engage the tank and see where the water is coming from. Sometimes putting it over a mirror and having a torch on hand can help you see deeper inside while it is leaking.
Jan 13, 2014 | Krups Gusto 880-42 Espresso Machine
Need to fill resivoir how much
Unplug coffee pot, empty over sink, turn on to ensure it has pumped all water out, turn off, refill with water, restart normally.
Sep 05, 2009 | Krups FME2 Coffee Maker
Krups kp 2000 water leak
I had the same thing happen. It turned out that the rubber hose connecting the water reservoir to the heating element had disconnected, probably due to grinding vibration. I found a triangular screw driver to open the coffee maker up at MicroCenter: http://www.microcenter.com/single_product_results.phtml?product_id=0332974
After removing the bottom of the coffee maker, the repair took 1 minute and it is brewing coffee again like new!
May 25, 2009 | Krups Coffee Makers & Espresso Machines
Bunn coffeemaker leaking
Is this a Bunn or a Krups-you have both listed.
Aug 09, 2008 | Krups Small Appliances Espresso Machine
I have the krups espresso and caffe machine and i have no idea how to MAKE espresso (it's NOT the one below)...
turn on your krups espreeso to warmup the water, put one spoon of coffee in the handle, lock the handle and turn on the pressure button, and the coffee leaks in your cup, that's all
Apr 27, 2008 | Krups Caffe Bistro 867 Espresso & Coffee...
Leaking from the water Chamber
The Krups heats the water through a horseshoe shaped aluminum tube which the heating element is wrapped around the tube in the same fashion, the tube is corroded or cracked most likely, if you poured cold water into the machine when it was hot, this will crack the tube, they are made by Cesod ? which is stamped on the element with a number on it,  and I have seen between 700 and 1100 watt elements. I have the same problem with my 7 year old krups coffee maker, Im trying to repair the tube with aluminum welding or find a new element.  It could also be the high temp tubing may be cracked.  You need tamper proof Torx bits to remove the bottom cover on some models.
Jan 21, 2008 | Krups Caffe Bistro 867 Espresso & Coffee...
Krups FMF5-14 Stainless Steel 10-Cup Coffee Maker Logo
605 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
cyfred
Level 1 Expert
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
