Question about Sony KP-51HW40 51" Rear Projection Television
Sony KP-51HW40 51in
When i turn it on picture seems allright then it slowly starts turning red until all you can see is red. can i fix this myself or is it gonna cost me a grip.?
  • tibi77 Jul 25, 2008
    I HAVE THE SAME PROBLEM. PICTURE TURNS RED AFTER ITS BEEN ON FOR ABOUT 10 MINUTES.
    Problem Solver:
  • 9 Answers
It sounds like your red tube is going out. Fairly expensive piece but easily replaced. They run anywhere from $250-$350.
Posted on Jul 29, 2008
1. My Sony KP-57WS500 TV is turning blue after abut 3 minutesof operation. It stays that way for about 30 miunes and comes back with pictures again, but with predominatly blue color. 2. Sometimes the TV...
Sounds like the picture tubes are failing,common on sony. do you notice any thin horizontal lines? You mite get lucky and be able to adjust the voltages. Remove back cover and look inside to see which tubes are lighting up.The front panel below the screen will come off and behind it is a small access cover.remove it. there you will find the voltage controls (its a plastic square with 6 knobs). 2 knobs for each tube, 1 is focus the other is the voltage labeled "screen". they are marked so look closely. Green is always in the middle but sometimes they flip the controls for red and blue so pay attention to which you are controlling .slowly adjust screen voltages to see if you can get it to stay on. If you over do it those thin horizontal lines will pop up and the tv will shut off again. If you already have lines back off the voltage by turning knob to the left slowly until they diappear. If that seems to fix it but the problem but it comes back later, then the tubes are shot. good luck!
Jul 05, 2010 | Sony KP-57WS500 57" Rear Projection...
My sony tv stars blinking 5 times in a row, then the picture goes black for a second comes back then goes black again and it keeps doing it non stop
tv has a blanking picture mute circuit. adjust the screen controls which are located behind the speaker grill in front of set. there will be a access panel to unscrew in center and then you will see a black 4 inch square box with 6 physical knobs. 3 control screen the other 3 controls focus for red, green, blue. turn them down and slowly start turning them up. fixed.
Nov 11, 2009 | Sony KP-53XBR200 53" Rear Projection...
The screen turn completly red after about 20 min being on
Usually that is a sign that your red picture tube is ailing. However there is a chance that it can be adjusted out, at least buy you time worst case.There is a voltage control in the front of the TV, you have to remove the bottom front half of tv to get to it. Some Sony's have 2 screws hiding at the bottom of set in front hidden behind 2 plastic covers,others just have screws along the backside.Be careful there are wires to front panel attached so remove slowly and leave wires on just move it out of your way..Once you remove that there is a small access panel to take off. You will see the voltage control (small plastic square with 6 knobs) The top knobs are focus controls for each tube the bottoms are for voltage adjust. The far right knobs are for red.So you can turn the red voltage control SLOWLY to the left,this will reduce voltage.Reduce until you see the red lines disappear. If you go too far one way or the other with the voltage control the tv will shut down and you'll waste time readjusting and turning set on until it stays on. If you can't adjust it enough to get all the red out without shuting down tv tube is in too bad of shape.
Apr 27, 2009 | Sony KP-65WS500 65" Rear Projection...
I BOUGHT A KP-57HW40 SONY AND ALL I CAN SEE IS A
Try this....
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
These sets have weak picture tubes, this may buy you some time. It is not worth changing the tubes in the set. The cost would be more then its worth. Try these adjustments until it completely dies. I have the same set.
Apr 21, 2009 | Sony KP-51WS500 51" Rear Projection...
Sony rear projection screen is red then tv shuts off
Can be 1 of 2 things. 1st the red tube just needs the voltage to it turned down. In the front of TV (you have to remove the lower front half of TV to access it) is a plastic square with 6 knobs. The from left to right top knobs control focus for blue,green red. The bottom knobs control voltage to each tube in same order (so lower right knob for red) turn SLOWLY to left to reduce voltage until excessive red and lines go away. If you over turn left or right set will turn off. If that does not fix it or if lines reappear then option 2 is that red picture tube is failing outright and needs replacement.
Jan 29, 2009 | Sony KP-57WS500 57" Rear Projection...
Sony KP-511HW40 fleshing with green color and shuts off
this is a common fault adjust the little black box in front behind the small wooden cover. you will see 6 controls don't adjust any of the top 3 only the bottom knobs 1 for each color. slowly back the control counterclockwise turn the set on and wait untill it shows a picture, slowly adjust the control for the color in question utill the color balance is correct- black and white with the color setting turned down all the way with the user menu when balance is ok you are all set.. turn the color back up with user control. rtepeat process if needed.
Dec 26, 2008 | Sony KP-51HW40 51" Rear Projection...
Kp57wv600 sony tv with red background and red dominance.
completly remove speaker cover untill you can see the electronics. there will be a box with 6 setting screws. on the bottom row of screws , look for the screw with the letter r under it .  verry verry slowly turn that screw counter clock wise untill the picture clears up . good luck
Oct 28, 2007 | Sony KP-57WS500 57" Rear Projection...
Sony KP-51HW40 No Picture, only sound
to thus problem its very simple .! try to resolder at the back of the picture tube board.
Nov 26, 2006 | Sony KP-53V75 53" Rear Projection...
Sony KP-51HW40 51" Rear Projection Television Logo
64 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
