FixYa.com
Tags:
Flat Panel Televisions
Generic problem for all Flat Panel Televisions
HDMI
posted by buschgator on Jul 23, 2008
I am new to the world of LCD's, HDMI, upconverting DVD players, and so forth. I have everything hooked up properly, but I'm not getting any video on the tv screen. Also, the audio is continuously cutting in and out (mostly out). Do you have a suggestion or solution?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jul 23, 2008
Not Rated (0)
Agent Aaron
Rank:Guru Guru
Rating: 86%, 123 votes
Hey buschgator,
If you've made all the appropriate connections, there are a few things that you may wish to try to resolve the problem.
First, you'll want to make sure that your TV is set to the proper input station. Some models may require that the TV be set to an external input to display any kind of signal from an HDMI input source. Input stations can usually be selected by pressing the "Input" button on the TV's remote control, but may also only be available through the TV's main video menu, depending on our model.
Second, you may be encountering an HDMI "handshake" failure. Whenever two devices connected by HDMI cables fail to recognize each other (the handshake fails), users may not see any images displayed or encounter poor picture/sound quality. This type of issue can typically be resolved with newer electronic devices by unplugging each device and power cycling them (turn them off then on).
Third, you may want to try another HDMI cable to make the connection. Like all other electronic components, HDMI cables have the potential to be defective right out of the box, though such instances are generally few and far between.
Should none of these suggestions help, you may wish to refer to your TV's owner's manual for more information. Some older HDTV's may not support HDCP (high-bandwidth digital content protection), and as a result you might need to contact the manufacturer for alternative solutions.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: Panasonic TH-42PX60U Television Sony BRAVIA KDL-40V2500 40 in. HDTV LCD Television Sony BRAVIA KDL-40S2000 40 in. HDTV LCD Television Sony KDF-E50A10 50 in. HDTV LCD Television Sony BRAVIA KDL-46V3000 Television Sony KDF-E60A20 60 in. LCD Television Sylvania 6842PE 42 in. HDTV-Ready Plasma Television
Can you Help with these Flat Panel Televisions problems?
Fujitsu Plasmavision P42HHA10 42 in....
no power no red or green light
there is no green or red lingt... Answer This...
Sony Bravia from MElena
I laid down my TV to make a... Answer This...
Haier LCD L30SV6 - tempremantal...
Hi i got hold of a haier LCD... Answer This...
Sony WEGA KLVS19A10 19 in. HDTV-Ready LCD...
bush lcd has no volume
Hi, the sound on my bush lcd tv... Answer This...
Sharp Aquos LC-32GD4U 32 in. HDTV LCD...
Sharp LCD screen is blank when...
Hi All, This problem only... Answer This...
Repair Service
Find Flat Panel TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
