Question about Kenmore 53509 Dehumidifier
Help me fix my dehumidifier
My dehumidifier keeps tripping my cicercit bracker what is wrong it has been working in the same plug for the past year and i tried it in two other plugs and the same thing happens
  • bobhenderson Jul 24, 2008
    My dehumidifier runs for 2 minutes then trips the breaker.
  • 11 Answers
What else is on the same circuit? Have you added any other appliances on that same circuit that were not on it before?
If no>>>you probably have a short in the unit, and it is grounding out>>>tripping the breaker before it starts a fire.
Also, check the breaker, they can go bad.
Posted on May 29, 2009
My dehumidifier keeps frosting I know the room temp. is above 65 what parts should I check?
Posted on Sep 23, 2009
What can be wrong dehumidifier keeps tripping the breaker
any appliaince that trips the breaker is a danger to your home as it could cause an electrical fire and should not be used, unit needs replaced asap
ck with your power company for any rebates they give for appliance upgrades Helps!!
Oct 02, 2014 | Dehumidifiers
4-5 years old. Has work great all that time. In the past week it stop collecting water. It runs but never any water in it. It's not leaking out. The collection pail is dry as a bone.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Aug 23, 2011 | Amana D530M Dehumidifier
I bought a model 365 remington dehumidifier. I plugged it in and nothing lights up. I have it plugged in for the past 8 to 10m hous and still nothing. Should i be seeing the blue light up ?
Two things that you need to check: Make sure that the outlet the dehumidifier is plugged int, is in fact working. The circuit breaker for that outlet may be tripped or there may be a loose or damaged wire connection to the one of the outlet's terminals. I assume you are turning the Master ON/OFF Switch to ON of the dehumidifier, after you plugged the unit in and set the humidity extraction level below 40%?
Jun 27, 2011 | Remington Model 365 Dehumidifier
I have a Kenmore dehumidifier 580.54701. It worked fine for two years, but now when it is plugged in and you hit "on" nothing happens. I took it apart, but cannot tell what is wrong. Do you think...
It could need replacing or the outlet that the unit is plugged into is at fault. Check you main circuit breaker panel, to see if a breaker has been tripped. Also, check the outlet's receptacle for internal damage or a loose or broken wire. In addition, try plugging it into another receptacle that is on a different circuit, than the one it's plugged into now. All these things are part of the process of elimination, in troubleshooting and finding the problem.
Hope this helped you. Please let me know. Thanks.
Jun 04, 2011 | Kenmore 54501 Dehumidifier
Dehumidifier #M7DH45B2A keeps tripping the GFCI . . .which seems like there is a short somewhere. Would appreciate your problem assesment and solution recommendation. Thanks.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
I would check if the compressor is starting... my first thought is that the compressor is either locked pu or not starting right because of a bad capacitor...
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Sep 12, 2010 | Maytag M7DH45B2A Dehumidifier
My Danby Silhouette DDR556RH dehumidifier is less than 2 years old (out of warranty) and is no longer drawing out the humidity. First, the hose connection to the sump pump stopped working (I have cleaned...
heatman101
Aug 21, 2010 | Danby DDR556RH Dehumidifier
Dehumidifier trips ground fault outlet and no water in bucket
The compressor is trying to start and pulling high amps which trips the GFI...
You are better off replacing rather then repairing that unit.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
May 17, 2010 | Haier 45-Pint Dehumidifier
Why does my dehumidifer suddenly starting tripping
either the compressor is locked up or the motor start capacitor on the compressor is shorted
Apr 14, 2010 | Ebac HD880 Dehumidifier
I have a Whirlpool dehumidifier that doesn't collect water
I have a Whirlpool dehumidifier model AD50LJ0: the compressor starts but then appears to trip out. The fan keeps running. It does not condense and water. Can you help?
Jun 08, 2009 | Whirlpool Dehumidifiers
Kenmore 53509 Dehumidifier Logo
707 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
